| stevelup |
 stevelup Renault 5 Driver
| XanderZZR |
 XanderZZR Borekit Bruiser
 Posted: 14:01 - 16 Aug 2013 Post subject: |
Congratulations on passing nice choice of bike as well.
I recommend the muc off bike products for cleaning, brings up a lovely shine (miracle shine for after the wash is brilliant).
I was my chain weekly and ride daily, keeps it nice and lubed, depends on how many miles you do and I. What weather... Have a check before you ride for slack and lube, it's a good practice to get into.
I would highly recommend acf50, will keep the corrosion away. |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
 Posted: 14:21 - 16 Aug 2013 Post subject: |
Congrats - you've done well there. As for #2, you can't really keep the chain too clean - a chain that's pampered will make gear changes much smoother and improve performance significantly against a bike with a neglected one. I personally have no time whatsoever for the waxy, spray type lubricants that come in aerosol form - though they are commonly used and have many advocates. But, afaic, the main benefit of such products is their anti-fling properties - i.e. the lack of splatter and mess they create. However, a thick gear oil like 80W90 is *far* superior - and much cheaper too. It's thick enough to remain on the chain, and won't get flung onto the wall of your rear tyre. You might find some slight residue of it on the swing arm etc. - but for the added benefits it brings this is negligible.
Clean the chain as often as you can - together with regular lubrication with thick oil, this will prolong its life considerably - and that of both sprockets too, of course. It will, e.g., help to avoid the development of seized links, which make for uneven tension along its length, creating e.g. an inch of play in one area and three or four somewhere else. Total pita.
Everyone has their preferred method of chain cleaning, but a little diesel on one of those three-sided chain brushes is as good a place to start as any. Finish off by wiping the excess diesel and crud off with a clean rag, then squirt some of the aforementioned heavy gear oil on. Just one pass of the chain will do, especially if you're undertaking this regularly. Fwiw I do it once every day or so.
ACF-50 - yeah, if you're going to commute and / or be out in the wet a lot. Otherwise, fuck it. No need. ____________________ "Life is a sexually transmitted disease and the mortality rate is one hundred percent."
Mobylette Type 50 ---> Raleigh Grifter ---> Neval Minsk 125 |
| stevelup |
| Enaver |
 Enaver Renault 5 Driver
| bikertomm |
 bikertomm World Chat Champion
 Posted: 16:12 - 16 Aug 2013 Post subject: |
Congrats!
For cleaning yeah you will want a decent shampoo, avoid using washing up liquid and the likes.
For cleaning and sorting out the chain this video is pretty good, if not a bit too in-depth
https://www.youtube.com/watch?v=zb1isb3yCAQ
It's worth noting an awful lot of people think all you need to do is spray on lube and think that's job done, it's important to clean the chain first with WD40 or whatever then apply lubricant
Unsure if your beemer will have a centre stand or not but if not a rear paddock stand may be of some use for jobs like this!
I usually do the chain every 4-500 miles.
As for ACF-50 I personally have no experience but I hear it's very good if you use the bike all year.
Enjoy  ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| stevelup |
 Posted: 16:23 - 16 Aug 2013 Post subject: |
I'm weighing up whether or not to fit a centre stand. I've got the part numbers for the bits I need... They come to less than £100, so I think it's probably worth doing.
I'll be a fair weather rider - no intention of riding in grotty weather... except yesterday because I didn't have the willpower to resist having one little go on it...
So now it's one day old and completely filthy  |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 16:59 - 16 Aug 2013 Post subject: |
Nice one
1) Washing - I'd use muc off or autoglym bike stuff, good range of stuff. Muc off brush set is worth its weight in gold i've found also.
2) Chain - every couple of hundred miles should be fine in normal conditions, if in the wet/winter etc then more often. Put it up on a stand/centre stand and spin the wheel giving it a good spray with chain cleaner [muc off again is fine]. Best to do this after a ride as it encourages the shite to come off once its warmed up a bit. Rub it down with a clothe until it looks clean. Then again go for short ride to warm up, come back and spray lube/wax/oil whatever you prefer onto the inner links while spinning the wheels. No need to drown it just an even liberal spraying. I personally use wurth dry chain wax as its clear and if it does flick doesn't leave speckles all over the wheels.
3) ACF-50 - If in the wet regularly and especially in the wet in winter definately - it goes a long way so don't go wild with it, putting it on a clothe and giving it a good wipe into the nooks and crannies will help. A good coating on lots of areas will last the whole of winter in some cases so you can just wash the layer of shit thats sat on top of it off at the start of spring. Some parts may need it more often though. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:12 - 16 Aug 2013 Post subject: |
Nicely done.
If that's the same Rotax twin as in the F800/700/650GS then keep a careful eye on the powder coating on the sump and at all the leading edges, it does seem prone to flaking. ____________________ Biking is 1/20th as dangerous as horse riding.
| Mark 37 |
 Mark 37 Trackday Trickster
 Posted: 17:17 - 16 Aug 2013 Post subject: |
Congratulations, well done.
If your tight like me (don't think you are from your OP) warm water & fairy liquid every couple of runs (except in winter after every run). T-Cut 2-3 times a year. Turtle wax every second or third wash.
Petrol out the tank with a chain brush every 200-250 miles lubed up with what you prefer. I'm using Holts chain lube just now. That's what the shop had at the time.
AC-50 every fourth or fifth wash, every second wash in winter.
As you can see with the responses it's whatever works for you but I'm quite anal about having a nice shiny bike.
Mark ____________________ No matter how fast light travels, darkness was always their first. |
| kevin_cambs_uk |
 kevin_cambs_uk Nova Slayer
The last post was made 12 years, 198 days ago. Instead of replying here, would creating a new thread be more useful? |
