Derailleur breaking?
Bike Chat Forums Index -> The Cycling Forum Goto page 1, 2  Next
Fladdem
PostPosted: 13:53 - 15 Jul 2013    Post subject: Derailleur breaking? Reply with quote
I thought I would ask here because I am not a member of other forums.
On my XC bike I have gone through about 3 derailleurs now, Shimano Alivio's all of them, I want to know why I only get about 2 months use out of them, I don't have them stretched to the max, I look after them well, I'm a massive bicycle nerd I love just working on bikes for no reason.
I don't know whether I'm just too hard on them, the last one happened after doing a rolling stoppie up to the traffic lights and it bounced into my spokes so when I rode off it got chewed up and snapped off in my wheel, my fault that time.
Another time I was just riding along and then it snapped in half, no extra pressure was applied and I didn't change gear. Is it just me being too hard on the bike or is it cheap derailleurs or both? I don't know whether to go for the same one again, as when it works I have no problems with it, or go for something more expensive and hope it doesn't break. I think with the 60 pounds I have spent on derailleurs I could have got a really nice one for that.
Thanks, Adam
UnknownStuntm...
PostPosted: 14:04 - 15 Jul 2013    Post subject: Reply with quote
Limit screw adjusters. Learn then use them Thumbs Up
Fladdem
PostPosted: 14:09 - 15 Jul 2013    Post subject: Reply with quote
I do know how to use them, I might spend longer setting the next one up, try and get it spot on, thanks Thumbs Up
UnknownStuntm...
PostPosted: 14:21 - 15 Jul 2013    Post subject: Reply with quote
To be honest, you can overcome a limit screw adjuster even if it's set up spot on and you're bouncing the bike about a bit. I often hear the cage dingalingalinging the spokes when I'm going over rough stuff on a sharp climb in the granny ring.
If I was to monkey on the shifter at this point I'm confident I could write off a rear mech and a wheel (and probably an arse cheek and some skin off my shin to boot) but I know not to do that.
KLR600
PostPosted: 17:18 - 15 Jul 2013    Post subject: Reply with quote
Might be worth checking that your mech hanger is still straight too if the derailleur is ending up in the wheel. Alivio isn't exactly the best by a long shot but I would expect it to last much longer than 2 months before snapping in half under normal use.
Chain Reaction Cycles have a sale on at the moment with quite a bit off some rear mechs, might be worth a look to see if a mech for your bike is cheap enough?
<Take Cool Photos!>
Fladdem
PostPosted: 19:42 - 15 Jul 2013    Post subject: Reply with quote
Good suggestion! I never thought about the hanger, I'm a rubbish bike nerd.
It was bent up, not by a lot but stick it on a flat surface and there's a smallish kick to it about 20 degrees.
I'll have a look at chain reaction cycles as well, see if I can get a mech, any suggestions? I keep using alivio because that's what it came with, might move up a step or something.
JonB
Afraid of Mileage
PostPosted: 20:42 - 15 Jul 2013    Post subject: Reply with quote
Moving a step up the groupset ladder doesn't make things stronger. In fact they tend to be lighter and more fragile.
Evidently there is something wrong with your bike, take it to your LBS.
PostPosted: 22:43 - 15 Jul 2013    Post subject: Reply with quote
Nothing wrong with an alivio. The one on Mrs stinkwheels bike has been there so long I've had to replace the jockey wheels.
Your bent hanger is probably the problem.
Maybe wortth checking your wheel spindle and hub integrity too? Just in case ot's snapped/snapping and is putting everything off kilter.
SIght along the chainline and look for any problems with the setup there. It's going to be off to one side or the other with being a geared bike but it should be more or less straight down the middle when you're on the middle sprocket and middle chainring. Particularly look for twisting of the chain. Obviously, you'd have to sight along the top of the chain on your bike, this one has a very slight bow to the right because the wheel isn't in straight.
https://i48.photobucket.com/albums/f216/stinkwheel/chainline.png
Fladdem
PostPosted: 20:40 - 16 Jul 2013    Post subject: Reply with quote
Straightened the hanger out, because I'm a cheapskate, got a new alivio derailleur on the way from the internet. Anything to consider while I'm at it? I will get a new hanger, don't worry but when you are a poor student like me you learn to pick what's needed most to help the bike run. And I keep pouring all my money into the 250 now.
