CBR 125 Won't start
Gingerbreeze
PostPosted: 13:16 - 31 Jul 2013    Post subject: CBR 125 Won't start Reply with quote
Hey guys.
I brought my cbr about 2 weeks ago and up till now it's been fine, but yesterday it was raining pretty hard and i was on my way home in it. i mounted the pavement and i had the clutch in ready to roll it along into my place and it cut out.. Now it wont start.It makes the turning over noise but it just wont kick in, the battery is full and i have tested it but i'm like brand new to bikes so i don't know where to start :/ Any suggestions ? if you think i should clean or do something to a part can you give me a lil tutorial as to where it is and how to get to it
Thanks
POW !!
Efes123
PostPosted: 13:20 - 31 Jul 2013    Post subject: Reply with quote
This would be better in The Workshop section, but;
How have you checked the battery?
Have you got a spark?
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
Gingerbreeze
PostPosted: 13:23 - 31 Jul 2013    Post subject: Reply with quote
i have a reader that you put on each terminal and it showed a decent 12.5 V reading, and how should i check it properly ? just pull the cable off, take the plug out and lick the end ? lol
POW !!
Gingerbreeze
PostPosted: 13:29 - 31 Jul 2013    Post subject: Reply with quote
If i took the plug out and connected the cable again would that create a spark when i hit the starter ?
POW !!
PostPosted: 13:38 - 31 Jul 2013    Post subject: Reply with quote
Not heard of a CBR having issues in the rain...
Under the tank however is a plethora of cables which should be covered, lazy people don't refit the cover.
Worth probably checking the colour of the spark plug, connecting the lead to it and grounding the plug against the frame then pressing the starter to check for a spark.
Efes123
PostPosted: 13:43 - 31 Jul 2013    Post subject: Reply with quote
Laughing No, sorry using a multimeter is the right way, it's never clear on how techy a person is on here, so I tend to start at a real noobie level. We almost got someone (Jivebunny) to do exactly what you joked, but some bugger went and told him the truth Evil or Very Mad
Try as Paddy suggests, ground the spark plug (not on your tongue), press the starter, and check for a spark.
Gingerbreeze
PostPosted: 14:16 - 31 Jul 2013    Post subject: Reply with quote
Ok guys good news, I've put the battery back in and when i hold he starter it's still not kicking in unless i open the throttle fully and then hold it, it takes about 2-3 seconds then it starts and then flys up to high revs. Once i slowly reduce throttle the revs slow down, and if i close the throttle fully it shuts off again :/ ??
POW !!
jeddy11
PostPosted: 14:35 - 31 Jul 2013    Post subject: Reply with quote
Fueling issue ? have you got enough fuel or have you run it empty at some point ? water in the tank etc etc..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
Gingerbreeze
PostPosted: 14:38 - 31 Jul 2013    Post subject: Reply with quote
there is plenty of petrol in there and what do you mean water in the tank ? water in the fuel tank ? the rain wasn't that bad!!! lol
POW !!
jeddy11
PostPosted: 14:46 - 31 Jul 2013    Post subject: Reply with quote
Lol its not been that heavy but some people leave there bikes out in all weathers and after time you get condensation and shite going on..
Fuel pump and fuel feed lines / filters blocked sounds like the engine isbeing starved of fuel hence only really going when you give it a load of throttle and and stalling etc im taking it as fuel injection and not carbs..
Fuelly My Z1000SX
Gingerbreeze
PostPosted: 14:51 - 31 Jul 2013    Post subject: Reply with quote
I have the 04 model, the 07+ have fuel injection, mine is carb
POW !!
UnspeedySam
PostPosted: 14:53 - 31 Jul 2013    Post subject: Reply with quote
Is it a carburettor or fuel injection cbr? Sounds like a blocked up carb to me. Could also be other crap stuck in the fuel system, do you have a fuel filter on the bike, if so change it!
edit: Just saw your latest post. Might be a pilot jet blocked up then...
Efes123
PostPosted: 14:54 - 31 Jul 2013    Post subject: Reply with quote
I'd say the rain is just a red herring. It certainly sounds like a fuel supply/mixture issue. First try squirting something combustible around the air intake/carb air box collars. If nothing, then check the carbs themselves, floats, jets etc.
That's twice today I've offered exactly the same advice Shocked
PostPosted: 16:13 - 31 Jul 2013    Post subject: Reply with quote
Drain the carb float bowl into a clear glass bottle.
See if you have 2 liquids in there, should separate if its fuel and water.
PostPosted: 17:14 - 31 Jul 2013    Post subject: Reply with quote
Wouldn't be the first CBR125 to get a blocked idle jet, they do seem (on experience and anecdote) to be prone to it.
While you're investigating it, I'd suggest spending a few £££ on fitting a filter into your fuel line.
Gingerbreeze
PostPosted: 14:40 - 01 Aug 2013    Post subject: Reply with quote
Ok so i had to go to work yesterday and couldn't check the jets. I drained the carb and it was pure petrol no water and it's starting abit easier and I can get it to turn over and stay running with about 50% choke but it stays at 500-1k revs and cuts out if I adjust the choke or throttle. Does this help locate the problem or should I still check the jets ( of which I don't know how Sad )
POW !!
PostPosted: 14:51 - 01 Aug 2013    Post subject: Reply with quote
No guarantees, but those symptoms sound like workmate's CBR that had a clogged idle jet.
Sorry, no how-to from me, he revved it into a Honda dealer and got mugged for it.
UnspeedySam
PostPosted: 15:07 - 01 Aug 2013    Post subject: Reply with quote
Idle jets are about £3. If removing the old one and blowing through it doesn't unblock it, just buy a new one.
PostPosted: 15:12 - 01 Aug 2013    Post subject: Reply with quote
Take carb off.
Fine an old piece of wire, strip the outer coating and get a few strands of the wire and remove the idle jet, all of them 1 by one if you feel, poke the wire through the hole in the jet and give it a nice wiggle and spray with carb cleaner/wd40 or equivalent.
Gingerbreeze
PostPosted: 03:33 - 02 Aug 2013    Post subject: Reply with quote
Thanks guys,,
Got it working. I oppened up the carb and looked into the jet and BINGO it was clogged, cleaned it out and put it all back and it's running like clock work Smile Thanks guys, you helpped out a newbie and in the process i learnt quiet abit about my bike Smile
POW !!
PostPosted: 08:32 - 02 Aug 2013    Post subject: Reply with quote
Nice one, great job on diving in and sorting it out. Thumbs Up
As noted, they do seem particularly prone to it. I would definitely recommend throwing a fuel filter in there.
UnspeedySam
PostPosted: 08:47 - 02 Aug 2013    Post subject: Reply with quote
What he said ^ or if you've got one, replace it...it clearly isn't doing its job anymore. You'll need to find out what size fuel line your bike uses though (internal diameter). Here is a 6mm one: https://www.ebay.co.uk/itm/MOTORCYCLE-MOTORBIKE-6mm-ROUND-FUEL-FILTER-UNIVERSAL-/320451996874?pt=UK_Motorcycle_Parts&hash=item4a9c6d6cca
The last post was made 13 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 114.1 Kb
