the yz250 engine
bikersupermot...
PostPosted: 16:28 - 23 Jul 2013    Post subject: the yz250 engine Reply with quote
can the yz250 engine be made ( with a bit of adaptor plate welding and engineering ) to fit into the engine space on the latest wr125x supermoto bikes as the current 4stroke fuel-injection lump is a bit ermm weak lol.
tinybikes
stevo as b4
PostPosted: 22:14 - 23 Jul 2013    Post subject: Reply with quote
Take some measurements of the frame mounting points once you've got the 125cc lump out. Then take your measurements of a YZ250 lump and the where the mounting points are on the crankcases etc.
My reservations with what your suggesting are:
1, The WR125X doesn't seem to have very big frame tubes or look anything like as strong in terms of the frame design as the YZ250 does.
2, The YZ250 will be quite a vibey engine compared to the 125cc unit in your bike.
3, Why not go down the Malossi 182cc conversion kit route instead, as I believe some companies offer 200cc trailbikes using the Malossi kit fitted to the WR125X engine, and if they are reliable enough to be offered as a factory model, then it makes sense to fit the conversion kit instead of trying to swap in a far less suitable engine that probably would not make for a very good bike overall when said and done.
dangerousdave
PostPosted: 04:31 - 24 Jul 2013    Post subject: Re: the yz250 engine Reply with quote
Sounds like its vaugely possible, with enough work and expense.
Those engines don't run too well on the road though, don't like running on less than full-throttle, and want a new piston every 40-50 hours, complete rebuild every 200 hours. If you can live with that then crack on, would certainly make an interesting project.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
PostPosted: 10:28 - 24 Jul 2013    Post subject: Re: the yz250 engine Reply with quote
Remember that I'd expect the WR125 frame will have been made to handle a 4 stroke commuter.
You're sticking in a 2 stroke competition engine of twice the capacity - so a lot more power everywhere.
Were it me, I'd go with a YZ250 frame and componentry - which are better quality and available pretty cheaply these days.
Bodge on the wheels if you want supermoto.
The last post was made 13 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Offroad & Supermoto All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 40.58 Kb