I was tempted to make it single speed but it's got vertical dropouts with no means of tensioning the chain. I believe it was fairly straight before it was smashed, I can't remember that well now as it was last used on the 23rd of December, I was Christmas shopping, I just used the other bikes between then and now, but I miss it, the brakes, the lightweight, the wheelying, the staircase jumping, the 4X track, blasting round the local woods, the abuse it takes is astonishing, my other bikes just don't stand up to it as well.
Thanks for everything, can't wait to get back on it.
Adam
KLR600
PostPosted: 23:55 - 16 Jul 2013    Post subject: Reply with quote
You could have got this for probably around the same price as a new mech and mech hanger if you wanted to go single speed:
Single speed kit
I am also a poor student. I have a single speed jump bike with 1 brake and a long seat post, less to go wrong and break. I do live in Manchester (at the moment anyway) which is basically flat so it might be a bit rubbish if you lived somewhere with hills.
<Take Cool Photos!>
Fladdem
PostPosted: 11:44 - 17 Jul 2013    Post subject: Reply with quote
I didn't really want to go single speed but I would have done in a heart beat just to save money if I could have done it for free.
My specialized p2 is single speed as well, with a long seat post and just a back brake, I'd imagine a similar set up to your jump bike, I have way too many bikes for my own good, 23 spread out between the garage, the shed or just leant up against the fence, mostly they are like early mountain bikes, Raleigh Marauder, Diamond Back Topanga, Specialized Rockhopper, some other stuff. My favourites the 1958 Raleigh, followed by my 1933 Raleigh, my great granddads bike, it had a custom frame due to him being 6 foot 8, I'm 6 foot 4 and I struggle to get on.
All of my bikes were either free or bare minimum, the P2 cost me 56 pounds to buy the frame, forks and bars, and I had all the stuff I needed to build it up from there, it's pretty low spec, but I wasn't sure if I was going to get into it or not.
Entertwainer
PostPosted: 14:11 - 18 Jul 2013    Post subject: Reply with quote
make sure your top jockey wheel isnt fouling the largest/smallest sprocket on the cassette. its not just the limit screws that need attention when setting up a rear mech - you need to setup the B-tension screw as well.
https://www.youtube.com/watch?v=Z3bVgP_MNwc
Fladdem
PostPosted: 17:40 - 18 Jul 2013    Post subject: Reply with quote
I got it all set up just now, I stuck the hanger in a vice and squidged it flattish, bolted it on the frame and bodged it with an adjustable spanner, it works completely, now I need to tweak the front derailleur.
Thanks everyone, we'll see how long this one withstands my abuse.
On a side note, I won't be abusing it immediately as the rear axle is snapped, I was just checking the bike over, I was about to head out on my little 10 mile circuit, and the rear wheel had about two mm of free play, I thought it was the cones went to tighten them and noticed nothing happened, so took the axle out to check and just where the cone thing sits, the axle had snapped near the end of the threaded section and the skewer is bent. So, new hanger, new axle and new skewer next time I get paid. I think it must have been the snapped axle combined with a bent hanger that caused the last derailleur to get eaten.
PostPosted: 18:00 - 18 Jul 2013    Post subject: Reply with quote
Frame builders call this "cold setting" which sounds a lot more impressive than "Forcibly levering it into alignment using whatever tool or large piece of wood comes to hand."
Snapped axle can be a sign of misaligned dropouts. It is not impossable that the hanger was straight and the whole of the rest of the dropout is bent.
This was never a big issue until the widespread use of hollow axles to allow for quick release skewers.
A quick check/bodge involves two long, straight bolts and four nuts. Bolt one bolt firmly into each dropout with the heads facing into the middle a few mm apart. If the bolts are straight (check with a metal ruler) the heads should land up exactly aligned and paralell with an even gap between them.
If they aren't, get "cold setting" until they are. A bit of pipe over the end of your bolt will assist with this greatly.
This picture shows the "proper" tool being used to check dropout alignment. This one is WAY out.
https://www.parktool.com/uploads/images/blog/repair_help/FFG19.jpg
The "proper" tool has a big long bar built in to assist with cold setting.
https://farm6.staticflickr.com/5089/5286283357_e32384e3b6_z.jpg
Fladdem
PostPosted: 18:39 - 18 Jul 2013    Post subject: Reply with quote
Cold setting. I'll remember that. The hanger was definitely bent, I'm going to replace it and keep it as a spare to live in the "Ride Bag" just in case I ever need a spare just to get me home.
