cb650z miss firing
itsdave
PostPosted: 18:34 - 13 Jul 2013    Post subject: cb650z miss firing Reply with quote
So yesterday I was riding around and noticed one of my pistons was not firing.
So I changed all of the spark plugs and it seemed to be sorted but it seems to haveggone back to how it was I think. Now it has all new sparks.what could be wrong? Any suggestions many thabks
Suppose to be going to Cambridge on Tuesday.
Oh I was on motorways and A roads today if that makes a difference.
Thanks again.
Its.
Project cg125 current bike cbr600f sport white+ black watch out for me in central London.
RhynoCZ
PostPosted: 19:11 - 13 Jul 2013    Post subject: Reply with quote
Are you sure it's not a fuel starvation problem? Also change spark leads and if nothing then I'd say one of your ignition coils is faulty. Did the bike get wet before it happened?
itsdave
PostPosted: 19:42 - 13 Jul 2013    Post subject: Reply with quote
I was bumping it for a bit and it was fine then when I got the battery fitted properly this happens.
Thanks for the ideas I will check the carbs and everything else.
Its.
itsdave
PostPosted: 20:06 - 13 Jul 2013    Post subject: Reply with quote
I have just startd her up. Reved and it started to fire all 4 but put hand behind exhaust and specs of what look like oil hir my hand. Not loads just a little.
Its.
moonzoomer
PostPosted: 21:49 - 13 Jul 2013    Post subject: Reply with quote
The HT coils on this model are not good, they tend to split their outer casing so a visual check usually confirms the faulty coil ( there are only 2) to confirm the coil fault switch over the ignition input wire from one coil to the other, if the bike misfires on the other 2 cylinders then the coil is faulty and needs to be replaced but do not use S/H items as these are usually knackered or on their way out.
The last post was made 12 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 44.25 Kb
