RS 125 (Rotax 122) CDI faulty?
andy_uk
PostPosted: 18:12 - 25 Jul 2013    Post subject: RS 125 (Rotax 122) CDI faulty? Reply with quote
Having just fitted new crank bearings etc after a lovely seize up...I now think my CDI is on its way out Confused
It was running fine for the first week after the rebuild but today it started playing silly buggers...
The bike starts fine, but after a few minutes if I go over 3k revs it either dies completely or misses one hell of a lot.
I have an electronic rev counter which takes its signal from the input side of the coil and when it starts missing the rev counter reads around 250rpm (even though the engine is obviously doing a lot more than that while still coasting...). I can hear it firing approx 4 times per second with the throttle wide open (which tallies with the rev counter reading).
If I let it drop back down to tickover (or let it stall & restart the engine) it's fine again until the dreaded 3K revs is reached.
Presumably I can rule out the coil (for the reason stated above regarding where the rev counter is connected to).
I've checked cable routing etc as well as the connector(s) between the pickup and CDI, no amount of 'cable wiggling' appears to make any difference.
So...
Does this sound like a classic "fooked CDI" or should I check anything else?
uberkron
PostPosted: 21:30 - 25 Jul 2013    Post subject: Reply with quote
check your stator/cdi windings. Before condemning the module. Had a weird coil/cdi issue on my zip where it would limit at about 3.5k but coil and cdi are integrated in my case but what you describe could well be your coil failing and shorting the cdi output.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
andy_uk
PostPosted: 01:05 - 27 Jul 2013    Post subject: Reply with quote
My multimeter has a frequency counter on it so I should be able to check the flywheel pickup...
I also have another coil (not the right one, but it may suffice for testing purposes...hopefully!)
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 36.25 Kb
