Engine paint?
Tuffers
PostPosted: 13:35 - 19 Jul 2013    Post subject: Engine paint? Reply with quote
I have just put a deposit down on a 98 bandit 600, the engine is a little corroded and could do with being sanded and painted.
When my Haynes manual gets here i will be stripping it down and painting various parts.
How would i go about painting the engine after i have sanded all the corrosion off? Does it need primer or can the engine paint go on directly? Also what is the best quality silver paint i can buy as i don't want it to peel off for at least a good few years.
Suzuki Bandit MK2 '02 - DRZ400s '02 - SV 650S '00 - Bandit 600 MK1 '98 - Honda NXR 125 Bros '04 - Yamaha YBR 125 '12 - Gilera RV 125 '88 - Reiju RS2 Matrix '07
PostPosted: 00:05 - 22 Jul 2013    Post subject: Re: Engine paint? Reply with quote
The colour is hard to find. I got a tin mixed up specially for my '04. I went down the paint shop and went through the swatches until I got the best match. I doubt you could tell the difference if you painted the whole engine.
Tuffers
PostPosted: 02:17 - 23 Jul 2013    Post subject: Reply with quote
Thanks, what make of rattle cans would you recommend? I want the best quality paint i can afford
Efes123
PostPosted: 05:52 - 23 Jul 2013    Post subject: Reply with quote
You've opened a whole can of paint with that question Embarassed
I use Techcote, and have had pretty good results with it, it seems to give a nice deep colour.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
janner_10
PostPosted: 17:31 - 23 Jul 2013    Post subject: Reply with quote
On the Fazer, i used to spray some black BBQ straight on when the engine was warm. Lasted from spring to end of summer. It took about 5 minutes.
You should be able to get some silver chiminea paint and do the same.
Sanding down the whole engine and priming sounds like a long way round to get a similar result.
Tuffers
PostPosted: 01:40 - 24 Jul 2013    Post subject: Reply with quote
I want to sand it down and do everything properly so that when it is finished, it will look like a brand new engine. I will be ordering some paint tomorrow. I didnt know you could get lacquer that could take the heat.
Tbag
PostPosted: 02:47 - 24 Jul 2013    Post subject: Reply with quote
You can get engine lacquers, But a lot go yellow over time.
Are you going to be removing the engine? Cant imagine how decent a spray job could be if a lot of the engine is covered/hidden.
Have you looked into brush painting it? I recently did mine and it looks just as if it was sprayed.
https://i.imgur.com/0nbtEoRl.jpg
https://i.imgur.com/8L1iWVll.jpg
Ripp3rCrust
PostPosted: 09:21 - 24 Jul 2013    Post subject: Reply with quote
Out of curiosity, what product did you use for this? Also, what was the process i.e. wet & dry, coats etc
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
Tbag
PostPosted: 12:15 - 24 Jul 2013    Post subject: Reply with quote
Its Granville engine paint, All i did to prep was clean it. Looks great
mudcow007
PostPosted: 12:25 - 24 Jul 2013    Post subject: Reply with quote
i used that on my CG, the stuff i used was like water so it litrally went for miles
https://i25.photobucket.com/albums/c81/mudcow007/Done_zps13ca7fb2.jpg
Tbag
PostPosted: 12:28 - 24 Jul 2013    Post subject: Reply with quote
Yeah, thats the same stuff, It is like water but somehow covers like any other paint with no transparent bits. Definitely worth a thought.
Ripp3rCrust
PostPosted: 20:21 - 24 Jul 2013    Post subject: Reply with quote
Thanks for the info, unfortunately it doesn't seem to be available in the silver colour of my engine casings. Was hoping to do a lazy repaint of the covers without having to remove them.
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 82.33 Kb
