Pesky Energy Saving Bulbs
angryjonny
PostPosted: 19:44 - 29 Jul 2013    Post subject: Pesky Energy Saving Bulbs Reply with quote
Right so I've just bought a new house and the outside light at the front has one of those 4-pin energy saving fittings in it. The bulb is too bright and I want to swap it for a dimmer one. Here's where the fun starts. I bought a smaller bulb and, spot the obvious problem:
https://img.photobucket.com/albums/v404/angryjonny/bulbs_zps4dd72131.jpg
New bulb on the left, old bulb on the right. The plastic teeth on the side are in different places on each bulb. There are gaps in the holder for the teeth to slot into. The old bulb fits, the new one doesn't.
Is there a reason why they've done this? Is it unsafe to fit a 10w bulb where there was an 18w one? Or can I just file the teeth off the new bulb and shove it in there?
Karma for sensible answers, ta.
I've done a quick Google but I don't really know how to ask the question in a few words.
Sako
PostPosted: 19:54 - 29 Jul 2013    Post subject: Reply with quote
Just stick a candle in it.
Marmalade
PostPosted: 20:03 - 29 Jul 2013    Post subject: Reply with quote
File off the tabs so it'll fit in.
10w in place of a 18 will be fine.
angryjonny
PostPosted: 20:05 - 29 Jul 2013    Post subject: Reply with quote
Ta. Thought so. Just seems an odd thing to do - like they really don't want me using any other bulb.
Suntan Sid
PostPosted: 21:03 - 29 Jul 2013    Post subject: Reply with quote
Done this in the past, it works, no probs! Thumbs Up
swampy
PostPosted: 21:14 - 29 Jul 2013    Post subject: Reply with quote
Cut the fitting off, replace by standard bayonet fitting, use whatever bulb you like, profit ??
angryjonny
PostPosted: 21:26 - 29 Jul 2013    Post subject: Reply with quote
It isn't so much a light fitting as much as bulb holder inside a daylight-sensing lantern unit, so it'd mean chucking the whole lantern. Anyway. I've filed the tabs off the bulb now so when I get a chance I'll plug it in and away we go.
I still don't get why they make them like this though. Needlessly contrary.
Marmalade
PostPosted: 21:32 - 29 Jul 2013    Post subject: Reply with quote
It'll all be down to electrical safety bullshit, since we all know you are likely to be killed changing to different wattage bulbs.
Plus the retard factor of the populace, if it won't fit then they can go back and change it for the item the should have bought.
benyboy
PostPosted: 22:00 - 29 Jul 2013    Post subject: Reply with quote
hi im a sparky, yeah there is a reason for this, without going into it too much, the light fitting is for ie 18w and no more no less.
like said in the previous post, remove lamp holder and replace with what ever you want, 230V mind.
Get out of the way, you dithering fool
Marmalade
PostPosted: 22:10 - 29 Jul 2013    Post subject: Reply with quote
what reason would you give for not putting a 10w in there?
angryjonny
PostPosted: 22:42 - 29 Jul 2013    Post subject: Reply with quote
Feel free to go into it as much as you like. I'm here to learn, that's why I started the thread. What happens if I fudge a 10w bulb into an 18w holder? I can understand the dangers of adding watts, but taking them away...? Bayonet and screw fittings will take anything from 8 to 150w.
groovylee
PostPosted: 22:45 - 29 Jul 2013    Post subject: Reply with quote
Won't cause you any problems at all dude
Past - 1988 honda revere 600, 1996 kawasaki gpz500s, 1999 Yamaha R6
Current - 2002 Aprilia RSV1000R & 1999 Kawasaki ZX6R
Lord Percy
PostPosted: 03:54 - 30 Jul 2013    Post subject: Reply with quote
Looks like you have two different brands of bulb, possibly the manufacturers are trying to monopolise somehow?
This 10W version also has the off-centre notches, as do the 13W, 18W and 26W versions, so with those you could mix and match as you please.
So my Internet-educated guess says you can probably file off those notches as it's just the manufacturers being dicks Thumbs Up
drzsta
PostPosted: 06:56 - 30 Jul 2013    Post subject: Reply with quote
Gx24q-1 on the left and gx24q-2 on the right.
You could file them down but easiest thing would be to buy the correct lamp in the first place. Wink
Bases are specific to wattages btw so SA your wrong IMO.
PostPosted: 08:26 - 30 Jul 2013    Post subject: Reply with quote
Paint the bulb white. It'll glow, but be much dimmer.
