Nearly got squished filtering - advice please
shooter
PostPosted: 12:19 - 20 Jul 2013    Post subject: Nearly got squished filtering - advice please Reply with quote
I'm filtering between stationary lanes stopped at traffic lights on the north circular and I go into a pretty tight gap between a large van and a lorry. The lights change and both of them immediately floor it and also pull slightly towards each other. I get squeezed pretty badly and come together with both vehicles. I only stayed on because there wasn't physically any room to fall.
No damage to bike but I think my clutch lever probably scratched the van on my left. Couldn't really stop where we were so I carried on, riding next to the guy, with the intention of speaking to him at the next set of lights. But then about a minute up the road he cut behind me and turned off.
Questions -
Whose fault? I'll probably think better of going down such a tight gap in future, but the guy on my left in particular should have know I was there. I was pretty much stood next to him when he set off.
What's the procedure when you aren't near any safe place to stop? What could/should I have done differently in this regard?
Is it worth contacting the police today (this happened yesterday morning)? If I've scratched the guy's van and it's my fault (not sure it is), I'd like to pay for it. What I don't need though is loads of unnecessary grief off the police and I can't see that they'd actually be able to help in any constructive way.
-Matt-
PostPosted: 12:24 - 20 Jul 2013    Post subject: Reply with quote
I'd say its their fault for not observing before setting off and both having changed road position, but then that could of been a minimal change and it just was bad luck they both slightly changed position at the same time.
If you can see the lights ahead when filtering i always try bare in mind if theyve been red a while and are likely to change soon, start slowing down and looking ahead for places you may need/can stop/slow into.
If you can't see obviously you don't really have a choice but to continue, but with any large vehicles - lorrys, buses, even big vans - and also tall vehicles that are blocking your forward view [and the car in front of thems view of you coming perhaps] i always slow right down whether theyre stopped or not.
Sometimes for example if theres two lorrys/buses side by side its better to just stop and wait. At least if two cars swoop together in a low speed filter you have a chance to bash on them/scream and maybe get noticed, a big long trailer or bus is going to be very hard to alert if they aren't checking mirrors etc and clip you or worse still drag you off and under Shocked
Moo.
PostPosted: 12:26 - 20 Jul 2013    Post subject: Reply with quote
I've always been told not to go up the inside of lorry's or between two lorry/coaches because things like this can happen Sad
A2 Passed 18/6/10
PostPosted: 12:28 - 20 Jul 2013    Post subject: Reply with quote
Your fault. When filtering, don't go between two vehicles that you can't get all the way through - hang back until there's room. You can never assume that they have seen you.
BTTD
PostPosted: 12:36 - 20 Jul 2013    Post subject: Reply with quote
Agreed your fault. If the gaps too tight for you to pin it out of, then don't risk it if the lights might change. If truck wheels catch you, you're going under - there's an unpleasant youtube of exactly that happening.
Sometimes you just gotta wait.
PostPosted: 12:40 - 20 Jul 2013    Post subject: Re: Nearly got squished filtering - advice please Reply with quote
You certainly put yourself in a place of danger and didn't get out - why didn't you accelerate hard away from the lights?
In those situation I always at least stick my nose out at the front, often slightly blocking the vehicle at the front - that way they have to let me go first (or run me over, of course).
That way, as I still generally go on green, it means I don't have to jump the red (and amber) to get a good start.
Remember, if you can't see a lorry driver (mirrors or through the windows), they can't see you. I'll generally the give the bike a few revs when I'm in a position the lorry driver can see me, so they know there's another vehicle there.
Can't think of many bikes that won't beat a van and a lorry away from the lights. Hell, I've beaten vans just fine on my electric push bike (and yes, that sprinter WAS trying to get the holeshot Very Happy).
Have had a case between two large lorries where I've had to really go for it as the lights changed when I was still half way between them.
I'd just leave it. Van driver is unlikely to report it. You'll get yourself a seven day wonder if you do.
shooter
PostPosted: 12:40 - 20 Jul 2013    Post subject: Reply with quote
To clarify - I could get all the way through, I just didn't get all the way through in time. Not sure if that's what you meant or not.
JP7
PostPosted: 12:55 - 20 Jul 2013    Post subject: Reply with quote
It's just not worth trying to squeeze between a van and a lorry in a tight gap. Both vehicles are rather large and can often have restricted rear view, and as others have said it's quite likely that neither of them would have seen you. That doesn't mean to say they shouldn't check their mirrors, and it sounds like neither did, but you put yourself into a really dangerous position.
Bear in mind also that if there was a left turn there, either vehicle would want to swing out to make the turn leaving you very vulnerable indeed.
