| Jonathan A |
 Jonathan A Crazy Courier
 Posted: 21:53 - 14 Aug 2013 Post subject: Had to do my first ever manly thing. |
My Hyosung GT650R did not start earlier on, so I jump started it from my mums car...and it worked (got the terminals wrong at first though )
I'm guessing it needs a new battery...so can anyone recommend a good one?
Cheers  |
| CG Sam |
 CG Sam Crazy Courier
 Posted: 22:02 - 14 Aug 2013 Post subject: |
Congratulations on the man stuff! Can't remember the first thing I did. May have been learning to weld. Or fixing a fence etc.
Not sure on what the best new battery for it would be, but it's not meant to be good to jumpstart bikes from cars, but don't think once will hurt! Get a trickle charger when you get a new battery, few quid but always useful  ____________________ CG125, SV650S, CBR600F, GSXR600 SRAD |
| misscrabstick |
 misscrabstick Crazy Courier
| Jonathan A |
 Posted: 22:14 - 14 Aug 2013 Post subject: |
well the car worked fine after...still we live and learn  |
| G |
 G The Voice of Reason
 Posted: 22:16 - 14 Aug 2013 Post subject: |
If the car engine isn't running, can't see any reason it would be 'bad'.
But a man would have at least tried to bump start it first .
Check the bike is charging and so on before replacing the battery.
If you're planning to sell the bike in the next couple of years and keep it in good nick generally - the cheapest you can find!
And yes - seen ECUs and the like easily blown from reversing polarity - in some cases writing the car off!
Would presume it's more likely the bike to be damaged than the car, at least - as it was the one with the dead battery, rather than the much larger fully charged battery.
| Jonathan A |
| Jonathan A |
| G |
| Jonathan A |
 Posted: 22:28 - 14 Aug 2013 Post subject: |
I'm not sure if I could manage that without something awful happening On 125s I allays just hobbyhorsed them allong |
| G |
| Jonathan A |
| Boxing |
 Boxing World Chat Champion
 Posted: 22:55 - 14 Aug 2013 Post subject: |
Bump starting is easy. What I do is I get it rolling, hop on the seat give it a couple of pushes with my legs once I'm at say my running speed whilst sat down, I pull the clutch in put it in first, stand on the pegs and then drop my backside on the seat and let the clutch out at the same time.
Easy once you've done it the first time.
I also live in Leicester, which is full of hills, which comes in handy.  |
| G |
| stevo as b4 |
 Posted: 23:07 - 14 Aug 2013 Post subject: |
At least you didn't try to bumpstart a Ducati 996, as that is usually a massive fail for most human species!  |
| Yoyo |
 Yoyo Brolly Dolly
| Jonathan A |
 Posted: 06:20 - 15 Aug 2013 Post subject: |
It's a 2007. It hasn't got a sidestand switch  |
| uberkron |
 uberkron Crazy Courier
 Posted: 07:37 - 15 Aug 2013 Post subject: |
Jump-starting is easy if you follow one simple rule:
Put the red lead from battery plus to battery plus before you do anything else. ____________________ a.k.a 'Geri'
| G |
| Jonathan A |
| P.addy |
 P.addy Red Rocket
 Posted: 11:55 - 15 Aug 2013 Post subject: |
Yes...  |
| G |
| map |
 map Mr Calendar
| Jonathan A |
| Jonathan A |
The last post was made 13 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