Lord Percy
PostPosted: 08:54 - 30 Jul 2013    Post subject: Reply with quote
Oh yeah, my bad.
Looked closer at the link I put in my last post, turns out the 10W and 13W versions have q-1 bases, and the 18W and 26W versions have q-2 bases, which would separate the wattages as you say.
Presumably it's only to stop you from going too high of a voltage, rather than too low, so yeah I guess everyone suggesting filing it down is ok in this instance.
However, to satisfy my own curiosity... What's wrong with stepping the wattage up? Isn't the bulb just a component in a bog standard main ring house circuit? As long as it doesn't exceed the 230V supply, what's the big drama?
Crazy-Duck
PostPosted: 09:39 - 30 Jul 2013    Post subject: Reply with quote
I had a similar problem a few weeks ago.
We rent our house so can't really go round changing light fittings. The bulb at the top of the stairs went, I thought it was just a bog standard energy saving one so went to change it and it was a bulb by a specialist manufacturer with 3 metal prongs on the base instead of 2. The only place I could find one cost me £9.95! I hope it last a few years for that amount!
angryjonny
PostPosted: 09:42 - 30 Jul 2013    Post subject: Reply with quote
Well that's kind of my original question. Why, exactly do they do this? It's irritating enough that I can't buy standard incandescent bulbs any more (no, energy saving bulbs are not "just as good" and the halogen ones are harsh) but to be restricted to a particular wattage based on the bulb holder seems needlessly restrictive.
So I've filed the teeth off. Fight the machine, Jon!
As for suggestions to change the holder; well I could but it's part of an outside lamp unit that came bolted to the house when I bought it, brand new. To replace the whole lamp would be pretty wasteful when I already have a bulb that almost fits it and a Stanley knife. If there are no real-world risks associated with fettling the bulb (and I've yet to hear a good reason why they're manufactured this way) then that's what I'll do.
angryjonny
PostPosted: 09:45 - 30 Jul 2013    Post subject: Reply with quote
I could paint it red and toy with the new neighbours a bit, I suppose.
angryjonny
PostPosted: 09:50 - 30 Jul 2013    Post subject: Reply with quote
I'm yet to find a shop that stocks more than a cursory nod in the general direction of these stupid fittings. Seems like it's just designed to catch people out.
"Oh yes, the bulb you've bought is a px79q8ddx000.11 which means it only operates between 3am and 5am when there's an R in the month".
fatjames
PostPosted: 10:28 - 30 Jul 2013    Post subject: Reply with quote
Maybe these bulbs originate from somewhere where the wattage is an important factor? Maybe, and this is a guess, in a caravan or on a boat or something?
Andyk
PostPosted: 10:54 - 30 Jul 2013    Post subject: Reply with quote
for the geeky and possible reason it could be that either its a progression from where maximum wattage was an issue or as the wattage is a product of the current draw vs voltage it could be used as a form of resistance and as such needed to keep the system running "correctly", which could mean you need to adjust sensitivity or something equally.
However personally i would sack it hack the thing up make sure there's no bare metal and use it, just don't blame me if it goes bang.
drzsta
PostPosted: 11:15 - 30 Jul 2013    Post subject: Reply with quote
There is nothing wrong with stepping the wattage up as long as the fitting is rated for it.
I think you are getting confused with voltage and current, the voltage won't exceed 240v but as the wattage goes up so will current draw.
Lights are either fed from a 6amp MCB or 5amp fuse wire. Outside light could be off the house ring but fused Down to 3amps at the switch fused spur.
The only limiting factor is what the manufacturer has rated there fitting at and the max switching capacity of the PIR.
PostPosted: 11:23 - 30 Jul 2013    Post subject: Reply with quote
All bulbs in my house are now halogen capsules. They are all standard bayonet cap unless totaly unavoidable by reasons of space in the fitting.
I have rooted out and destroyed all examples of fluorescent tube fucktardery and non-standardised fittings.
I do have a couple of LED strips in cupboards.
map
Mr Calendar
PostPosted: 12:02 - 30 Jul 2013    Post subject: Reply with quote
stinkwheel wrote:
All bulbs in my house are now halogen capsules. ...
Ditto replacing the 'energy saving' fluorescent type where we actually need more light. Still have the fluorescent type where it isn't so critical, up-lighters in bedroom and the like.
IIRC the halogen ones are a tad more watts than the fluorescent type but still way lower than the filament bulbs of yesteryear. The light is actually white as well, which helps. Very Happy
The last post was made 13 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 132.06 Kb
