Why no back brake?
Snorty
PostPosted: 15:29 - 28 Jul 2013    Post subject: Why no back brake? Reply with quote
So I'm going to get a new back tyre put on today, on the way up the road I go to use a little back brake, no resistance in the pedal at all...
I took the pressure off immediately thinking of some sort of fluid leak...
Get there (after reaching triple digits) to see my caliper is no longer on the disc... held on by the torque arm only and the two bolts completely missing.
Wut? Do caliper bolts tend to vibrate loose? I know they were tightened up well when the rear pads were changed...
PostPosted: 15:32 - 28 Jul 2013    Post subject: Reply with quote
No, they don't usually vibrate loose, especially being probably fine thread bolts in cast alloy. They were either not tight enough or too tight and pulled the threads.
Snorty
PostPosted: 15:36 - 28 Jul 2013    Post subject: Reply with quote
The threads were fine, I put some new ones in. Maybe somebody is trying to kill me.
Snorty
PostPosted: 15:41 - 28 Jul 2013    Post subject: Reply with quote
In any case it shattered my pads to bits, lucky it was still attached to the torque arm or that could have been ugly.
-Matt-
PostPosted: 15:49 - 28 Jul 2013    Post subject: Reply with quote
I didn't go down this route myself as i was using a torque wrench and was worried it might actually cause more problems, but a friend of mine tightens by hand [perhaps not wise with 'critical' bolts i dont know Laughing ] and i know he uses a small dab of medium loctite on the bolts to keep them secure.
Snorty
PostPosted: 15:54 - 28 Jul 2013    Post subject: Reply with quote
I'm a bit suspicious to be honest.
-Matt-
PostPosted: 15:55 - 28 Jul 2013    Post subject: Reply with quote
Row with the mrs Thinking Question
Snorty
PostPosted: 15:59 - 28 Jul 2013    Post subject: Reply with quote
Hah, no Mrs to have a row with.
Perhaps it was just loose but to be honest the last time it was interfered with (by me) was around 700 miles ago. I'd have thought if it were loose I'd have noticed before now, or it'd have happened before now, which makes me wonder if somebody has tampered with it.
There are easier ways to do it I suppose. Cutting the brake lines would make more sense.
Snorty
PostPosted: 16:14 - 28 Jul 2013    Post subject: Reply with quote
Would've been worse to do the front brakes, I'd have flown out of my driveway and straight into the wall opposite ha.
-Matt-
PostPosted: 16:17 - 28 Jul 2013    Post subject: Reply with quote
Did you torque them up out of interest or just 'very tight' by hand.
Vincents paint on the bolt idea sounds good as a precaution Thumbs Up
Snorty
PostPosted: 16:27 - 28 Jul 2013    Post subject: Reply with quote
Yeah my friend also suggested this. Did them by hand. No torque.
-Matt-
PostPosted: 16:47 - 28 Jul 2013    Post subject: Reply with quote
I'd start there as a first step when you get them back on, but definately go for the paint as a precaution just in case some lunatics out to get you Confused
Having only used a torque wrench on mine it made me realise [maybe not as important as it seems i dont know] but how far off i probably would of been in terms of the torque had i done it by hand.
Even if you don't torque the entire bike by the book, perhaps at least worth it on the few real critical bits that are likely to fuck you over if they do come loose like with the brake Thumbs Down
PostPosted: 17:17 - 28 Jul 2013    Post subject: Reply with quote
Maybe the tyre fitter loosened them to make getting the wheel off easier, and then forgot to tighten them?
nathan k
PostPosted: 17:23 - 28 Jul 2013    Post subject: Reply with quote
Well atleast who ever is trying to kill you is not very good at it, who only does the rear brake these days? Laughing
Acemastr
PostPosted: 17:27 - 28 Jul 2013    Post subject: Reply with quote
I'd have gone about 6 months before realising this Very Happy
2016 Toyota Tacoma Limited
BTTD
PostPosted: 18:57 - 28 Jul 2013    Post subject: Reply with quote
I'm under the impression that loctite threadlock breaks down with heat - and brakes get pretty hot.
Any other opinions (or preferably knowledgeable guidance) on this? Confused
barrkel
PostPosted: 19:21 - 28 Jul 2013    Post subject: Reply with quote
This is the most likely cause IMO.
I've had tyre fitters forget to tighten one of the two swingarm bolts on my GF's SH300 - the exhaust, swingarm and brake caliper all need to be taken off on the RHS to remove the rear wheel. And another tyre fitter put the front tyre on backwards on my VFR.
PostPosted: 20:26 - 28 Jul 2013    Post subject: Reply with quote
400 degrees celcius. Your hangers aren't ever going to approach that.
instigator
PostPosted: 20:37 - 28 Jul 2013    Post subject: Reply with quote
The russians.
Islander
PostPosted: 20:41 - 28 Jul 2013    Post subject: Reply with quote
This sounds like a likely scenario.
-Matt-
PostPosted: 21:36 - 28 Jul 2013    Post subject: Reply with quote
If i read and understood OPs first post didnt this happen before reaching the tyre fitter Confused
I wasnt endorsing the loctite option by the way just something i know a mate does,do at your own risk til someone can verify Thumbs Up
PostPosted: 22:18 - 28 Jul 2013    Post subject: Reply with quote
I actually cannot believe that nobody suggested that until I did TBH.
The last post was made 12 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 131.42 Kb
