Few riding questions
Blitz_
PostPosted: 15:37 - 09 Dec 2004    Post subject: Few riding questions Reply with quote
May be i should have asked that question in New Bikers forum, but then thought that if i get replies from people like me it wont help me much. So the question is for experienced riders. Generally.
Ok, i've got NSR125RR (2-stroke). Very Happy
1. When i see the red light quite far ahead and i go around 50mph, is it right that i just press clutch and shift straight from gear i'm in (5th or 6th) down to neutral, and then keep on rolling and brake in the end?
2. Is it right that i generally use my front brake? Most of the time. When i'm supposed to use my rear one?
3. When i stop, which leg i should put down? Cause my instructor (not the CBT guy, the private instructor) told me to put down the right one, so i dont waste time to get into 1st gear off the cross lights?
4. Should i stop in neutral? Or should i hold clutch and be in first gear at crosslights?
I think this is it. Just if have any other advice about gear changing, clutch holding and shifting down, tell me. Cause i think i ride well enough and yeasterday got a bit confused when met AD from this forum and he 've been riding totally different from what i'm used to.
Thanks for help guys,
Ana
8316
PostPosted: 15:39 - 09 Dec 2004    Post subject: Reply with quote
everything seems fine, bar the 1st gear at the lights. snick it into neutral. it doesnt damage your bike like that. you seem ok to me! Very Happy
Now own a Fireblade!! Speed Limits? Bah!
nc30 chick
PostPosted: 15:43 - 09 Dec 2004    Post subject: Reply with quote
Well I only know the way i was taught and that was good enough for me.
You dont have complete control of the bike then, stay in gear till you stop, going down the gears as you slow down. As you are about to come to a stop then put it into 1st.
Your front brake is the most effective, however if its wet then you use both brakes. I was taught to use around 80% front brake and 20% back brake in normal conditions, 50/50 in the wet.
You should put your left foot down so the rear brake is covered at all times, you should already have sorted out your gears.
You should be in first gear ready to go!
Hope this helps
Very Happy
dainesefreak
It's usually left foot down and right for applying the rear brake for the "Safety Position".
Front brake is ok really, although CBT/Instructors generally say 75% front, 25% rear and about 50 - 50 in the wet. I'm not sure whether that's something a DSA instructor would look for in a test though.
Rob W
PostPosted: 15:44 - 09 Dec 2004    Post subject: Reply with quote
When braking it's best to apply the front brake slightly before the rear, to aviod too much dive and even out the braking, and I'd recommend sticking it in neutral when your at the lights or whatever, I always do. I pretty much always put my right foot down, leave my left sat under the gear lever in case traffic starts moving.
Other than that you seem OK Thumbs Up.
Marc_Buck
PostPosted: 15:45 - 09 Dec 2004    Post subject: Reply with quote
I think instructors tell you to have left foot down at lights, so you can have right foot on brake.
I keep it in 1st at lights with my clutch in, but if i am to be there a while i go to neutral, so i can have a stretch etc.
Generally i ride how i feel comfortable, i know on my test i will have to adjust to their riding styles, so i should start to get into the habit.
94 fzr600r
PostPosted: 15:45 - 09 Dec 2004    Post subject: Re: Few riding questions Reply with quote
Remember, a bikes gearbox is quite different from a car and its not wise to go down lots of gears at a time. Its wise to go down one at a time and come to a gradual stop, stick it into neutral and then wait the stationary position. (Sounds dirty Laughing )
The rest sounds OK though. Only I was tought to wait with my left foot down and right foot on the rear brake, not put my right foot down while stationary. (Obviously everyone has different styles and techniques)
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
Villers
PostPosted: 15:46 - 09 Dec 2004    Post subject: Reply with quote
Hi!
Im not an expert but ive been riding about a year now so its not long since I was in the same position as you!
If the lights are a good stretch away it may be best to go down the gears somewhat, but not all the way to first. On my old RS125 If i was in 6th doing 50 towards ared light I would prob drop the box as far as third or second then coast to the line with the clutch in and the bike in 1st. This way if the lights change as you approach you are in a better position to roll on the throttle.
Most braking is done on the front brake, but remember that as your braking you are loading the front which can cause a possible slip in the wet. On damp/wet or greasy roads try feathering the back brake slightly and use the two progressively. If leaned over on a bend and you want to shave of a few mph's use the rear as its possible the front will sit you up! Obviously using the back brake for slower manouvers is better as you have full throttle control and the bike wont nosedive on braking!
