| binge |
 binge Emo Kiddy
 Posted: 22:33 - 06 Dec 2004 Post subject: Arrr Not agen! |
Right, Ive just had a full engine rebuild and a new HT lead on my Speedfight 70 and it is still not cutting out for about 20 seconds affter I remove the key...
Its not coked up and self running because its a brand new engine. And its not to do with the HT lead cos thats new too...
It isnt my immobiliser because Barney checked that when I took it in... How can I stop it because Ive traced the switch back and caked it in WD40 and nothing.
<|Binge|> |
| Fortuna |
 Fortuna World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:15 - 07 Dec 2004 Post subject: |
Have you tried wiggling the bars from side to side when you take the key out? My Mum's old CG125 had a problem where the bike wouldn't turn off when the ignition was turned off. Wiggled the bars and it would though. A sign of a loose connection. ____________________ I must not be a troll...
Mmmm, Guinness
| binge |
 binge Emo Kiddy
 Posted: 00:24 - 07 Dec 2004 Post subject: |
It can run on from anything from 5 seconds to a minute...
Ive noticed that when the scooter is cold it dosent do it. And when the engine is reving it dosent do it, But when its ticking over it runs on, and can be reved and riden without a key for some time...
I want to wiggle the bars, but when I wanted it to do it, It wouldnt But tomorrow im putting my standard clutch back on because my Malossi clutch it very bitey and unsmooth. So ill get all the front farings off and check all the wiring again...
But its bugging me because I dont know what is causing it...
<|Binge|> |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 01:14 - 07 Dec 2004 Post subject: |
Wotcha.
Here's something easy to try.
When it's ticking over, simply pull the plug cap off.
If it stops immediately, then it's wiring related, if it carries on running then it's fuel / pre-ignition due to red hot carbon related.
At least that gives you a 50 / 50 head start in tracing the problem.
My trike has a solenoid valve in the pilot circuit of the carb which cuts fuel off as soon as the ignition is turned off - this is supposed to prevent over running. ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| Fortuna |
| binge |
 binge Emo Kiddy
 Posted: 11:49 - 07 Dec 2004 Post subject: |
Nah. They dont do Kill switches on the scooters...
Just for security reasons. Can this problem make my scooter easier to start without a key?
Ill try pulling too the HT lead today and see if it runs on... I wouldnt of thaught so though because its a brand new cylinder (Less than 10 miles)...
<|Binge|> |
| Dam_buster |
 Dam_buster Crazy Courier
| binge |
 binge Emo Kiddy
 Posted: 20:37 - 07 Dec 2004 Post subject: |
Right. today I pulled my HT lead off while the engine was ticking over and it cut out immidiatly... So thats a good thing right?
It looks like its a strip down and rewire jobby then.
<|Binge|> |
| Lone-Wolf |
| Fortuna |
| binge |
 binge Emo Kiddy
The last post was made 21 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
