| G |
 G The Voice of Reason
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 14:05 - 24 Jul 2013 Post subject: |
No , the batteries are too heavy for my mountain bike but fire away.
assume you have a switching box to switch source charger circuits in . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| G |
| unitynotsocri... |
 Posted: 21:34 - 24 Jul 2013 Post subject: |
i'd say for small scale solar , like a van /boat/caravan for weekenders , one 100 amp batt with a 5 amp solar charger and small regualtor is enough to power a small inverter , charge phones/laptops and a small tele / stereo .
For bigger power stuff solar is out .....unless you want a superboat /car /bike that needs 3 days charging for a 5 mile 50 mph dash ...
With bigger batteries its important to have matched pairs when raising the voltage . this keeps the charge and load even to prevent plate wear . Keeping a closer charging / discharging cycle helps .
if you have 24 volt , and 4 x 12v batteries then its easier to keep the batteries on a more even cycle .
solar charging is not usually a constant , without a charge controller a lot of power is wasted and the batteries are more unevenly charged . you do need 5 amp really to start charging bigger lead acid batteries . a solar charge controller can keep the voltage and power more stable as the sunshine fluctuates . On dull days they are really good . Panels without controllers are best left to garden lights .
see CPC farnell and Maplins for panels .
it would stress batteries more being charged by different sources so its best matching solar to different compounds .
a modern alternator should ensure that the charging current / waveform aids battery life . If you charged/discharged your batteries extremly with a severe cycle then they would last a few hundred times .....however old or new they are ....if you had a gentle cycle then they could last a thousand times and 15 years if looked after . ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| G |
| G |
 Posted: 23:56 - 24 Jul 2013 Post subject: |
What I'm basically looking for is something to replace a Sterling Alternator to Battery charger (well, apart from doing the funky stuff to make the alternator output more power), for less money - and this way I get to charge my lithium batteries quickly too . |
| G |
 Posted: 00:34 - 26 Jul 2013 Post subject: |
The company I contacted got back to me and the answer is basically 'no'.
However, this, I believe, would solve most of my problems.
https://www.bimblesolar.com/offgrid/inverters/PIP-2424MS
It does MPPT and 3 stage 30a mains charging in one, along with the bonus of a 2.4kw inverter (so power most stuff bar the compressor and welder).
Cheap Chinese box, but sold by a recognised UK company.
Then maybe get an advanced alternator regulator at some point.
(But with 30a charging from mains, the generator will be a much more efficient use of fuel than it is now at least.) |
| sickpup |
 sickpup Old Timer
| G |
 Posted: 10:49 - 26 Jul 2013 Post subject: Re: Balance charger - for PB charging from solar/alternator? |
Cheers, but I was specifically looking to run the balance charger directly from the alternator, which is not possible, it seems.
Running through a fancy charger like that has various benefits - all sorts of monitoring options and can download data to a computer, program it to do exactly what you want and the like.
The FFR alternator probably has a good - at-idle power. Most alternators don't work amazingly efficiently in the way they produce power as far as charging batteries goes. Fine if you're driving a lot as they can produce more than is needed in total, but if you're only running the engine specifically to charge batteries for long periods, more of a problem.
My current one probably doesn't do very well; the advanced alternator regulator or similar would get more out of it and let it charge the batteries faster while still not damaging them (but involves taking it apart I believe and I don't even know it's rating).
I would like a Sterling 24v 140a alternator - they're designed to be good at low rpm:
https://www.sterling-power.com/images/product/page24/graph2.gif
90A at idle; then producing the same power as a household socket with the engine at 1500 rpm. |
The last post was made 12 years, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
