Kawasaki ZZR600 - Cooling Fan Probs..
bikecruiser.co.uk
PostPosted: 18:45 - 10 Dec 2004    Post subject: Kawasaki ZZR600 - Cooling Fan Probs.. Reply with quote
Hello again guys.
Right. On a toy run last week, my cooling fan failed to operate and resulted in a nice load of liquid coming out of my expansion chamber..... Nice! Razz
So, I get the bike home and test the fan.. It works fine, so I'm now thinking "Find the temp switch" -- Easier said than done. I've found the plug that the fan connects to, but then the wires disappear above the engine under the tank :S Any ideas where the temperature switch is, because i cant seem to find it on the radiator..
Thanks in advance..
Dave
www.BikeCruiser.co.uk
Git
PostPosted: 19:04 - 10 Dec 2004    Post subject: Reply with quote
It could be on the thermostat housing under the tank or very nearby.
The small sensor will be for the temp guage if you have one and the larger switch may very well be for the fan.
Good hunting Cool
Guest
PostPosted: 19:08 - 10 Dec 2004    Post subject: Reply with quote
Part no. 21176 on the stat cover?
https://www.buykawasaki.com/scripts/ImgServ.exe/convert?ilFN=e:\epcimages\I10\I1044\E3032.TIF&ilIF=P&ilSC=25&ilIV=0&ilBR=0
mr.z
PostPosted: 19:10 - 10 Dec 2004    Post subject: Reply with quote
Probably off the thermostat, though can't say for sure... will be a tank off job...
- actually not the thermostat, its on the front of the rad...
Item 27010
edit: guest- bah beat me to it! that one is the temp sensor, could well be that too...
Here
Depends on the year though i'd supose... this is the 2001 i think? should be on that site somewhere anyways...
good luck Wink
Guest
PostPosted: 19:11 - 10 Dec 2004    Post subject: Reply with quote
Did you test the actual fan switch - 27010 - or just put a supply to the fan?
Git
PostPosted: 19:14 - 10 Dec 2004    Post subject: Reply with quote
How helpful was that then, even got a picture Thumbs Up
Looking at that I will go with 27010 like above.
Guest
PostPosted: 19:17 - 10 Dec 2004    Post subject: Reply with quote
Yep, whip that out (you'll lose your coolant of course) and play a fag lighter across the back - that should start the fan I reckon.
PostPosted: 02:58 - 11 Dec 2004    Post subject: Reply with quote
A lot of people just bypass the fan switch and connect the fan to a flick switch so they can turn it on manually when the temperature creeps up.
bikecruiser.co.uk
PostPosted: 04:00 - 11 Dec 2004    Post subject: Reply with quote
I just put a supply to the fan to check that was working fine..
This is a 1991 model matey.
Lol, well, before i even started looking, i decided to fit a switch anyway to power anything it needs too... Cooling fan now by the luks of it.. Razz
Thanks for everyones help. u people r great!
Dave
The last post was made 21 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 60.99 Kb
