Advice needed - Honda Blackbird Charging issue
Mrjoolz
PostPosted: 07:15 - 16 Jul 2013    Post subject: Advice needed - Honda Blackbird Charging issue Reply with quote
Hi all,
I was riding into work this morning, and got into London (40 miles from home) all OK. Stopped at work to ask Security to open the gates, and when tried to start bike, it turned over really slowly but did start.
Got the bike into the yard, parked up turned it off, and tried to start it again. Battery flat, ignition lights all dimmed when trying to turn over. Turned lights off and tried again, no change.
Any thoughts as to why the battery would have charged on the way in ? What do I need to check ?
Many thanks
Mr Joolz
Crying or Very sad
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
Formerly known as
P.
PostPosted: 07:36 - 16 Jul 2013    Post subject: Reply with quote
Regulator cooked itself? Get bike jump started and check voltage across battery. Anything under 12 or over 15 and you will want a regulator.
RhynoCZ
PostPosted: 07:39 - 16 Jul 2013    Post subject: Reply with quote
Reg/rec or stator, maybe a faulty battery Thumbs Up
Get multimetr and you should get 13v+ on the battery while the engine is running or arround 60v on each combination of 2 yellow wires comming out of the stator while the engine is running and when you turn of the engine you should get some ohm reading on those 3 yellow wires. At first try the battery and if you have a spare reg/rec then try it after you're sure the battery is alright.
This is very brief troubleshoot manual.
EDIT: Be sure you switch your device AC/DC, AC for stator, DC for battery/after reg/rec.
Aff
PostPosted: 07:51 - 16 Jul 2013    Post subject: Reply with quote
Here is a less brief guide. Very Happy
Electric Bike Project
Shinigami
PostPosted: 08:05 - 16 Jul 2013    Post subject: Reply with quote
i'll put my bets on regulator, I hate regulators, i've had a couple die/burn out on me
Mrjoolz
PostPosted: 08:26 - 16 Jul 2013    Post subject: Reply with quote
You back Paddy ?
Think its the R/R. Just called my mechanic, and he said even if AA come out and jump it, it wont get me home. I'll get stranded on route, as battery wont get me home on its own if not charging.
Is this correct ? Got 40miles to do through London
Aff
PostPosted: 08:44 - 16 Jul 2013    Post subject: Reply with quote
The ER6 managed 150 miles on a fully charged non charging battery.
If you have a way of charging it while you're at work I think 40miles should be OK.
RhynoCZ
PostPosted: 09:40 - 16 Jul 2013    Post subject: Reply with quote
I bet my money on faulty stator Thumbs Up
I had the same problem with NC27, running alright, then stopped and the battery was drained.
Mrjoolz
PostPosted: 10:00 - 16 Jul 2013    Post subject: Reply with quote
Got RAC coming out before 2pm to test it and if its knackered they will arrange recovery to my home at 5:30pm when I finish.
Last thing I need at the moment. Sad
Apparently my mechanic has one on the shelf and says it should be the same as mine. R/R with a single large plug on it.
Need to check on net and see if this is the case.
Formerly known as
P.
PostPosted: 10:17 - 16 Jul 2013    Post subject: Reply with quote
I would upgrade it to the R1 regulator when you have the money.
Islander
PostPosted: 10:22 - 16 Jul 2013    Post subject: Reply with quote
It might just be a knackered battery - they do die eventually or even loose connections. You really need to get a meter on it.
Check the voltage with the ignition off - it should be around 12V if it's much lower then you could try a smart charger to see if it'll recover it but that's indicative of a very flat battery. Then get the engine started and check again with the revs up around 4K or so. It should be around 14V if the charging circuit and reg/rec are alright.
If you're seeing a much higher voltage then the reg/rec has probably gone. If you're seeing a much lower voltage then you need to check the stator outputs (AC range). If they're fine then the reg/rec is dead. If they're not then it might be the stator. Check all the earth points and connections as you go.
Mrjoolz
PostPosted: 10:29 - 16 Jul 2013    Post subject: Reply with quote
whats the stator ?
Aff
PostPosted: 10:39 - 16 Jul 2013    Post subject: Reply with quote
The stationary part of your alternator, it's basically lots of coils of wire. All the leads coming out of the genny cover area of your bike come from the stator.
radicalrabit
PostPosted: 11:40 - 16 Jul 2013    Post subject: Reply with quote
ALMOST hate to say this but if you go on the Blackbird forum there is loads of info on this but god are they a bunch of self praising self centred pricks...
https://www.cbrxx.com/
https://www.superblackbird.co.uk/
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
RhynoCZ
PostPosted: 11:59 - 16 Jul 2013    Post subject: Reply with quote
Mrjoolz wrote:
whats the stator ?