I think the guys talking out of his @rse on that one. For my test I was taught that if stationary it was neccessary to cover the back brake in case anything hit you from behind or if you started rolling or something. Basically as a handbrake is in a car. On a 125 I wouldnt bother fighting it into neutral for a short wait at the lights, if you have your left foot down, your right on the brake and your clutch pulled in your ready to go. Once past the test though use your feet as you see fit, if you are turning right on a junction and feel more comfortable leaning the bike right ready for take off, do it!
hope this helps!
Blitz_
PostPosted: 15:55 - 09 Dec 2004    Post subject: Reply with quote
Thnks guys/girls Smile
Thats a pity - i've just got used to ride the way i do and now it is wrong way =(( Now have to get used to put my left foot down, keep the first gear, and steadily slow down...
Ohhh... Rolling Eyes
Marc_Buck
PostPosted: 15:57 - 09 Dec 2004    Post subject: Reply with quote
I would not go to 1st from doing 50 eg, unless holding the clutch in.
94 fzr600r
mchaggis
PostPosted: 15:59 - 09 Dec 2004    Post subject: Reply with quote
As far as braking goes, do whatever you feel comfortable with. At the moment anyway, I'm tending to use the front brake hardly at all, unless I need to stop. I use engine braking, changing gears and the rear brake to shave off a little speed if letting off the throttle won't get enough.
If I were on a faster bike and wasn't concerned with just keeping my average speed up and riding smoothly, but riding quickly and stopping suddenly, then perhaps I'd use my front brake more.
I must not be a troll...
Mmmm, Guinness
nc30 chick
PostPosted: 16:00 - 09 Dec 2004    Post subject: Reply with quote
I go down to first when im almost stopped (if 1 went to 1st at 50 it would most likely blow up my baby!), if i see a red light ahead I slow down and go down 1 gear at a time.
binge
Emo Kiddy
PostPosted: 16:01 - 09 Dec 2004    Post subject: Reply with quote
When I took my CBT they told me to have left foot on the ground so if another bike or a car comes too close, your right leg is on the bike and out of the way Confused
I see alot if bikers stop at lights, Sort gears out, left foot down and then right foot up ready to go...
<|Binge|>
PostPosted: 16:06 - 09 Dec 2004    Post subject: Re: Few riding questions Reply with quote
Just to go over it one more time:
No. When you see the light, close the throttle, change down through the gearbox as you slow down to always be in a gear which suits your speed. Brake as you come up to the lights and pull in the clutch just before you come to a halt, then change into neutral if necessary (see below) or first.
You should not coast on a motorbike (ie ride along with the clutch pulled in) ever.
The front brake does most of the work on a modern bike, use the back brake along with it to steady the bike. Use the back brake by itself at low speeds or on loose surfaces, it is all too easy to give it too much front which will have you off. You will also fail your test if you use the front brake when doing low speed manouvers such as u-turns.
I was always taught to put my left leg down and hold on the back brake with my right which allows a controlled getaway. To me it is a good habit to get into, especially if you get shunted from behind at some lights. Nevertheless, listen to your instructor as he will know what you need to do to pass your test.
Depends how long you can be bothered holding the clutch in for. If you think you will be stopped for a long time, flick it into neutral and save your wrists. Try to anticipate when the lights are going to change so you can be in first and ready to go when they do.
Dan 4RR
PostPosted: 16:30 - 09 Dec 2004    Post subject: Reply with quote
When I took my CBT test the instructor told us that if you need to stop at some traffic lights, etc that you should put your left leg down because for example if for some reason your leg just suddenly gave way or your foot slipped then you would fall away from the traffic and hopefully fall towards the kerb or footpath.
jamie192
PostPosted: 16:49 - 09 Dec 2004    Post subject: Reply with quote
I would go from experiance as i have only been riding 2 weeks but my cbt instructor answered em all these questions and i remember all his responses.
For this, you can do that no harm in it (from my own experience i find that if i switch right down then the lights change i have ot change back up before setting off or engine breaking almost throwns me over the handle bars)
Use what ever break you like they say you should use 75% front and 25% back but i use my front normally.
Right, here at the lights you should be in first gear holding in the clutch with your back break on so you dont roll, you should have your left foot down on the road ( reason is if a car decides to over take they will do so on the right and if your right legs sticking out its gonna get hit if its tight) u keep the bike in first and hold in the clutch with your back break on.
