charging 12v battery with solar panel
mic
PostPosted: 11:24 - 20 Jul 2013    Post subject: charging 12v battery with solar panel Reply with quote
Morning
im sure theres a way to work it all out but i have no idea.
i use a lesuire battery to power my ittle fishing boat. id like to keep the battery topped up when im anchored but i have no idea how long would be a sufficient charge.... lets say ive drained 50%, there must be a way to work out how long id need to solar charge the 50% back.
85amp calcium battery
4 watt solar panel
so many watts per amp per hour?! or sumfink?
thanks
ZebraDriver
PostPosted: 13:21 - 20 Jul 2013    Post subject: Reply with quote
In an ideal world it would probably take about 150 hours to recharge your battery. However as this isn't an ideal world, and given that the 4w of charge is very optimistic and given that your battery is slowly discharging itself all of the time the real answer is that it probably won't manage to recharge the battery at all.
4w solar chargers are good for preventing a fully charged battery from discharging itself but not good for much else
ZD
Marmalade
PostPosted: 13:22 - 20 Jul 2013    Post subject: Reply with quote
4 watt solar panel will maybe keep it fully charge through natural wastage but connect it to a half charged battery and it may be back to full in about 5 years.
You need something at least a lot better like a 60w to charge up a battery in a sensible time.
Marmalade
PostPosted: 13:27 - 20 Jul 2013    Post subject: Reply with quote
if it is a standard leisure type battery at 110amp a 4w charger at maximum capacity for 8 hours a day would charge it in theory in 37 days if there was no usage or natural wastage.
uberkron
PostPosted: 17:37 - 20 Jul 2013    Post subject: Reply with quote
That panel will fook your battery. You need about four amps to put power int that battery and a controller to waste what isnt needed.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 17:39 - 20 Jul 2013    Post subject: Reply with quote
PostPosted: 19:03 - 20 Jul 2013    Post subject: Re: charging 12v battery with solar panel Reply with quote
As above, only useful to keep it topped up.
For about £100 you should be able to get a 100w panel and a controller that'll do the job well enough.
But, of course, it might be better just to take the battery home with you and charger.
mic
PostPosted: 19:11 - 20 Jul 2013    Post subject: Reply with quote
£100 could buy another battery to take with me Laughing
I just worry about my range limitations that's all. Rowing is shit, I found out the hard way Laughing
PostPosted: 19:50 - 20 Jul 2013    Post subject: Re: charging 12v battery with solar panel Reply with quote
85ah - lets say you need to recharge 40amp hours.
Watts = Volts x Amps.
So 40amp hours * 12 volts = 480watt hours.
So on these very basic figures, you'd need a little under 5 hours charging with a 100w panel.
However, that's presuming it's a Sunny day (at least there won't be trees to give you shade).
Also, a cheap charger won't work as effectively as it could - 'intelligent' chargers will vary the output depending on how charged the battery is.
There will be other losses through inefficiencies and the like.
If two batteries will do it (I misunderstood initially) and you can charge them at home, that's probably going to be your best solution.
You can get a 85AH battery new for £56 delivered on ebay.
Note that in reality there is pretty much no difference between most leisure batteries and car batteries.
So if you can find a decent battery from a scrap yard or similar; may be a decent cost effective solution.
Especially if weight's not an issue, you could probably get a nice little 'battery' of batteries. Bit more hassle to get home and charge, however.
Note that if you can get proper 'traction' batteries (used in fork lifts etc), normally 6v or 2v, then they can handle being discharged to much lower levels.
RayGregory
PostPosted: 09:54 - 28 Nov 2013    Post subject: Re: charging 12v battery with solar panel Reply with quote
mic wrote:
Morning
4 watt
peimar solar
thanks
Were you able to find the right way? You seems to be very close to it.. Please share further details.
mic
PostPosted: 10:02 - 28 Nov 2013    Post subject: Re: charging 12v battery with solar panel Reply with quote
[quote="RayGregory"]
Yea. Decided I couldn't be bothered to load the car with all that shit every time I went out so sold it and bought a kayak so only take bare minimum. Is much easier (only take lure and fly rod)
zzr600
mic
zzr600
mic
zzr600
map
Mr Calendar
PostPosted: 11:42 - 28 Nov 2013    Post subject: Reply with quote
FWIW came across this bike cover with pocket for solar panel.
https://www.sealey.co.uk/Images/Products/MCBL.png
The solar panel for this is
https://www.sealey.co.uk/Images/Products/SPP01.png
There's an additional waterproof connector that you can leave connected to bike battery and plug panel in as/when required.
I'm taking a wild guess here and will say the solar panel can be used without the cover if required Wink
From Sealey site.
PostPosted: 12:00 - 28 Nov 2013    Post subject: Reply with quote
I'll recant an earlier recommendation and assert from experience that a panel of that size is essentially useless and won't even stop a battery discharging, let alone keep it topped up. Doubly so in winter, which is when you actually need it.
The last post was made 12 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 103.37 Kb