Here's an burned one from NC27: https://i970.photobucket.com/albums/ae184/RhynoCZ/DSC00391_zps84e799c9.jpg
Mrjoolz
PostPosted: 14:09 - 16 Jul 2013    Post subject: Reply with quote
RAC turned up and tested battery. R/R was fine, and their battery tester basically said replace battery....knackered.
RhynoCZ
PostPosted: 14:17 - 16 Jul 2013    Post subject: Reply with quote
Did you charge up the battery before the test?
Mrjoolz
PostPosted: 15:49 - 16 Jul 2013    Post subject: Reply with quote
Nope. But by the time the RAC arrived, the blooming bike started. so had managed to sort itself out. Didnt even turn over slowly. Made me look stoopid.
Bezzer
PostPosted: 09:16 - 17 Jul 2013    Post subject: Reply with quote
You want to go over the electrics thoroughly before it blows something expensive. The reg/rec is a known weak point and your symptoms are what a lot have, it doesn't charge enough then fails to start but leaving it standing for a while allows the battery to recover enough to let it start also the connector to it from the stator, it can burn out/short, if it looks at all iffy the accepted fix is to hardwire it. If it's an FI 'bird then make sure the loom fix has been done as well, the test block can cause all manner of weird electrical problems, failure of electrical items and eventually a total shutdown if it's not sorted.
map
Mr Calendar
PostPosted: 09:55 - 17 Jul 2013    Post subject: Reply with quote
Late to the party but thought I'd throw my Penny Coin Penny Coin of thoughts in.
My old bike was having issues like this. My first thoughts were the reg/rec which it turns out would have been a bugger to replace. God knows how it was put in the frame in the first place.
Anyhow after posting on here the various meter reading I was persuaded to just try a new battery.
...and that solved the problem.
Still don't know how/why the battery became faulty but problem solved.
Hope it's as straightforward for OP.
Bezzer
PostPosted: 12:08 - 17 Jul 2013    Post subject: Reply with quote
Don't know what bike you were looking at but the 'bird reg/rec is just hanging there fixed to the outside of the subframe, 5 minute job to remove the seat plastics, unplug then undo the two bolts holding it to the subframe, job done.
https://ixxra.co.uk/v-web/phpBB3/download/file.php?id=1839&t=1
map
Mr Calendar
PostPosted: 12:24 - 17 Jul 2013    Post subject: Reply with quote
Bezzer wrote:
map wrote:
My old bike was having issues like this... the reg/rec ...a bugger to replace. ...
Don't know what bike you were looking at but the 'bird reg/rec is just hanging there fixed to the outside of the subframe...
To clarify my old bike wasn't a Blackbird but an old Kwack GT550. Located below battery box and I couldn't get a socket to the fittings due to the frame. Same symptoms though (it's just bike electrics after all).
Mrjoolz
PostPosted: 07:17 - 19 Jul 2013    Post subject: Reply with quote
Have bought a new battery and will fit it this weekend.
Smile
Will keep an eye on it.
Mrjoolz
PostPosted: 13:51 - 08 Nov 2013    Post subject: Reply with quote
Problem with charging is back. Pulled over in london on Wednesday to check phone for directions. 2 mins later, went to start the bike and battery totally flat. Had just done 40 miles up motorway.
RAC Came out and tested battery 11.8 on tickover and 12.8 on rev. However I managed to ride it home, and turned off bike. Tried to start and it turned over as if fully charged battery on it.
Following day it turned over really slowly and just managed to start. Rode into work and then when I came to leave at the end of the day it turned over fine.
Could it be the reg still ? I thought they were solid state and therefore would either work or not, not an intermittent issue. Is the reg/rec earthed out through the bolts holding it to the frame ?
I am having someone replace the reg and then perform a charging test on the replacement reg / battery. If figures return to normal, then sorted. if the figures dont return to normal, what could it be
Thanks in advance
Joolz
Bezzer
PostPosted: 14:30 - 08 Nov 2013    Post subject: Reply with quote
12.8volts @ 5000rpm points towards the reg/rec going tits up, but to make sure you need to check the stator output, the plug to the reg/rec has three yellow wires with the bike running on battery and the plug disconnected put a multimeter on AC volts across the three wires in pairs - 1-2 2-3 and 3-1 and you should get the same voltage for each pair probably around the upper 20s or so, they should all be very close to the same as each other. If they are then the stator is fine and it will be the reg/rec.
The last post was made 12 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 130.55 Kb