I'll have a play tomorrow, the joys of the summer holidays, playing whenever I like, I think they might be a touch misaligned because I was checking it out earlier trying to work it out if they were straight.
I was saying to my dad earlier as well that the hollow axle probably caused it to be weaker, although saying that I've snapped solid axles before.
Fladdem
PostPosted: 15:26 - 07 Aug 2013    Post subject: Reply with quote
More problems.
I have replaced the axle, the drop outs weren't bent, got new derailleur on and set up, or so I thought. Now it refuses to hold a gear when I accelerate hard and the chain seems to skip a lot, as if it's not connecting with the sprockets, what could be the problem now? The bike, to me is not worth a lot of money, I bought it for twenty quid off a mate who trashed it, it lived in his garden for a year and then lived in mine for 6 months, it's a Scorpion Rage, and the only things worth keeping are the stuff I put on it, Avid BB5 brakes and DMR V8 pedals.
If it needs new chain rings, a cassette and a new chain to replace the old ones cos they are worn out, this is what I am thinking is causing it, I may just scrap it and take the good bits off.
Please give me hope.
JonB
Afraid of Mileage
PostPosted: 15:42 - 07 Aug 2013    Post subject: Reply with quote
Either your cassette is worn or your hanger is bent. More likely the latter.
Fladdem
PostPosted: 16:15 - 07 Aug 2013    Post subject: Reply with quote
Oh dear, this is the second time I forgot about the bent hanger. Embarassed I cannot believe this, I keep meaning to get a new one, but it slips my mind. This is more frustrating than anything because it should have been the first thing I checked.
Fladdem
PostPosted: 20:19 - 28 Aug 2013    Post subject: Reply with quote
the derailleur is dead. I killed it a fortnight ago on some dirt jumps I think I hate gears now, although my single speed mtb snaps chains like no ones business so I can never win. the fixie on the other hand never has anything go wrong, never snapped a chain, only problem is a flat tyre so far. after over a year of (ab)use.
Just thought I'd let you know, I think I am just doing something wrong.
PostPosted: 14:06 - 29 Aug 2013    Post subject: Reply with quote
Touching the tools to 'fix' your bike is my bet. Thumbs Up
Fladdem
PostPosted: 16:34 - 29 Aug 2013    Post subject: Reply with quote
Hahaha, you're probably right there. Embarassed
Although I have fitted many derailleurs without problem in the past, it's just the ones on this bike I struggle with, I have straightened the frame out as best I could, I got a new hanger, new axle and re-tightened the cassette. I just think the bike hates me. I admit to not being the most skilled bike mechanic in the world, but I'm not too shabby.
JonB
Afraid of Mileage
PostPosted: 16:51 - 29 Aug 2013    Post subject: Reply with quote
Everyone in thread disagrees.
Epic and Fail are the first two words that spring to mind. Laughing
PostPosted: 16:55 - 29 Aug 2013    Post subject: Reply with quote
Do you know how many derailleurs I have fitted?
2 because that is how many bikes I have built. They have both run for many miles without needing to be replaced.
The problem isn't your ability to fit a derailleur.
PostPosted: 16:59 - 29 Aug 2013    Post subject: Reply with quote
Fladdem
PostPosted: 20:26 - 29 Aug 2013    Post subject: Reply with quote
Currently I have 23 bikes at home and I do not know how many bikes I have built, I made my first out of bits from the local tip when I was 12, an old raleigh marauder mtb frame, it's my fixie now, 7 years later.
I have just built a jump bike out of parts I have been paid with, my mates have a problem with their bike, most recently my mates derailleur, I fixed it, it wasn't changing smoothly, he paid my with a front brake for a bmx, although it will go on the back of the fixie. I restored two 50's raleighs last summer. I'm not that bad, I don't know all the names for parts, and I don't know all the theory, and the first wheel I tried to build last week is disastrous but I'm trying. I have just had trouble with this particular bike since I got it.
I know you two are just having a laugh but this bike has got me so wound up, it's just a money pit.
The last post was made 12 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 146.56 Kb
