| fox |
 fox Spanner Monkey
 Posted: 14:59 - 15 Jul 2013 Post subject: Scamming MOT scum |
Car failed its MOT last week for 'excessively corroded suspension bushes', 'headlight aim incorrect' and 'plate light blown'.
They wanted nearly £400 for the bushes, and £30 quid each for headlight aim and plate bulb.
Told them where to stick it and got myself booked in to someone for today.
Surprise surprise, it failed again, but this time none of the above was mentioned.
This time it was for 'exposed wires by headlights'!
They want £85 EACH SIDE, to rewire! Told the guy I can get electrical tape for a quid, and got a jobsworth response about fire safety.
I need to find a "guaranteed pass" station asap!  ____________________ Sold: 2003 satin black Yamaha R6
Current rides: 2006 blue Triumph Sprint ST 1050, 2003 Yamaha WR450F |
| MarJay |
 MarJay But it's British!
| map |
 map Mr Calendar
| Islander |
 Islander World Chat Champion
| fox |
 fox Spanner Monkey
| MarJay |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 15:26 - 15 Jul 2013 Post subject: |
If you REALLY want someone to take the piss with an MOT, take it to Halfrauds. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| map |
 map Mr Calendar
| MarJay |
 Posted: 15:37 - 15 Jul 2013 Post subject: |
Looks like you can get a pair for a 306 with bushes for less than £40:
https://www.ebay.co.uk/sch/i.html?_odkw=Peugeot+306+lower+wishbone+assembly&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.XPeugeot+306+lower+wishbone+assembly+diesel.TRS0&_nkw=Peugeot+30
Get the car up on axle stands, remove bolts, replace wishbone, jack up front wheel slightly to meet the end of the wishbone, tighten bolts to specified torque. Shouldn't take more than 2 hours.
The number plate light might have blown because of the worn insulation on the wiring. I'd probably disconnect or unsolder it, place a bit of heatshrink tubing over it, and then re solder it, and heat up the tubing to seal it.
None of those jobs are particularly taxing TBH.
Oh, and £30 each for headlight aim? You have to be kidding! it takes about a minute! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| fox |
 fox Spanner Monkey
| yaigi |
 yaigi World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| fatjames |
 fatjames World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| G |
 G The Voice of Reason
 Posted: 23:56 - 15 Jul 2013 Post subject: Re: Scamming MOT scum |
Two different sets of fails from two different stations.
Grounds to report them both if you're not taking them back there?
(Not sure how it works reporting them for stuff they DIDN'T get, presuming each one is legitimate.)
However, yes, tape up the wiring appropriate and take it back.
Note that apparantly some VOSA people (not sure if it's the same ones that do car MOTs) can be VERY picky.
Thankfully the one that did my annual test, while he was thorough, was also a reasonable human being .
£200 for test and retest, still, hover . |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:35 - 16 Jul 2013 Post subject: |
Scamming MOT scum, or pissed off driver trying to cheapskate through the test?
Seems like you've got faulty wiring, faulty lighting and faulty suspension, some or all of which could be construed as being bad enough to fail the test.
If you maintained your car better, it wouldn't have failed the test at all. ____________________ Things get better with age; I'm close to being magnificent........
| Lord Percy |
 Lord Percy World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 07:41 - 16 Jul 2013 Post subject: |
I'll be phoning VOSA later today. I took a 'ped for a MOT. I knew I had issues when he refused to believe that the headlights only had on and off and had to check with someone else that it was ok. He failed it for not having a number plate light I pointed out that it was 12 years old and had never had a light, it didn't need one. He shouts to his mate who replies, yeah it's illegal, everything has to have one.
He then spent 15 minutes trying to find out how he put it down as a fail since it isn't on the list of items to be checked. He ended up typing it in.
Idiots! ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| The Wobbly Orange |
 The Wobbly Orange Brolly Dolly
 Posted: 07:59 - 16 Jul 2013 Post subject: |
| Acemastr |
 Acemastr World Chat Champion
 Posted: 08:00 - 16 Jul 2013 Post subject: |
| Ichy wrote: | I'll be phoning VOSA later today. I took a 'ped for a MOT. I knew I had issues when he refused to believe that the headlights only had on and off and had to check with someone else that it was ok. He failed it for not having a number plate light  I pointed out that it was 12 years old and had never had a light, it didn't need one. He shouts to his mate who replies, yeah it's illegal, everything has to have one.
Idiots! |
I'm kind of with him on that one, I thought you needed a number plate light too? every bike I've owned has has one (and car obviously) ____________________ 2017 KTM 350 XC-F - 2014 Yamaha R6 - 2005 Yamaha YZ125
2016 Toyota Tacoma Limited |
| The Disapproving Brit |
 The Disapproving Brit World Chat Champion
| uberkron |
 uberkron Crazy Courier
 Posted: 08:33 - 16 Jul 2013 Post subject: |
Barry car  ____________________ i ride a zip 50 2smoke. It overtakes a hundred times a day. |
| N cee thirty |
 N cee thirty Banned
 Posted: 08:41 - 16 Jul 2013 Post subject: |
Idiots! |
Where was this ? place in a crewe has recently got a jobsworth that makes things up and fancy giving him a boot up the arse. ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Lord Percy |
The last post was made 13 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
