What budget laptop (£200)
drzsta
PostPosted: 20:05 - 25 Jul 2013    Post subject: What budget laptop (£200) Reply with quote
Hi all,
Just after some recommendations.
I currently have a 7 year old laptop which takes an age to boot up so I have decided a new one is order.
I will basically never use it for gaming (ps3 soon to be ps4) so aslong as its got good storage capacity and enough RAM to handle PS CS4 then I'm golden.
Looking to spend around £200 possibly stretch to £300 but the cheaper the better as I won't be using it that much.
Cheers,
Ben.
fatpies
PostPosted: 20:28 - 25 Jul 2013    Post subject: Reply with quote
Send your old lappy to sleep instead of turning it off?
My old Dell from 2003 took 3 minutes to boot from cold. I sent it to sleep and it took 5 seconds to wake up.
doggone
PostPosted: 20:33 - 25 Jul 2013    Post subject: Reply with quote
I thought these looked pretty good if you can organise your own Windows 7 (*cough* Cool )
https://www.ebuyer.com/398944-zoostorm-laptop-7873-9040
gfrancisdev
PostPosted: 20:38 - 25 Jul 2013    Post subject: Reply with quote
eee 901, running lubuntu or similar
best laptop ever, small, 6h battery life, and enough power to do anything a laptop should
if you want gaming, get a desktop (or console if you want)
ybr125(07 silver)-killed 2013/4/3 on some ice
ybr125(06 blue), KE100(89 green-black-puke)
drzsta
PostPosted: 20:39 - 25 Jul 2013    Post subject: Reply with quote
Good point, although ever since I spilt a bottle of tangle foot on the keyboard it has meant using the on-screen jobby which is a bit gash.
karoshi
PostPosted: 11:15 - 26 Jul 2013    Post subject: Reply with quote
Dell Latitude e6400, e6410 or e6500
Mostly get the one with the fastest available processor in budget, however you mention using cs4.. are you linking it to an external large screen or working on the laptop's own screen? if you haven't got an external monitor try to find one with the nVidia graphics card and the higher screen resolution option - standard screens are 1280x800 ish res, the higher spec option will have a 1440x990 res on the 6400/6410 series or a 1920x1080 on the 6500 series (likely to be expensive)
Don't believe any ebay ad that says 4.8Ghz processor, they're misrepresenting the 2.4Ghz dual-core processor because they're idiots or scammers. Highest spec 6400 model will be a 2.8Ghz (ish) core2duo, 6500s have early core i5s
they're pretty easy to upgrade, I ran one for four years that I'd upgraded to 4Gb ram, a WD Caviar Black HDD and windows7 Ulitmate, was prepping to install an SSD drive when it died.
The weak point is the screen, hinges can get worn and sloppy. After a while this can damage the ribbon cable which leads to display issues starting with a dark band appearing on the display.
Only annoyance for me was that they don't have a HDMI output, they have a Dell DisplayPort instead, can use a £10 converter to HDMI but I don't think it'll run sound on the output?
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
charlie74
PostPosted: 12:05 - 26 Jul 2013    Post subject: Reply with quote
https://www.tier1online.com/728-277418g/refurbished-thinkpad-x301-intel-core-2-duo-u9400-1-40ghz-4gb-64gb-dvd-webcam
upgrade the warrenty from 3 months to 12 for not alot extra and still in budget
daemonoid
PostPosted: 12:37 - 26 Jul 2013    Post subject: Reply with quote
Don't bother - all electronic goods sold in Europe have a minimum warranty of 24 months whether the companies state otherwise or not...
current: ducati monster 750
charlie74
PostPosted: 12:51 - 26 Jul 2013    Post subject: Reply with quote
interesting, does that apply to 2nd hand goods or just new?
