A most useful tool
Ariel Badger
PostPosted: 21:30 - 22 Jul 2013    Post subject: A most useful tool Reply with quote
In your bike's tool kit you will have a cross head screwdriver, this will be made on a budget and you should not use it for undoing screws. what you need to buy is one of these that Pete linked up earlier. However do not chuck the one from your kit into the bin, instead cut through it just below the handle and measure the diameter. find a nice bit of mild steel bar ( about 12 to 16 mm) and about 100 mm long and drill a hole the same size as your remaining bit of driver and about 25 mm deep ( you are best doing this in the lathe). Now you need to braze or silver solder the screwdriver into the bar. What you now have is a punch with a cross head that matches your screws, before even trying to undo a screw with your nice new driver you bought via Pete's link locate your punch in the screw and give a sharp tap with a hammer. This will break the bond that has formed between the screw and the case (dissimilar metals, galvanic action etc) and allow easy withdraw of the screw without wrecking the head.
PostPosted: 23:05 - 22 Jul 2013    Post subject: Reply with quote
Petes tool (fnar) isn't going to be much good for undoing the JIS B 1012 screws you'll find all over the shop on many Japanese motorcycles.
Good luck finding a screwdriver that fits them (other than the one in the toolkit) in the UK.
If you see this screw head, you may as well just get the drill out:
https://honda-cb750-s.456789.n3.nabble.com/file/n4035834/jisdimples.jpg
Timmeh
PostPosted: 23:11 - 22 Jul 2013    Post subject: Reply with quote
I have a set of standard philips which I machined down to have a domed profile.
Works a treat, presuming they haven't turned to cheese with age.
PostPosted: 20:18 - 23 Jul 2013    Post subject: Reply with quote
Impact driver for me. The best tool for Japanese engine casing cheese head bolts Thumbs Up
Ed Case
PostPosted: 13:16 - 24 Jul 2013    Post subject: Reply with quote
Couldn't agree more, I wouldn't attempt to strip an old Jap engine without one, and what's more, they're cheap !
map
Mr Calendar
PostPosted: 13:40 - 24 Jul 2013    Post subject: Reply with quote
One of my favourite philips/cross head screwdrivers (because it's head isn't knackered) has a little hole at the top of the handle. Useful for storage but also if you put another bar (usually another screwdriver) through it, apply downward pressure and also use the bar to turn it can be quite effective.
To misquote Archimedes, give me a lever long enough and a fulcrum to put it and I will move the world Wink Very Happy
Quote Me Happy
PostPosted: 14:21 - 24 Jul 2013    Post subject: Reply with quote
map wrote:
To misquote the bird from Luther last night, give me a lever long enough and a fulcrum to put it and I will move the world Wink Very Happy
Very Happy
PostPosted: 18:21 - 24 Jul 2013    Post subject: Reply with quote
What's the significance of the B 1012? Tamiya screwdrivers are JIS standard and the No2 is the most popular size.
PostPosted: 19:02 - 24 Jul 2013    Post subject: Reply with quote
My bad then. I wasn't aware that they sized JIS screwdrivers like that.
The B 1012 is the standard size they usually use on motorcycles, there are others.
The last post was made 13 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 63.86 Kb
