| R1stu |
 R1stu Shrek!
 Posted: 04:47 - 22 Jul 2013 Post subject: Removing seized engine mount bolt. |
Ive been trying unsuccessfully to remove the front engine bolt from the nee 350 engine ive got.
I had to cut the engine from the frame to get it out and I have been left with the engine with the front engine mount bolt still in the engine.
It is just one long piece of threaded rod. No nuts on either end. I have had to dremmle off one side as the engine mount had snapped off. Now Ive been putting wd40 on it for a few days now, and ive used a wire brush to remove as much corrosion as possible.
Ive also tried a blow torch and hammer, as well as two nuts locked against each other.
HELP!!! ____________________ Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished) |
| trevor saxe-coburg-gotha |
| Ariel Badger |
 Ariel Badger Super Spammer
| SQL |
 SQL World Chat Champion
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 15:17 - 22 Jul 2013 Post subject: |
A 50:50 mix of automatic transmission fluid and paraffin makes an excellent penetrating oil.
Hot oil is also good if you can turn it on its side and pour it into the bit you are worried about. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c_dug |
 c_dug Super Spammer
| R1stu |
 R1stu Shrek!
| CG Sam |
 CG Sam Crazy Courier
| Ed Case |
 Ed Case World Chat Champion
The last post was made 13 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
