Derbi gpr 50 redlines at idle... need help
dragonslayer6...
PostPosted: 21:03 - 16 Aug 2013    Post subject: Derbi gpr 50 redlines at idle... need help Reply with quote
Ok, so I recently bought a 2000 derbi gpr 50. Everything on the bike right now is the way I bought it. The bike would idle at about 5k when I got it, and it should have been about 1,900. After running it the first time, I noticed the carb leaks. So I took apart the carb and cleaned the gunk from the float so it wouldn't stick. I put it back together and now it wants to redline right after starting the bike. I usually shut the bike off at around 9-10k rpm, but it will keep trying to go higher.
Additional info: I have pulled the air filter and I can see the slide is positioned correctly, so it is not the slide or the throttle cable. I can see that when I twist the throttle, the slide lifts and closes properly. I have also unscrewed the idle adjuster all the way, so it is not that. I tried to adjust the air mixture, but now the bike struggles to start and still runs the same.
I found the stock carb should be 19mm. Everyone recommends upgrading to 21mm if oyu have performance parts like the custom exhaust on the bike. I found the carb on the bike now is a 32mm carb. There was dirt in the jets that I celaned out when I took apart the carb. How can I tell if the carb is just too big? It is a no name carb with no size markings on the jets, so I would just replace the carb before trying to reject.
Please help
Timmeh
PostPosted: 21:05 - 16 Aug 2013    Post subject: Reply with quote
you will prolly have an air leak past the carb intake manifold.
The last post was made 13 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 31.92 Kb
