How many tools to change a bulb?
bridgedino
PostPosted: 21:54 - 14 Jul 2013    Post subject: How many tools to change a bulb? Reply with quote
Why don't the makers of bikes consider simple things like changing a bulb in the dark in nasty weather?
Took me 10 minutes with a socket set and screwdriver to change a simple tail light. And that was in sunshine in my back garden.
My CBF600 had by far the easiest bulb change. No tools required just four fingers and a thumb. Done and dusted in around 3 minutes.
Just wondered how everyone else gets on?
clancy
PostPosted: 22:14 - 14 Jul 2013    Post subject: Reply with quote
Gave up on my old rvf was an absolute ball ache and fidly to change a headlight, rear light was easy just lifted the rear seat and you could get to the bulbs
Haven't had to on the GSXR so no idea Thumbs Up
KLX 300r
-Matt-
PostPosted: 22:16 - 14 Jul 2013    Post subject: Reply with quote
My ZX6 front ones are as easy if not even easier than the car, litearlly screw-out plastic cups.
Rear lights a bit of a cunt but not too bad once you've got the cumbersome fairing aside Rolling Eyes
Have any luck sorting your alarm by the way mate Question
kawakid
PostPosted: 22:27 - 14 Jul 2013    Post subject: Reply with quote
You have to remove the front cone on the er to change the headlight bulb. I also have a screen that needs removing too.
So you need a socket set.
The Z is easy no tools for the headlight and the rear is LED strips so should past forever.
I've a twin and a 4.
bridgedino
PostPosted: 22:44 - 14 Jul 2013    Post subject: Reply with quote
No luck sadly. Changed sensitive settings with no luck. It does everything fine except "go off"
Not put off though, will replace it win another one the same
kerr
PostPosted: 23:57 - 14 Jul 2013    Post subject: Reply with quote
They make it harder so lazy people will take it into the garage to get replaced, get fleeced around 40 squid for a feckin light bubl Evil or Very Mad
Is it the focus that you have to jack up and take the bloody wheel off to change a bulb? Shocked
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
-Matt-
PostPosted: 00:19 - 15 Jul 2013    Post subject: Reply with quote
Ah crap Thumbs Down i think it must just be bad luck. Unless you gave the bike a brutal winter ride that could of killed something i cant think what itd be ive had 3 cyclones over nearly 7 years without a fault would stick with em personally Thumbs Up
PostPosted: 00:45 - 15 Jul 2013    Post subject: Reply with quote
Headlights on the GS are readily accessible. The bulbs are probably hand crafted by blind Tibetan nuns though. If the rear LED cluster goes, it's doubtless cheaper to buy a new bike.
barrkel
PostPosted: 00:46 - 15 Jul 2013    Post subject: Reply with quote
The 2006-2008 ER6f does not need tools or anything removing to change either headlight bulb. The rubber cups can be peeled back, the wires unplugged, and the bulb mount removed by hand, all from reaching up from the front of the machine.
The SH300 needs splitting the handlebar fairing to change the headlight, and that's a tricky job, very easy to mark the plastic with screwdrivers used as levers, or snap one of the tabs. I've gotten the technique down now as it's my second SH300, but the insurance repairers who dealt with the bike after my last smidsy snapped a couple of tabs.
Bigmal This post is not being displayed because the poster is banned. Unhide this post / all posts.
_mjs_
PostPosted: 04:59 - 15 Jul 2013    Post subject: Reply with quote
I'm not looking forward to doing it on the ZZR... it looks like you've got to strip the entire fucking bike down in the Haynes Sad
trevor saxe-coburg-gotha
PostPosted: 05:53 - 15 Jul 2013    Post subject: Reply with quote
How many BCF forum members does it take to change a light bulb?
