Now about GPU - I WON!
RhynoCZ
PostPosted: 16:37 - 05 Aug 2013    Post subject: Now about GPU - I WON! Reply with quote
Hello, today I over clocked my old Q6600 (OEM cooler), I clocked it up to 2.8GHz, we've got here 33°C+ outside so I did not want to over-do it. Anyway, at factory settings 2.4GHz the CPU/SYSTEM(chipset) temp was about 54°C/46°C at idle with fan running around 1950rpm, right now I run the CPU at 2.8GHz, CPU voltage 1.28, at 49°C/46°C and the fan goes also at 1950rpm, at idle. Tried some games and in many of those the temps were even lower when OC'ed, not all games profits from 2.8GHz, but many of them do. RAM is also a bit over clocked, everything else is stock.
How is it possible, that the temps are lower when OC'ed and is it possible I ruined something? Thinking
Thank you
Seb
PostPosted: 18:30 - 05 Aug 2013    Post subject: Reply with quote
Adding voltage will always mean more heat, it's likely a background process soiled your factory settings run.
2010 Triumph 1050 Sprint ST
RhynoCZ
PostPosted: 07:53 - 06 Aug 2013    Post subject: Reply with quote
I see, I'm gonna check that, thanks Thumbs Up
PostPosted: 10:16 - 06 Aug 2013    Post subject: Reply with quote
I had my q6600 at 3.8ghz, but I settled on 3.6 for safety, even water it wouldn't go above 60 under load I believe. Thumbs Up
RhynoCZ
PostPosted: 11:18 - 06 Aug 2013    Post subject: Reply with quote
I run it at 350x8, what did you set as multiplier and what's the difference between different multiplier numbers?
I use boxed cooler, I'm cheap and this is the last thing I wanted to try before I'm gonna have to spend some money on new hardware.
I was thinking of a new CPU cooler, there's one that people recommend, it's called: ,,Gelid Solution Tranquillo'', costs about 20 pounds, is it worth it and I don't mean the money.
https://www.eteknix.com/wp-content/uploads/vb/1429-Gelid%20Tranquillo%20Rev.%202%20accessories%20and%20mounting.jpg
RhynoCZ
PostPosted: 11:25 - 06 Aug 2013    Post subject: Reply with quote
Another question, you say lower voltage means lower temp, do you happen to know what is the lowest voltage a Q6600 on Asus P5K/EPU can handle? It seems to me like witchcraft. Smile
Seb
PostPosted: 18:38 - 06 Aug 2013    Post subject: Reply with quote
Stock is 1.20, I vaguely remember some of the later variants going down to 1.18? Not gospel though, whilst I had one, I never bothered overclocking it as I had a silent setup at the time.
Shinigami
PostPosted: 19:11 - 06 Aug 2013    Post subject: Reply with quote
my q6600 is running at 3.4, can't remember at what voltage and can't remember temps as I set it up aaaages ago and it was fine then and running stable as anything since.
anywho i have this cooler on mine
https://www.amazon.co.uk/computers-accessories/dp/B0068OI7T8
RhynoCZ
PostPosted: 13:23 - 07 Aug 2013    Post subject: Reply with quote
Alright, I'm gonna try to reduce the voltage, what is the worst case scenario here?
PostPosted: 13:26 - 07 Aug 2013    Post subject: Reply with quote
It won;t beable to run at speed cause the voltage ain't there.
RhynoCZ
PostPosted: 10:01 - 09 Aug 2013    Post subject: Reply with quote
I understand, while we're at it, I've got another question. I think my GPU HD6790 is loosing it, there's still no way I can run catalyst control center, not even in linux and the driver restarts quite often + when I move or scroll a window, in win.desktop, it leaves there marks, like when you've got no drivers in the system at all.
When I tried TechPowerUp GPU-Z, just to see if it runs, it said openCL error, uninstaled openCL and the GPU-Z worked. According to sensors everything seems to be alright, the temp is a bit high, but that'd normal in this weather.
What do you think and how can I get the catalyst control center to work? Games work, sort of, some of them restart the driver Mad
prawny1
PostPosted: 18:47 - 15 Aug 2013    Post subject: Reply with quote
If your motherboard supports it the 1333fsb bsel mod will give you 3Ghz, that way your motherboard will select all its timings and stuff to be optimal rather than having the chipset, ram and what not overclocked too so things generally are a bit more stable.
Most of the time they will run like that at stock volts but if you have to add a little it is not the end of the world, overclock limits and instability are not always due to the cpu, it can be thanks to other components reaching their limits.
