Brake sensor on a 91 yamaha TZR 125 doesnt work
simon1221
PostPosted: 22:20 - 07 Dec 2004    Post subject: Brake sensor on a 91 yamaha TZR 125 doesnt work Reply with quote
i need to adjust the sensors on my bike, the brake light goes on when i press the rear brake but not when i press the front one, does anybody know how to adjust the sensor so that it will come on when i press the brake cable?
thanks
Simon
PostPosted: 22:25 - 07 Dec 2004    Post subject: Reply with quote
It is most likley one of two types.
1) a square microswitch under the lever mounting. These aren't really adjustable.
2) A cylindrical 'plunger' switch that screws into the lever clamp. These are adjusted by screwing them in and out.
It is probably nothing to do with adjustment though, most likley a bad contact in the switch itself, squirt it full of WD40 and work it back and forth a few times. If this doesn't fix it, get a new one, shouldn't be expensive.
simon1221
PostPosted: 22:43 - 07 Dec 2004    Post subject: Reply with quote
im not sure its a 91 tzr (kickstart), erm cant really tell you much more than that at the moment
thanks anyway
mchaggis
PostPosted: 22:47 - 07 Dec 2004    Post subject: Reply with quote
You can tell whether this kind is working by whether the little plastic pin pops out of the front of it when you pull the lever. This would normally connect the switch and make the light come on. If it stays inside the housing, spray it with wd40 and pray, or admit defeat to the god of borked springs and get a new one.
I got a new one when the spring went ping in mine, it cost me a fiver if I remember correctly on ebid.co.uk. They can be a bit of a pain to find even though they are generic, although that might have been me searching for the wrong thing. Embarassed
I must not be a troll...
Mmmm, Guinness
simon1221
PostPosted: 15:32 - 13 Dec 2004    Post subject: Reply with quote
cheers for your help, i just sprayed in wd40 like you said
and now it works but i have loads of other problems to sort out....
The last post was made 21 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 44.22 Kb
