Loose brake disc?
Bike Chat Forums Index -> The Cycling Forum
Fladdem
PostPosted: 11:58 - 25 Jul 2013    Post subject: Loose brake disc? Reply with quote
Hi, currently I'm throwing money at a bike that isn't worth it. I noticed the other day that the front disc is kind of loose. When you stick the front brake on the rim continues to rotate a bit, it's a little bit unnerving, and I don't think the back does it. They are Avid BB5's, in case that makes a difference. I am thinking that it's something to do with moments, i.e. the length of the spokes to the rim act as a lever about the disc as the pivot and the wheels momentum? I don't know though because I don't think the back does it, or if it does it isn't noticeable, and the front does it just at a standstill, just rocking the bike.
Any help would be appreciated,
Adam
KLR600
PostPosted: 21:05 - 25 Jul 2013    Post subject: Reply with quote
Erm, just tighten the disc bolts?
<Take Cool Photos!>
Fladdem
PostPosted: 21:07 - 25 Jul 2013    Post subject: Reply with quote
They are, I forgot to mention that. I don't know what's causing it. I didn't mean loose just wobbly.
PostPosted: 21:14 - 25 Jul 2013    Post subject: Re: Loose brake disc? Reply with quote
Is the hub definitely moving?
It's not unusual for there to be a bit of play in the spokes in such situations.
Fladdem
PostPosted: 18:52 - 28 Jul 2013    Post subject: Reply with quote
I had a look today and I noticed a load of loose spokes, I went round to try and re tension them and the problem seems to have got less, the rim still moves a smidge round but it's more sturdy. It still does it though just not as much. I guess I'll live with it, I have done for ages. I was mostly just wondering if it was a universal thing, if all discs did it or maybe its flexing spokes or something, it still has me puzzled but there seems to be less movement.
KLR600
PostPosted: 01:10 - 30 Jul 2013    Post subject: Reply with quote
It could be any number of things as there's plenty of things on the front end of a bike that could cause a little bit of movement if worn out/loose. If it's bothering you to the point of really wanting to do something about it then I'd set an afternoon aside and go through the front end thoroughly from top to bottom.
Hard to pin it down without seeing it and I suppose it's quite difficult to describe where a small movement could be coming from on the front end.
<Take Cool Photos!>
Fladdem
PostPosted: 11:42 - 31 Jul 2013    Post subject: Reply with quote
I swapped the wheel out with a new wheel I had knocking about in my garage. The wobbling was still there, just less, I think it may be the fork tubes moving in the suspension, that may contribute something to the wobbliness, but I think the original wheel needs examining thoroughly. I'll check everything on it like you say, just work through everything. I can live with it but now that I have noticed it I can't stop noticing. Like when someone points outs that your handlebars are bent before you spotted it and then it's all you can think about.
PostPosted: 11:57 - 31 Jul 2013    Post subject: Reply with quote
I presume the wheel is conventionally spoked with leading and trailing spokes (ie every spoke crosses three other spokes)?.
Radial spoking and a disc brake would cause all manner of problems.
Fladdem
PostPosted: 20:50 - 31 Jul 2013    Post subject: Reply with quote
Yes, normally spoked. I don't disbelieve you but why would radial spoking cause problems? Would the rim continue rotating a lot and bend the spokes or collapse the wheel?
I am not sure, but is there like a rubber grommet or something maybe that goes in the disc, probably not, but I was just wondering if maybe there was a damper that might have rotted, I'm clutching at straws now. I've never had a disc rotor off, never even had disc brakes until a few months go, always used to use rim brakes.
joef
PostPosted: 18:47 - 17 Sep 2013    Post subject: Reply with quote
Are you sure this isn't just the pads moving in the caliper? Get someone else to move it while you have a look. The pads will usually move a small amount with the brake held on.
Fladdem
PostPosted: 20:04 - 17 Sep 2013    Post subject: Reply with quote
Thats a very good suggestion. I shall check it out tomorrow! My bikes are all a bit wrecked, I buy on a whim, always second hand, and can never say no regardless of condition.
The last post was made 12 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Cycling Forum All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 74.28 Kb
