| dolly3900 |
 dolly3900 Traffic Copper
 Posted: 09:31 - 23 Jul 2013 Post subject: Changing Oil, Spring Drops Out?? |
Here is an odd one for you.
Draining the oil on the lad's DR125SM last night and as usual, out comes the drain plug, a stream of oil runs out, but then a spring drops out of the drain hole, into the pan??
OK, I thinks, that is not good.
Stripped down most of the accessable engine and gearbox bits with the unit still in the bike and nothing appears to be out of place, all operated as it should and nothing obviously loose or rattling which would indicate a missing tension giver.
the spring looks like a clutch spring, but all 5 are there on the back of the clutch unit and all there operates fine too.
Any ideas would be most welcome, as it is all back together and running fine, riding well (only up and down the drive), no rattles, no squeaks, just a normally sounding and driving bike.
I am at a loss and Google does not appear to be any help, so over the the Gurus on here to shed some light on the subject.
Mike |
| Ariel Badger |
 Ariel Badger Super Spammer
| Shinigami |
 Shinigami World Chat Champion
| Ariel Badger |
 Posted: 10:12 - 23 Jul 2013 Post subject: |
JFGI ____________________ Bikers make great organ donors, get 115 on your licence today. |
| P.addy |
 P.addy Red Rocket
 Posted: 10:19 - 23 Jul 2013 Post subject: |
What you have probably undone is the "wrong" sump bolt.
There is one on the side, likely to have once had a small mesh filter. There is also a sump plug on the bottom.  |
| misscrabstick |
 misscrabstick Crazy Courier
| Ariel Badger |
| dolly3900 |
| YBR Ric |
 YBR Ric Spanner Monkey
| Pete. |
 Pete. Super Spammer
The last post was made 13 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
