Loose sprocket?
ADSrox0r
PostPosted: 16:41 - 13 Jul 2013    Post subject: Loose sprocket? Reply with quote
Reet, so I decided to slap on a new chain and sprocket 'upgrade' on the Yibber as my old one was starting to sound a bit 'agricultural'.
The front sprocket was quite wibbly when I took it off, but the bolts were fully tight and the output shaft has no up/down movement so the bearings are fine.
Put the new sprocket on (used the old spacer) and it wobbles a fair bit still.
Made a rather tedious little video of it ... https://www.youtube.com/watch?v=DClzEvwxQj0&feature=youtu.be
Also took a photo of the bare shaft (oo-er)
It's a 2011 with only 5000-odd miles on it.
What ye think? Perfectly normal or potential fireball of doom?
ADSrox0r
PostPosted: 19:45 - 13 Jul 2013    Post subject: Reply with quote
Yeah the splines are disappointingly soft for 5000 fairly easy miles.
I'm wondering if I just wang a spacer like an appropriate sized washer between the sprocket and the retainer it might take out the lateral 'wiggle'?
Pete.
PostPosted: 23:37 - 13 Jul 2013    Post subject: Reply with quote
Normal, stop worrying. It's a bit more loose than you'd expect for 5k but nowhere near as bad as some.
Grease the splines to reduce the rate of wear.
a.k.a 'Geri'
The last post was made 12 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.59 - MySQL Queries: 13 - Page Size: 44.82 Kb
