Aprilia rs 125 jetting??
gedi1305
PostPosted: 17:39 - 26 Jul 2013    Post subject: Aprilia rs 125 jetting?? Reply with quote
I have a aprilia rs 125 2008
Parts fitted:
Arrow exhaust system
Pipercross panel air filter
28mm standard carb
At the moment its running on a 140 jet but ive been told thats wayy to low.
So if anyone can help that would be great
Thanks
Timmeh
PostPosted: 17:58 - 26 Jul 2013    Post subject: Reply with quote
Kickstart has already given you the answer, you should be using a 180 main jet.
gedi1305
PostPosted: 18:01 - 26 Jul 2013    Post subject: Reply with quote
Ye
But that was just for the arrow system
I was wondering if having a pipercross airfilter you would nee even bigger than a 180
Timmeh
PostPosted: 18:12 - 26 Jul 2013    Post subject: Reply with quote
Fuck knows, there's isn't a magic formula we can apply to get your fuelling right. That's what dyno runs are for.
Buy a bunch of jets starting at 180 going up in 5s to about 220, and a colourtune.
Keep jetting up until the colourtune starts to look right.
Take out for a spin and keep doing plug chops to confirm fuelling state.
Bear in mind that you're only changing the main jet.
If you want to do it properly, book it for a day on the dyno. Which will probably work out cheaper in the long run than you keep replacing pistons.
gedi1305
PostPosted: 18:30 - 26 Jul 2013    Post subject: Reply with quote
Yeah
Got aload of jets on order and booked a dyno for the 7th august
I will let you know how it goes
Thanks
PostPosted: 19:43 - 26 Jul 2013    Post subject: Reply with quote
Start rich and work down. Rich is safer than lean.
Colourtune will be pretty useless for the main jet though. Not sure I would want my head close enough to a glass spark plug to see through it when using full throttle.
The last post was made 13 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 47.68 Kb