Dalemac
PostPosted: 13:51 - 26 Jul 2013    Post subject: Reply with quote
Also, under what section of which law? :S
YBR125 -> GPZ500S -> SL1000
daemonoid
PostPosted: 14:01 - 26 Jul 2013    Post subject: Reply with quote
EU directive 1999/44/EC
Section 17 of this... https://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:1999:171:0012:0016:EN:PDF
The UK sale of goods act actually gives you 6 years, but after the first 6 months it is up to you to prove an inherent fault with the product so go with the EU directive as it's easier...
charlie74
PostPosted: 14:21 - 26 Jul 2013    Post subject: Reply with quote
you skipped section 16, which covers 2nd hand goods, they arnt covered, its down to each member state to legislate for that, so i guess back to fit for purpose and what ever warrenty the seller decides to offer, over the standard " fit for purpose" crap and it not being D.O.A etc
CaNsA
PostPosted: 15:09 - 26 Jul 2013    Post subject: Reply with quote
This thread is just full of facepalm.
unless you buy a heavily used, or a knocked off, laptop you are not going to get what you are after.
Get to cash converters and the like.
daemonoid
PostPosted: 16:04 - 26 Jul 2013    Post subject: Reply with quote
I didn't click the link so didn't realise it's a refurb. I'm not sure how that would rank on scale of things... it's not a straight second hand sale as the refurb should make it as new. Perhaps there's already been a test case, but I don't know.
Seb
PostPosted: 18:13 - 26 Jul 2013    Post subject: Reply with quote
Near Plymouth? At the risk of being a spamming muppet, we've got a Dell i7 quad core 2nd gen with 6gb ram, 640gb hdd, dedicated 1gb nVidia GPU and licensed Windows 7 refurbished for a rather tempting £250 with a 3 month warranty. It's ultra cheap for a quad core i7 because it won't shutdown tidily. Let me know if you want more details Thumbs Up
2010 Triumph 1050 Sprint ST
prawny1
PostPosted: 00:07 - 27 Jul 2013    Post subject: Reply with quote
Assuming you have a reasonable cpu (dual core 2Ghz+) Spend £40 on a ssd and maybe another £20 on some extra ram, redo all the thermal paste whilst your at it and call it good.
Battery life will improve with an ssd as you have no platters to spin up.
If you can load a fresh copy of windows rather than the oem bloated restore images you usualy get you will find it will run like a different animal when mated to an ssd.
Even just reloading the o/s or running a repair install without replacing and hardware, would get you back to a sensible boot time
hellkat wrote:
sickpup
Old Timer
PostPosted: 18:16 - 27 Jul 2013    Post subject: Reply with quote
I strongly suggest you go on Ebay and have a look at Lenovo Z570 laptops. They are hitting as low as £250 and are quite excellent.
Scotsman37
PostPosted: 18:00 - 01 Aug 2013    Post subject: Reply with quote
Ok, here's a selection with Buy it NOW option just a bit above your purchase, but you may like them?
Acer Aspire E1-571 15.6" Notebook Intel Core i5-3210M 4GB RAM/500GB HDD Wins 8 @ £256 + free shipping
https://www.ebay.co.uk/itm/Acer-Aspire-E1-571-15-6-Notebook-Intel-Core-i5-3210M-4GB-RAM-500GB-HDD-Wins-8-/190879350193?pt=UK_Computing_Laptops_EH&hash=item2c714bbdb1
https://i.ebayimg.com/t/Acer-Aspire-E1-571-15-6-Notebook-Intel-Core-i5-3210M-4GB-RAM-500GB-HDD-Wins-8-/00/s/NDcxWDQxNw==/z/aWwAAMXQaOVRlPBH/$(KGrHqEOKo4FGTz4GObUBRlPBHS)Qg~~60_12.JPG
Dell E5410 - 4Gb RAM, i5 2.4Ghz processor, 160GB SATA HDD, Windows 7 Professional 32bit Loaded and Licenced with COA @ £249.99 + free shipping
[url]
https://www.grabalaptop.com/windows-7-laptops/dell-e5410/[/url]
Generic pic of the laptop from Dell's website
https://i.dell.com/images/global/products/latit/latit_highlights/latitude-e5410-overview-main.jpg
https://www.dell.com/uk/business/p/latitude-e5410/pd
The last post was made 12 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 103.39 Kb
