Strange juddering at low speeds on rear brake -Diversion 900
Cheeseybeaner
PostPosted: 18:40 - 19 Jul 2013    Post subject: Strange juddering at low speeds on rear brake -Diversion 900 Reply with quote
Wondering if anyone has any ideas on this...I recently had the rear master cylinder rebuilt with new seals, fitted a goodridge hose and changed fluid, rear disc was also replaced around the same time.
The bike basically stops fine with the back brake, it appears to work okay but at low speeds say beneath 20mph I get a strange jerkiness as if its applying pressure intermittently so you can't really control the bike with the back brake as much as you'd like to.
There's no unusual feeling coming back through the lever when doing this and it otherwise works very well at all other speeds. I thought the master cylinder seals might have been going but have also just replaced the unit complete with a Fazer 1000 master cylinder this week.
The disc looks pretty much fine to me, if you spin the back wheel it doesn't seem to bind against the pads though it looks like a tiny flutter may be there - I wouldn't have thought it enough to cause problems.
My bikes: 2003 KAWASAKI ZRX1200R, 1996 YAMAHA DIVERSION XJ900S
Robby
Dirty Old Man
PostPosted: 22:11 - 19 Jul 2013    Post subject: Reply with quote
How well did you clean up the wheel before fitting the new disc? Alloy corrosion on the wheel can push the disc out of true. To fix, remove the disc and sand down where it seats until you have bright, clean alloy.
Cheeseybeaner
PostPosted: 00:23 - 20 Jul 2013    Post subject: Reply with quote
That would be enough to give this juddering on/off sort of feel to it? As I recall it still had the same sort of feeling with the old disc on it.
Nemo
PostPosted: 00:34 - 20 Jul 2013    Post subject: Reply with quote
These are shaft driven right?
Did it start doing it pretty much as soon as it was done, or a little while after?
If there's no odd feeling through the brake lever then it's not going to be the brake system itself I wouldn't have thought.
Has the rear wheel been located properly?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Cheeseybeaner
PostPosted: 01:04 - 20 Jul 2013    Post subject: Reply with quote
Yeah it was there before and after refitting the wheel I think really not related. It is a shaft drive bike. I think there was a similar feel even with the old disc on it (which I replaced as it was worn beyond its limits.) Its like a juddering on/off feel to the brake at low speeds as if pressure is pulsing on or off.
Nemo
PostPosted: 01:28 - 20 Jul 2013    Post subject: Reply with quote
Checked the caliper mounting? I forget what its call, but I think its the torsion bar or something?... Does it have one? If so is it secure? Not sure that would give a juddering feeling though..
Im thinking out loud, sorry!
What have you checked?
When you're stationary and have the brake on, and you rock the bike, is there any movement?
Robby
Dirty Old Man
PostPosted: 19:49 - 20 Jul 2013    Post subject: Reply with quote
If the mating surface on the wheel has corroded, it will push the disc out of true and make it feel like a warped disc. This can happen with the disc fitted, corrosion happens slowly and has enough force to push a disc out of true. It can cause juddering/pulsing.
Cheeseybeaner
PostPosted: 20:17 - 20 Jul 2013    Post subject: Reply with quote
Thanks, sounds like removing the disc again would be my best option and checking what's going on under there. As I can only see what seems like a really slight flutter to the disc as you spin the wheel I didn't think it significant (not so much that it would halt the wheel just by spinning it, but a slight touch against the pads in one spot) and seeing as the new disc was only fitted about 8 months ago wouldn't have jumped to thinking that was the cause of the problem.
Ariel Badger
PostPosted: 23:47 - 20 Jul 2013    Post subject: Reply with quote
If you have a Dial Test Indicator (Clock) mount it on the swing arm and test the disk for true.
Fizzer Thou
PostPosted: 14:22 - 21 Jul 2013    Post subject: Reply with quote
You do not say that you replaced the pads at the same time as the disc.If the old disc was worn and grooved then so will the pads be.If they are contaminated or worn unevenly then they should be replaced.
Was the new disc thoroughly cleaned with brake cleaner before installation?
Always have a 'Plan B'
Cheeseybeaner
PostPosted: 01:32 - 22 Jul 2013    Post subject: Reply with quote
Unfortunately I don't have one. Took the disc off today and there was some corrosion type deposits in various places under the disc which I've removed and brought it up to bright alloy with a file.
I've refitted the disc and ridden it, still seemed to be that flutter going on when spun it would tighten up giving a bit of resistance against the pads in one spot.
Rode it and although the judder has lessened a little its still there so I'm assuming the disc has warped, there are some signs of overheating in places.
Don't understand what's happened to it really as its an EBC disc rather than say a cheap Chinese one (as was previously fitted), the caliper was rebuilt and fitted with new pads at the same time so why just 8 or 9 months later its giving trouble I don't know...
Cheeseybeaner
PostPosted: 21:18 - 26 Jul 2013    Post subject: Reply with quote
Disc from ABE now fitted on the bike and the juddering's gone completely...
Would love to know what I actually did wrong with the EBC disc, is it possible that the corrosion could have contributed to warping/uneven pad deposits on the disc enough to leave me with a disc with bad run-out?
Trying to be as careful as possible bedding in this one, 200 miles at light to moderate braking then 10 heavy braking runs from 60 to 20 sound about right?
PostPosted: 23:44 - 26 Jul 2013    Post subject: Reply with quote
Shouldn't make the slightest difference to the disc. Bedding in is just the pads wearing to 'fit' the disc.
You could fit a new disc, shoot up the road and stand on the pedal, you wouldn't hurt it at all Thumbs Up
The last post was made 13 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 78.53 Kb