As far as the law goes you are obliged to stop and exchange details, or report the collision to the police within 24 hours. But it sounds like neither the lorry nor the van knew they'd collided with you, and if you didn't get the registration number of either there's nothing much to gain from reporting it. Perhaps give the cops a call and log an incident just to prove you reported it, should the van driver realise there's been a collision and tries to have it investigated. It depends how much you want to cover your backside really.
If it happens again then try and get alongside the vehicle and motion for them to pull over somewhere so you can let them know what's happened (if they comply!).
Nemo
PostPosted: 13:03 - 20 Jul 2013    Post subject: Reply with quote
Your fault for lacking common sense Thumbs Up
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Mario_Kempes
PostPosted: 16:07 - 20 Jul 2013    Post subject: Reply with quote
You've been a bit daft, mate. You know these guys have reduced visibility. You need to have a bit of awareness when the light is going to change before plunging between any vehicle never mind vans and the like.
No harm done though.
arry
PostPosted: 16:13 - 20 Jul 2013    Post subject: Reply with quote
That's what he meant. If you can't get to the other side before they start moving again, you're putting yourself in a sticky situation. Most drivers will focus their attention forwards when pulling away, and with reduced visibility being a big issue it's not wise to put yourself between two big vehicles.
Chalk it down to experience - could have been worse.
Clanger
Stirrer
PostPosted: 16:19 - 20 Jul 2013    Post subject: Reply with quote
This. I am extremely wary about filtering through these types of gaps. If you think you can get through these types of vehicles, then do it when you know the sequencing of the lights...when you know you have time to get through to the front. Being caught up in the middle of traffic when the lights change isn't ideal, because the drivers are not idling they are watching the car in front and getting ready to move off...not thinking that some biker might be in their blind spot between vehicles.
This is something you will get used to in time...you will be surprised just how much you keep finding out/learning the more you ride... Exclamation
Lyam
PostPosted: 18:58 - 20 Jul 2013    Post subject: Reply with quote
Certainly a situation you shouldn't of put yourself in, however a loud exhaust and a few throttle blips should alert them of your presence, only filter when it's safe l, don't get carried away.
Lyam
PostPosted: 19:11 - 20 Jul 2013    Post subject: Reply with quote
Killer Rat
PostPosted: 19:42 - 20 Jul 2013    Post subject: Reply with quote
This.
If that traffic has been stationary for 30 seconds and you decide to fuck with it, then expect the worst.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
SQL
PostPosted: 19:50 - 20 Jul 2013    Post subject: Reply with quote
your fault for fucking with lorries.
J4mes
PostPosted: 20:32 - 20 Jul 2013    Post subject: Reply with quote
It matters not one shit whose fault it was (yes, yours by the way) when you are under the wheels of a lorry. You've really gotta think this shit through of you wanna survive on a bike.
But I guess you won't be doing it again Thumbs Up
PostPosted: 20:34 - 20 Jul 2013    Post subject: Reply with quote
Every set of traffic lights is meant to be a race. You lost and it was your fault.
What I do if this happens is stop and let them go past, then pull away as the rear of the vehicles come past so as to slot in behind them. The gap where you are stopped is not likely to close much at all because of front wheel steering. If you move forward with them, you can (and did) get squished.
Islander
PostPosted: 20:35 - 20 Jul 2013    Post subject: Reply with quote
You lived to tell the tale and will hopefully learn from it and never ever do it again. Thumbs Up
Your fault BTW.
magpiemale
PostPosted: 22:26 - 20 Jul 2013    Post subject: Reply with quote
I agree with most your fault as when filtering the onus is on us as we are out of position while filtering. While filtering you need to one either see what the lights are doing or the traffic as soon as either changes you need to be in a position of strength like in a gap between cars. If I am filtering most lorries if they can move over even though they do not have to and with one eye on the road ahead and the other watching for a safe position gap for when traffic moves. I have not been on the wrong side of things as yet 7yrs riding also keep speed sensible 20 - 30 map . observation is your friend.
NSR125 1992 (sold) kawasaki Z750S,fazer FZ1 07 now gone present bike 2012 fz1s Fazer,beowulf rad protector,heated grips,sw motech gps holder,power socket.
magpiemale
PostPosted: 22:28 - 20 Jul 2013    Post subject: Reply with quote
Bigmal This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 05:05 - 23 Jul 2013    Post subject: Reply with quote
Bigmal wrote:
I have found van, truck and taxi drivers in London very anti bike. I bet they knew you were there and were just being cunts. Something to do with white working class London attitude that really stinks. I'm an ex white van man (Scottish) by the way.
I have found them to be more indifferent/oblivious to me, in the 20yrs or so of regular commuting into London by bike.
The last post was made 12 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 4.28 - MySQL Queries: 13 - Page Size: 131.61 Kb