You will find with some bikes because of bikes gearboxes you cannot always change into neutral easily, sit at the lights in first same thing less hassle and means you dont have to change to set off and saves your right leg.
Ride Fast, Brake hard, don't fall off!
Rob W
PostPosted: 16:54 - 09 Dec 2004    Post subject: Reply with quote
I agree with haggis to be honest, I only ever really use my front to stop, and it'll be my back if I need to scrub off speed or just let the throttle off a touch as that usually suffices. I'm not a big fan of using my front to lose some speed while cornering, really unsettles my bike, so I avoid that at all costs and just dab the back.
PostPosted: 17:16 - 09 Dec 2004    Post subject: Reply with quote
One last time:
DO NOT COAST ON YOUR MOTORBIKE!
Dangerous, not in control, fail your test etc.
Tut Tut Brick Wall
Villers
PostPosted: 17:21 - 09 Dec 2004    Post subject: Reply with quote
whys everyone repeating each other?
If your engine breaking throws you over the handlebars then surely you are down changing at the wrong time?
Rob W
PostPosted: 18:08 - 09 Dec 2004    Post subject: Reply with quote
Precisely, listen to your engine...
Blitz_
PostPosted: 18:28 - 09 Dec 2004    Post subject: Reply with quote
Just went to bank in the city and then went for a small ride to try what you all said. Its fine with being in first gear at the traffic jam or at crosslites - much easier to start and stop.
However i didnt like that when you hold the damn clutch, it is impossible to reach out for the indicator switch... Hm Confused How do you sort that out?
Going down through gears is a bit sloooooow... I try not to rush through them now, but can i just switch them down to 2nd in a row holding the clutch and stedily breaking? Cause then its almost the same as release clutch after each change - my speed anyways goes down as it is needed. Question
Left foot down make me feel a bit weird. Cause then if i wannachange to neutral, i have to put my right foot down, and then change. Feels stupid jusmping on the bike like that...
Just the last questions - why cannot i stand at the crosslights and use my frontbrake? And why i have no control over bike when its in neutral? I can always slip into gear and speed up or break? Rolling Eyes
Bendy
Mrs Sensible
PostPosted: 18:37 - 09 Dec 2004    Post subject: Reply with quote
Not as stupid as putting your foot down onto something slippy and wiping out into the car sitting next to you. Wink
I just hold the clutch in at most lights. If they're taking a long time to change, a little shuffle to get into neutral is usually accompanied by stretching and tank bongos anyway so it's not really a hassle.
mchaggis
PostPosted: 18:38 - 09 Dec 2004    Post subject: Reply with quote
Known as the Hendon shuffle, as the technique police riders are/ were apparently taught at the academy. The idea is to always have something on the brakes. Ideally you have your foot brake on as if you get punted up the arse, your hand will tend to lose grip of the front brake.
Something else with this is being able to scratch your arse, wipe your visor, twiddle your mirrors, warm your hands on the engine etc etc. If I'm sat at junctions for a long time, I knock it into neutral, put my foot on the brake, take my hands off the bars and relax. You also need to have your foot on the brake for hillstarts.
You can use the front, just it's a matter of what you have control over if you're hit. You have no far less control over the vehicle when it's in neutral, because the only resistance to your motion is the rolling resistance, drag and the gradient, which can speed you up.
The bike will go as fast as it wants to, all you can do is apply the brakes (you're then just on a big weight with wheels). With drive engaged, the bike won't go any faster or any slower than the engine can. Added to that, the engine can be controlled easily with the throttle, so it can force the wheels to turn more slowly just as well as more slowly.
Mmmm, Guinness
Fortuna
PostPosted: 18:44 - 09 Dec 2004    Post subject: Reply with quote
Regarding the leg question thingy.
Remember you can actually put either foot down to stop safely as long as your right foot is then used to cover the brake straight away.
What happens if you stop on a gradient sloping to the right? You'd fall off if you always had to use your left foot on the floor.
r1_lad
PostPosted: 18:50 - 09 Dec 2004    Post subject: Reply with quote
To be honest I was told in my CBT to always put my left foot down but I put down whichever is most comfortable especially if there is a gradient in the road. I'm always covering the front brake anyway so it's not an issue.
I also very rarely put it into neutral at traffic lights, only because I don't mind holding the clutch in at lights and it means I don't have to mess around changing gears before pulling away.
RS50 -> RS125 -> GSXR600 SRAD -> 02 R1 -> Speed Triple 1050 -> Ducati Streetfighter 1099 -> DRZ400 Superetard
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 138.87 Kb
