source for 25mm OD x 15mm ID steel tube
Cigaro
PostPosted: 20:01 - 24 Jul 2013    Post subject: source for 25mm OD x 15mm ID steel tube Reply with quote
Hello,
Where can I get some tubing of the above spec? Only need a very small length (25cm or so).
Cheers.
Turkish
PostPosted: 20:16 - 24 Jul 2013    Post subject: Reply with quote
Possibly useless as it's only 3.25mm instead of 5mm, and it's stainless.
Perhaps the seller can get hold of what you need, though?
ZX-6R G2
CBR125R RW6
Ariel Badger
PostPosted: 20:36 - 24 Jul 2013    Post subject: Reply with quote
What do you need it for?
Nexus Icon
PostPosted: 20:41 - 24 Jul 2013    Post subject: Reply with quote
Can't think I've ever come across steel tube with a wall thickness of 5mm yet only 25mm OD. That's heavier gauge than red banded high pressure piping.
What sort of application demands those sizes cos if you can move a little it'll open up a lot of possibilities.
Greetings from Shitsville!
Cigaro
PostPosted: 20:46 - 24 Jul 2013    Post subject: Reply with quote
It's for making some swingarm spacers for my GSX750. The swingarm has needle bearings in it and steel bushings; the spacers pass through the bushings and bearings and the swingarm pivot shaft goes through the middle.
BanditsHigh
Worse than a woman
PostPosted: 21:05 - 24 Jul 2013    Post subject: Reply with quote
Might be misunderstanding you, but you should only have one spacer which fits between the two bushes ... the spacer is to hold the bushes out to the correct distance while you tighten the swingarm bolt.
Sooo, 5mm wall steel tubing is probably overkill ... 3mm would be more than enough, as would an ally tube (like most spacers these days).
To centre it on the shaft all you'd need to do is slip a bit of 1mm cardboard or plastic into the spacer to hold it in position while you feed the shaft through and tighten it.
Have fun Smile
Cigaro
PostPosted: 21:19 - 24 Jul 2013    Post subject: Reply with quote
Possibly - here is a pic of the bearing/bushings and the pivot shaft:
https://i.imgur.com/zMLGovL.jpg
So the spacer is to 'fill the gap' between the shaft and the bearings/bushings.
Smile
Nexus Icon
PostPosted: 21:39 - 24 Jul 2013    Post subject: Reply with quote
You can get aluminium tube in those sizes but it isn't a common size so you're going to pay. You'll also find it difficult to get anything other than a 5m length from a supplier.
I'd ring around every engineering firm you can and ask if someone has an offcut.
Or just order the actual part. Wink
Ariel Badger
PostPosted: 21:59 - 24 Jul 2013    Post subject: Reply with quote
Can you not bore out some solid to suit? I have seen some seamless hydraulic that was about that size but it was a long lime ago.
Cigaro
PostPosted: 23:55 - 24 Jul 2013    Post subject: Reply with quote
This might be the best option, but I don't have a lathe. Can probably get access to one though.
janner_10
PostPosted: 07:15 - 25 Jul 2013    Post subject: Reply with quote
https://uk.rs-online.com/web/p/steel-rods-bars-tubes-hexagonals/4478924/
We needed some similar spec at work - we brought a length of this and got a local engineer to bore it out - he did it for about £20 IIRC
If you are struggling I maybe able to get him do to another one for you - that said any small engineering firm will be able to do it for a small fee.
The last post was made 13 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 66.62 Kb
