| fireyphoenix1... |
 fireyphoenix1... Brolly Dolly
| Bezzer |
 Bezzer World Chat Champion
| fireyphoenix1... |
| Pete. |
 Pete. Super Spammer
 Posted: 18:43 - 26 Jul 2013 Post subject: |
Sometimes the problem is with the spanner that's turning the nut.
In this case I believe it's more about the nut that's turning the spanner  ____________________ a.k.a 'Geri'
| fireyphoenix1... |
| Pete. |
 Pete. Super Spammer
 Posted: 03:33 - 27 Jul 2013 Post subject: |
I guess I wasn't being very charitable, should have at least said well done for persevering, and getting there in the end. Many people would have thrown in the towel long ago.
I'll try to redeem myself by offering some constructive comments.
The reason your bolt twisted up is because you used a very poor grade bolt as a packer. If you had used a socket cap (allen key head) it would likely not have bent up. Better still would have been to use something with the proper thread and bottom that out in the hole, then pop in a ball bearing to press against.
You should not have needed threadlock on that fine thread bolt. Minimum holding torque should be way lower than 92lbs/ft. Better hope you never have cause to remove it.
You say that you roughed up the crank - not the taper I hope? Self-holding tapers such as on that crank and flywheel are supposed to be ground to a fine finish, then fitted up perfectly clean and dry for maximum hold. Roughing it up will have reduced the holding capacity, though it might still be fine in use. At least the bolt isn't coming out.
I bet those fine thread taps weren't cheap. last one I bought that size was £27, though it's pretty good quality. ____________________ a.k.a 'Geri'
| fireyphoenix1... |
The last post was made 13 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
