CG125 cylinder + piston woes
treeno
PostPosted: 14:19 - 19 Jul 2013    Post subject: CG125 cylinder + piston woes Reply with quote
Hey!
Long story short I replaced the piston and barrel on my 1997 CG125 and the new piston is more domed than the old one and is also taller. This results in the piston poking out of the end of the barrel by ~1mm. I have a feeling this means that someone in the past has replaced the piston and cylinder head with one from the newer models which according to what I've read (link below) had flatter and slightly shorter pistons and a non-recessed cylinder head.
https://hondacg125.awardspace.com/how_to_increase_engine_size.htm
Anyway, can anyone confirm that the older models had a recessed cylinder head which would allow for the piston poking out of the barrel and stop it from bumping into the head as it does currently?
Ta!
treeno
PostPosted: 11:52 - 20 Jul 2013    Post subject: Reply with quote
unitynotsocrippledatmo wrote:
difficult one ....Measure the size of the pistons , check the barrel , and compare with spec . You may have an odd chinese barrel or piston , check the ohc models to compare .
I've actually had two pistons delivered as I thought the first may have been a dud. They are both 1mm taller from the centre of the gudgeon pin hole to the top of the Crown. Hard to find exact dimensions of the original piston but it fits the description. The only thing I haven't changed in the top end is the cylinder head now. If you have a look at the picture of the underside of the head in that link, it does look like that. Unless it is the crank or the control length having been changed but I somehow doubt it?
treeno
PostPosted: 20:12 - 21 Jul 2013    Post subject: Reply with quote
Bump... Anyone have any knowledge on this?
treeno
PostPosted: 00:03 - 22 Jul 2013    Post subject: Reply with quote
The different gudegeon pin sizes . You may have a later model piston .
One way to check its ok is to put a thin layer of grease or bluetack on the piston , put the barrel , piston and head on and tighten the head bolts.....
then turn it over through a few good turns .Disassemble the head and check the valves are'nt touching the piston crown by marks in the bluetack / grease / paint. You may end up with a higher compression cg , they are tuned lowish anyway .
differences in the skirt should be checked , and rings / oilway patterns / casting marks to indentify it visually / by measurement on ebay parts etc .
Thanks for the tips! The gudgeon pin is the old style 15mm, but apparently they changed that to 13mm in 2004 (but changed to a flat piston in 2000) so I guess that puts the parts in between that date range.
From what I can see the edge around the combustion chamber on the cylinder head is where the piston is bumping. The edge is flush with the bottom of the cylinder head therefore doesn't allow the piston to go all the way up. I will give the blu-tac method a shot! I have also been trying to identify the year of the barrel and cylinder head but it is proving quite difficult.
The new piston looks very similar to the one in the first photo (as did the first one I ordered, I thought it was wrong at first!) and the original has the same shape and size as the second one but is not completely flat on the top like that one.
treeno
PostPosted: 00:10 - 22 Jul 2013    Post subject: Reply with quote
Some further evidence for my theory is the piston from the 01-04 model which I have just found:
https://www.ebay.co.uk/itm/NEW-HONDA-CG125-CG-125-PISTON-KIT-RINGS-01-04-STD-/230443913117?pt=UK_Motorcycle_Parts_13&hash=item35a7870f9d
This looks exactly like the original, however having changed the barrel and bought a new original piston I would quite like to finish the job off and get an original head if that will fix it! Although that one strangely has a 13mm pin. Confused
treeno
PostPosted: 10:57 - 19 Oct 2013    Post subject: Reply with quote
Sorry to resurrect an old thread but I thought this would best go here. Does anyone see any issues with using a completely different piston? I found a piston from a pit bike that is shorted with the same bore, so should fix this problem that has stumped me for months. Is it fine to do that?
The last post was made 13 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 69.04 Kb
