| Shreeve |
 Shreeve Scooby Slapper
 Posted: 09:50 - 10 Aug 2013 Post subject: General Q's |
New rider here, passed my CBT mid July and bought a 2011 CBF 125 immediately.
Clocked up 300 miles so far, riding most days after work and on the weekends, just locally at the moment as i tend to get lost quite easily
Just a few questions that have occured to me over the last few weeks:
1) I was in 5th gear and just got up to 60mph, all of a sudden the bike seemed to lose a bit of power and went down to 50mph despite no movement in throttle, no increase in incline or headwind. It has only happened once, apart from that the bike runs smoothly. Any ideas why?
2) When you apply ACF50 do you just spray it straight onto the bike and take no mercy? I went back to it after an hour to find a big pool of the stuff settled underneath the bike (that stuff just doesn't want to budge).
3) Is it possible to adjust the rear brake lever? It doesn't have the traditional lock nut that you just screw. It has a nut at the back of the connecting rod (no idea what it's called) that adjusts the slack of the pedal and that's it. Any ideas? (have searched for the answer to this to no avail)
4) What the hell do you do with the build up of chain lube in the chain guard? just get the thick of it out and degrease it with something? What do you use? Just cleaned/lubed the chain today and i swear shit was growing in it...
5) Generally, do you just use warm soapy water to clean fairings and general muck off the bike?
I think that's it, had the bike for less than a month and already wanting a bigger one (Triumph Street Triple), this 'hobby' is clearly a bottomless pit for the old bank balance
Great fun so far though! Cheers. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4 |
| deadwolf |
 deadwolf Could Be A Chat Bot
 Posted: 10:18 - 10 Aug 2013 Post subject: |
I'm by no means an expert but here's my thoughts:
1) Ran low on fuel? Did you try downshifting?
2) Can't say, not used it myself yet.
3) Don't know.
4) I used SDOC100, it's expensive but pretty effective. Unscrew and remove chain guard before applying so that it gets to all the crap on the underside.
5) Warm soapy water's fine. I used cold water, fine as well. The important bit is drying the bike off properly with chamois/etc to prevent unsightly marks left by the water. If you want showroom quality finish, you'll need to start looking into polish/wax and the whole shebang. ____________________ Motorsapien Art |
| c_dug |
 c_dug Super Spammer
| -Matt- |
 -Matt- World Chat Champion
 Posted: 12:58 - 10 Aug 2013 Post subject: |
1] Maybe you just hit a bump in the road or something if it was just the one off I'd think 60 is up near if not on the top speed of the bike so wouldn't take much for it to drop off, just a guess though - if it started happening more regularly maybe its a fueling issue
2] Sounds like you put a bit too much on - ACF goes a long way, i do tend to spray mine from the can but don't go wild with it, you can also spray a load into a rag and give it a wipe on, especially good for getting it in and around nooks and corners.
3] Not sure on this one in the case of your bike sorry
4] I remove the guard and use an old large flat-head screw driver [don't use it anymore] to scrape it all off, then some degreaser on the last bit. I wouldn't bother trying to get it sparkling clean though it'll be mucked up again in 5 minutes
5] I use muc-off bike cleaning range, theres plenty of other brands, some a bit cheaper but muc-off are very good from my own experience and quite a few others. I'd be cautious using soaps/car shampoos many have additives and chemicals added that aren't good for a lot of bike fairings and finishes. They won't melt and break the bike by any means, but if you want to keep it looking pristine they're not a good idea. Especially if you have anything powdercoated/aftermarket painted etc.
HTH  |
| Shreeve |
 Posted: 13:23 - 10 Aug 2013 Post subject: |
Cheers for the responses chaps!
Gonna run the bike down to a local bike shop and ask them about the rear brake lever. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
| lukamon |
 lukamon World Chat Champion
| Shreeve |
 Posted: 14:15 - 10 Aug 2013 Post subject: |
Yeh that's the one that adjusts the slack, the problem is i'm 6"2 and when it's adjusted to the most extreme point (no slack in the lever) it's still uncomfortable  ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
| metalangel |
 metalangel World Chat Champion
| Shreeve |
 Posted: 15:09 - 10 Aug 2013 Post subject: |
Above, the instructor from my CBT stressed to always be covering the brakes and it planted a bit of a seed. ____________________ Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
| metalangel |
 Posted: 15:19 - 10 Aug 2013 Post subject: |
Don't do that. Once I was out on the road doing lessons, with the same instructor as my CBT, I was told not to. I had tried to make it a habit myself, and the result was as my muscles got tired holding my foot just above the pedal (bigger bike, but I'm the same height as you) it would imperceptibly drift down and start to apply the rear brake.
When we stopped for a break, the instructor observed that I'd been braking for the last several miles. I responded that the bike hadn't been performing any differently, so he conceded it might have just been enough to make the light come on.
Regardless, all you're going to do is wear your brakes out and maybe overheat them for when you really need them.
Just rest your foot on the peg, point it out to the side and there is a position you'll find that it rests comfortably sort of against the side of the pedal. Getting your foot back onto the pedal when you need to brake is extremely quick, don't worry about it. ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
| Shreeve |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| FiBob |
 FiBob Nova Slayer
| Baffler186 |
 Baffler186 World Chat Champion
| Ribenapigeon |
 Ribenapigeon Super Spammer
 Posted: 22:02 - 18 Aug 2013 Post subject: |
I just spray ACF50 into the cap then use a paintbrush to dab it onto vulnerable areas, then I treat the bike with it  |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 22:22 - 18 Aug 2013 Post subject: |
Don't worry about getting lost. This is how you will learn your way around.
When I was 16 I just rode, miles and miles and then found my way home eventually. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| CG Sam |
 CG Sam Crazy Courier
The last post was made 13 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
