YBR 125 Idling at 6K RPM and Won't Run Without Choke Open?
tterminus
PostPosted: 07:01 - 21 Jul 2013    Post subject: YBR 125 Idling at 6K RPM and Won't Run Without Choke Open? Reply with quote
Hi all.
Still messing around with my basket case bike. Decided to try and change the oil yesterday, dragged out of the shed and started her up but needed to leave the choke open otherwise the RPM dropped then the engine would cut out.
Also the RPM built-up over time, eventually hitting 6K RPM after 8 minutes of running, this is on idle, no throttle.
So first the inability to run without choke open, is that likely to be the carburetor? If so, considering I'm mechanical of mind with little practise, what would my chances be of servicing it? Any tips or pointers?
Second, what RPM should the engine idle at? Also any pointers where the adjustment is on the engine?
Cheers.
Alpha-9
PostPosted: 08:17 - 21 Jul 2013    Post subject: Reply with quote
Check and clean airfilter and reoil it
Check breathers and pipes are clear
Should idle at like 1600 rpm tops without choke
Fzr-600 1999
Andyk
PostPosted: 09:44 - 22 Jul 2013    Post subject: Reply with quote
my bike did a simlar thing wouldn't idle without choke etc... took it into a local garage for a full service and then checked the valve clearances and re setup the carb and all worked ok. Previous garage had apparently done the carb setup so might be worth checking clearances?
YBR Ric
PostPosted: 10:09 - 22 Jul 2013    Post subject: Reply with quote
If you need choke to richen it up just to get it to run, that would indicate it's far too weak.
On the assumption that the carb internals are still intact,and the carb slide is sitting on the bottom of the venturi, this would usually indicate an air leak.
Check the intake manifold for splits and gaps and wiggle the carb around with the engine running before the revs rise too much and see if things change.
Timmeh
PostPosted: 14:03 - 24 Jul 2013    Post subject: Reply with quote
i bet you 5 ponds the pilot jet is blocked.
YBR Ric
PostPosted: 20:29 - 24 Jul 2013    Post subject: Reply with quote
I'll take mine stocked with Koi Wink
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 56.13 Kb