Fucking loads. One to actually change it, while the rest aggressively trash the member's parentage, heterosexuality, bike riding abilities, choice of bike, role in Zionist conspiracies, conceptual grasp of temporality, etc. etc.
bendover
PostPosted: 07:31 - 15 Jul 2013    Post subject: Reply with quote
i agree with the above, Thumbs Up
Shinigami
PostPosted: 07:38 - 15 Jul 2013    Post subject: Reply with quote
hornet is easy enough, a couple of screws on the headlight casing for the front and couple of screws on the cover on the rear too.
jeddy11
PostPosted: 07:45 - 15 Jul 2013    Post subject: Reply with quote
Also think they have to make harder and with tools so some douche doesn't come round helping himself to lenses and covers etc ..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
CarlosCBR
PostPosted: 07:52 - 15 Jul 2013    Post subject: Reply with quote
Right ball ache on my 6f, screen off, infill panels off, dash surround off.
radicalrabit
PostPosted: 09:24 - 15 Jul 2013    Post subject: Reply with quote
cbr1100xx Blackbird what a twat to change a bulb,
take off the screen to start with , then take off the clocks and then you can just about get a hand to the bulb holder but you have to take the wet shield off first . One bulb sits above the other and the lower one is a harder reach than the top . No idea about the back bulb because I haven't had to tackle that yet but not optimistic that its going to be any easier .
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
bridgedino
PostPosted: 10:22 - 15 Jul 2013    Post subject: Reply with quote
Jeez, and I thought it was only mine. Hard to believe they don't give it more thought when designing...or do they
c_dug
PostPosted: 13:23 - 15 Jul 2013    Post subject: Reply with quote
I'm not sure I've owned a bike yet where you can't access the headlight bulb by coming up from underneath rather than disassembling half of of the bike from the top.
johnsmith222
PostPosted: 13:32 - 15 Jul 2013    Post subject: Reply with quote
My ZZR 600 is a hassle when changing the headlight bulb as similarly the clock surrounds, screen and tank need to be lifted.
There is an access panel underneath the lightbulb but is more suited to people with very small hands.
It's not such a big issue to change the bulbs IMO, although i wouldn't fancy doing it at the side of an unlit motorway at night.
huskie69
PostPosted: 15:41 - 15 Jul 2013    Post subject: Reply with quote
The VTR's fiddly but nothing in comparison to the bulbs in my old Volvo S40.
I got nabbed on the way home by a copper some years ago who told me a bulb was out. It was dark and the only place open was the dreaded halfrauds. I picked up the cheapest I could find and went to pay.
That day they were offering a free bulb fitting service if I bought some de-icer so I did. I paid up and then they asked me what my car was..... 'Sorry sir, we don't fit bulbs in S40s'. WHAAAA??!!! To be fair, it's a right bastard of a job and I cut my hand up something rotten. In the end I got my missus to do it - just needs girly hands!
I dunno what's wrong with modern manufacturers (bike and car) but they really do take the piss when planning on how to access 'consumables'.
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
map
Mr Calendar
PostPosted: 15:59 - 15 Jul 2013    Post subject: Reply with quote
huskie69 wrote:
...nothing in comparison to the bulbs in my old Volvo S40....
The S40/V40 are fiddly but not too bad. Just the usual amount of cursing and prodding around in the dark (some may liken that to foreplay).
Bit like the ST1100. That's fiddly as well done from underneath the forks.
I understand on the newer Volvo models you have to actually remove the headlamp unit itself to replace the bulb.
Slacker24seve...
PostPosted: 17:33 - 15 Jul 2013    Post subject: Reply with quote
Super easy on the Daytona. Four screws and easily accessible.
Banger rallies are ace
Andy_Pagin
PostPosted: 20:43 - 15 Jul 2013    Post subject: Reply with quote
If you had to pay someone to change a rear bulb on a Vity it would be cheaper to buy a new bike.
kitty kat
PostPosted: 21:27 - 15 Jul 2013    Post subject: Reply with quote
no it is the Rover 75, we gave up trying to change the front bulb, even girly hands wouldn't work. We got the bulb in but couldn't get the holder to slot into place Twisted Evil
Mk1 fazer 600 is so easy to change the bulbs, absolutely no tools required for front or rear Smile not sure about the Deauville, I haven't changed a bulb yet Smile
The last post was made 13 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 129.5 Kb
