idle problems
benyamaha
PostPosted: 12:55 - 17 Aug 2013    Post subject: idle problems Reply with quote
Hi guys, just gave my yamaha yz80 carb a clean and when I fitted it back I couldnt get the bike to idle without choke and when I switched the choke off it revs flat out!Ive messed with the idle screw but that does nothing!! Ive checked all my hose clamps are tight and seated properly but it makes no difference Sad help will be appriated
CestrianX
PostPosted: 12:59 - 17 Aug 2013    Post subject: Reply with quote
Why did you clean the carbs? Was it idling OK before the clean? Is the air filter clean? Is there a fuel filter and is it clogged?
More info required.
benyamaha
PostPosted: 13:11 - 17 Aug 2013    Post subject: carb Reply with quote
I was putting a new piston i just did it as it was a straight foward job to do... it revs its head off and it runs fine with choke on. Maybe the rubber pipe from the carb to the engine is split or perished causing a vacume leak?
misscrabstick
PostPosted: 14:23 - 17 Aug 2013    Post subject: Reply with quote
have you put the throttle slide/needle assy in 180 degrees out?
The other Paul Rudd
PostPosted: 15:04 - 17 Aug 2013    Post subject: Re: carb Reply with quote
Possibly. When you replaced the piston did you reuse the base gasket or use a brand new one? If you reused it, or didn't clean the mating faces perfectly, then air can leak in there.
CestrianX
PostPosted: 16:32 - 17 Aug 2013    Post subject: Reply with quote
"it revs its head off and it runs fine with choke on" - OP
So you know exactly whats causing the problem then. Assuming you're working fervently to fix your transport, have you found the fault yet?
benyamaha
PostPosted: 16:24 - 19 Aug 2013    Post subject: Reply with quote
Thanks for the replys! I did change the base gasket and they looked pretty clean and btw the problem happened after hours of riding it then when I came to it the next day to start the problem occured! And the throttle slide slides all the way down and up perfect
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.12 - MySQL Queries: 13 - Page Size: 50.64 Kb
