CBT Signed off - This time !
finniee
PostPosted: 21:20 - 16 Jul 2013    Post subject: CBT Signed off - This time ! Reply with quote
So today I got my CBT certificate to say I can actually ride a bike and not fall off and I'm safe !. Please to say I am very very happy.
Made a minor/major mistake depends on how you would see it :
Forgot to switch the indicator off after coming off a roundabout, Instructor told me its easier just to press the indicator button after every turn.
Only question is as I will be keeping the 125 until I am 24.
So : Aprilia RS4 125 or Yamaha YZF R125. Are they the exact same or different ?.
Alpha-9
PostPosted: 21:42 - 16 Jul 2013    Post subject: Reply with quote
Different, both for tarts
go for the Aprillia
Fzr-600 1999
finniee
PostPosted: 22:04 - 16 Jul 2013    Post subject: Reply with quote
go for the Aprillia
I'm a high end tart though.
Seriously thought about it - the insurance is roughly the same.
-Matt-
PostPosted: 23:19 - 16 Jul 2013    Post subject: Reply with quote
I had a yzf 2 years couldnt fault it for a 125 personally Thumbs Up
PostPosted: 08:40 - 17 Jul 2013    Post subject: Re: CBT Signed off - This time ! Reply with quote
Why? You can get on a real bike when you're 19.
CBR125, put the savings into a jar marked "A2 license".
finniee
PostPosted: 13:12 - 17 Jul 2013    Post subject: Reply with quote
I lack the confidence at the moment to think about my a2 but iv always liked sports bikes... I'm thick so it doesn't help when I need to do a theory test, main reason is bike is cheaper than a car but will get my full car before I go for my full bike.
The Disapproving Brit
PostPosted: 13:56 - 17 Jul 2013    Post subject: Re: CBT Signed off - This time ! Reply with quote
Instructor talks sense. Get into the habit of checking your indicators after every turn, and even as part of your standard glance at the speedo while you're riding along. It's the easiest mistake to make and potentially one of the most costly, so make it second nature to check.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
UncleFester
PostPosted: 15:39 - 17 Jul 2013    Post subject: Reply with quote
My noob 2 cents regarding indicators .....
My YBR125 has fat boring blob indicators with wrap around lenses and they're great because you can see them when you're sat on the seat. That's good because you get to see when you haven't cancelled them in your peripheral vision. Then you get into very good the habit OF cancelling them.
Then you don't need to worry about what has become 2nd nature.
DottyDuck
PostPosted: 16:47 - 17 Jul 2013    Post subject: Reply with quote
what about when OP gets a different bike and he can't see whether the light is flashing or not!?
my only advice is to clear the indication before you change gear. It can be a costly mistake to make forgetting to cancel them. Imagine turning a corner, for example a left turn.. you indicate then turn left and forget to cancel the indicator... further up the road you can either turn left or go straight ahead... the car waiting at the junction sees your indicator light and pulls out thinking you are turning left and you then either smash in the back of him or luckily avoid him.
moral of the story? TURN OFF YOUR INDICATORS! Thumbs Up
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
-Matt-
PostPosted: 16:49 - 17 Jul 2013    Post subject: Reply with quote
I always place my thumb over the indicator button just prior to turning, then part of my 'turning routine' in my mind is to press it once straight and return the thumb to gripping the bar - very hard to forget if you do this i find as your mind is thinking 'why arent i holding with my thumb again Thinking '
Guess that may not work for everyone though depending on hand-size etc, wouldn't want to do it if it compromised you holding on properly Whistle
Alpha-9
PostPosted: 18:25 - 17 Jul 2013    Post subject: Reply with quote
Do A2, ride unrestricted Thumbs Up
drill indicators into your head, call yourself a cunt a lot, worked for me Thumbs Up
Fzr-600 1999
Entertwainer
PostPosted: 15:43 - 19 Jul 2013    Post subject: Reply with quote
i can vouch for the unforseen danger of leaving indicators on.
did this recently - within 100yards of setting off on my commute. turned right, forgot to switch it off. moments later down the hill, i get someomne pull out on me, i lay on the horn, wonder why (when i'm in full sight) they pulled out - then i get to the junction at the bottom and realise my indicator is still on.....
this was an issue in my CBT - but i'm getting much better.
turning off after every turn is a good tip to make sure its never on more than it needs to be.
it was a scary mistake to make - purely because it happened so easily. but luckily it happened at slow enough speed for me...
noobRider
PostPosted: 16:31 - 19 Jul 2013    Post subject: Reply with quote
I'm crap at turning off indicators too, trying to drill myself to press the cancel after every turn and check on every speedo glance.
Buy a cheap 125 and save for a big bike and your tests. Your confidence will grow quickly with practice.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Alpha-9
PostPosted: 09:50 - 20 Jul 2013    Post subject: Reply with quote
No such thing as a 125 sports bike, unless its a 2 smoker
How can it be a sports bike if it can't even do 80mph Razz
Fzr-600 1999
The last post was made 13 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 88.42 Kb