Are your gpu issues due to the overclock or was it like that all the time?
hellkat wrote:
RhynoCZ
PostPosted: 14:44 - 16 Aug 2013    Post subject: Reply with quote
Well, according to ASUS it handles: FSB (HT, QPI) 1600/1333/1066/800 MHz
The GPU problem was there before I OC'd the CPU. One day I updated the Catalyst control center and I had no CCC since then + what I've mentioned earlier. I tried nearly anything to get the CCC working and there was no success. The last thing would be format C:\, which I'm not gonna try, at the moment.
I do not want to invest any more money into this PC, I'd rather build a new one.
Right now, I run the CPU/FSB at 2.8Ghz/1403Mhz and DRAM 438Mhz (400Mhz standard).
prawny1
PostPosted: 20:04 - 16 Aug 2013    Post subject: Reply with quote
I would try for a clean install of the graphics card drivers.
First: download driver sweeper from guru3d https://www.guru3d.com/content_page/guru3d_driver_sweeper.html
Second: go to add remove programs and uninstall the ccc program/manager etc.
Third: go to device manager and uninstall the hardware
Forth: reboot into safe mode windows will prompt to install drivers for the card just cancel it all.
Fifth: run driver sweeper and delete all ati drivers (I boot into safe mode twice and run driver sweeper again to be sure)
sixth: boot back into windows and cancel all prompts to install drivers again (you can run a registry cleaner now too if you want to get rid of any obsolete registry data) then rerun your desired ccc/driver package.
You should now have a clean graphics driver install with no conflicting old drivers.
RhynoCZ
PostPosted: 10:10 - 19 Aug 2013    Post subject: Reply with quote
I'm gonna look into that, thank you prawny1 Thumbs Up
prawny1
PostPosted: 21:04 - 19 Aug 2013    Post subject: Reply with quote
Another thing you can do if to keep your drivers uncluttered is add a new environmental variable to the registry to show non connected device drivers in device manager.
To do it you need to go to advanced system setting and add this environmental variable to system settings.
devmgr_show_nonpresent_devices
Variable=1
Now when you reboot and check the show hidden devices option in device manager it should show all the devices ever connected to the pc,
Those not currently connected will be greyed out so they are easy to identify, it is an excellent way to fix usb related issues, or to clean old monitor drivers and stuff.
RhynoCZ
PostPosted: 18:12 - 20 Jan 2014    Post subject: Reply with quote
So, today I did the first solution to fix the CCC, and it's still the same. It lets me to instal the AMD package but the instalation ends with a yellow question mark. I click to see the log about problems and there's nothing there. The CCC still does not work and games don't work either. It says I've got to update my GPU driver, well I CAN'T!. Mad
And, I'm too stupid to do the other solution. Thumbs Down
EDIT: When I try to check the version of drivers, it says everything is up to date. Confused
RhynoCZ
PostPosted: 20:54 - 10 Feb 2014    Post subject: Reply with quote
Good news, the CCC finaly works. Well, I had to go format c:\.
Anyway, I'm stuck on 11.4 version and can not update it eventhough it tells me to update it. I get quite bad gaming performance on DX11, where I used to have 60fps I get around 25fps. DX9 seems to work alright. The OS is fresh instal, still the vista 64bit. Everything in the OS is up to date.
Is it possible that ATi does not want me to update the CCC/driver or that the GPU is faulty, somehow? Confused
lihp
PostPosted: 21:36 - 10 Feb 2014    Post subject: Reply with quote
Just build a new system, with recent OS, 7 or 8.1, you're going to struggle a lot with 6 year old hardware these days.
RhynoCZ
PostPosted: 14:48 - 13 Feb 2014    Post subject: Reply with quote
Just out of my curiosity I tried the driver sweeper in fresh instal of the OS and then went straight to sapphire site to get ''their'' driver and ccc and it works now. It's still slow, as a 6 year old PC should be, but it works, DX11 is back in business. Thumbs Up
EDIT: I still can not believe it, I was about to go to get some new HW. Smile
EDIT 2: PSU is still not perfect, gonna try to fit there a new fan. Thumbs Up
PostPosted: 17:27 - 13 Feb 2014    Post subject: Reply with quote
CCC being a cunt? Laughing You must be new to computers. Razz
RhynoCZ
PostPosted: 21:51 - 13 Feb 2014    Post subject: Reply with quote
I admit, since I got into motorcycling, I've lost the track of new stuff, meaning no spare money = no new toys. I started with bikes 5 years ago which means, in real life, I missed like 20 years in PC world. Laughing
The last post was made 12 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 120.98 Kb
