| pendulum |
 pendulum Traffic Copper
| P.addy |
 P.addy Red Rocket
| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
 Posted: 21:27 - 27 Jun 2012 Post subject: |
also a restricted CB500 should still do a decent 90mph uphill!  |
| GREENI3 |
 GREENI3 World Chat Champion
 Posted: 21:58 - 27 Jun 2012 Post subject: |
Gutless after 45 mph? Struggle to do 70 mph up a hill?
BS.
You must have a pretty crap cb to come out with those figures.
As for the restriction, just take the washers out.
I can't see why it would need a re-jet and unnecessary messing about with the carbs. |
| pendulum |
 Posted: 22:12 - 27 Jun 2012 Post subject: |
Ok, cheers.
I did a bit of research and discovered the FI International usually change the jets to #125 size from #122 on the CB500. I've seen this mentioned in many different threads so trusted the info, but I will check the old ones, to see if they have indeed been changed.
If it was just a case of removing the washers, I think I'd be a bit more confident, maybe the jets I can manage too (we'll see ), but some threads mention other things get changed too when the bike gets restricted (like modified inlet rubbers, and a mod to limit the diaphragm slides, whatever they are!). How will I know if this has been done
Re: my bike's speed. I've seen people say they can get up to 100mph after a long run up on a restricted CB500. On a perfectly flat road, I am very lucky to finally reach an indicated 80mph, which probably equates to 75mph or less in real life. With a headwind or a hill, I have dropped down to below 70mph before despite having the throttle fully open. That's not much better than the 125cc I've come from. From stationary though, the bike's very quick. Perhaps I have another problem with the bike, I'm not sure, but because the bike is fine at the lower speeds, I've always just assumed the restrictor kit had restricted the bike more than it needed to. I guess if everything goes to plan I'll soon find out.
I'll start tomorrow. ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment |
| stinkwheel |
 Posted: 23:31 - 27 Jun 2012 Post subject: |
A genuine Honda restrictor kit alters the main jet diameter and has restricted inlet rubbers.
An FI kit has washers in the inlet and different main jets. So if it's an FI kit, you remove the washers and fit the standard (smaller) main jets.
I used to be able to get Mrs stinkwheels restricted CB500s up to about 90mph if I wrang its neck for long enough. Top gear may as well not have been there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pendulum |
| stinkwheel |
 Posted: 13:25 - 28 Jun 2012 Post subject: |
| pendulum wrote: | I see, thanks. It's definitely an FI kit, it came with the red certificate. I'm going for one last ride and then I'll start work. Can you confirm that I'll definitely need the new Float Chamber cover gasket? I've read so many threads and none mention needing that at all, but I think I do? |
Depends if it tears when you take it off. I didn't need to, take care when you seperate the two parts as it's made of paper and tends to stick to one or both of the sides.
Of more importance, make sure you use the correct size and type of screwdriver to remove the screws holding the float bowl on, they burr easily. If you are not comfortable telling the difference between a phillips, a pozidrive and a JIS screw head (can't remember which they used), a quick google on the subject could prevent a disaster.
The airbox pivots backwards away from the carbs once you've taken the battery out. It can be an enormous help to detaching the carbs if you secure it in the pulled back using a bungee. The manuals aren't always clear on this point.
Take digital photos at each stage so you remember where the pipes, cables and breather hoses were routed. I didn't actually take the throttle and choke cables off the carbs when I did them. Just detached them and flipped them upside down on the bike. This allowed me to remove the float bowls and change over the jets with minimum fuss.
You may well need to heat up the inlet rubbers to get the washers out, they are in there pretty tight. A soak in boiling water and a little washing up liquid to jube them helps a lot, just careful not to scald your fingers. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pendulum |
 Posted: 15:16 - 28 Jun 2012 Post subject: |
Thanks, very helpful. And I'm glad I read that before I begun.
I've been putting it back all day (weather's been nice, I've been out riding ) but now is the time to go in the garage and start work.
Probably be back on here shortly with a problem  ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
| stevo as b4 |
| Ingah |
 Ingah World Chat Champion
| prawny1 |
 prawny1 World Chat Champion
| stinkwheel |
| pendulum |
 Posted: 12:23 - 29 Jun 2012 Post subject: |
I know you're right stinkwheel, I've read about the 125 jet upsizing in far too many places for it not to be true... however, I have just undone one of the float chambers, unscrewed the main jet, and on the side of it, as clear as day: 122
So, for whatever reason, it doesn't look like they've changed the jets on my bike when they did the restriction. I have however removed the two big restriction washers, one from each inlet.
Now I think I'm ready for the daunting task of trying to get the bike back together again
Edited because I meant to say "inlet" ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
| FantasticMrFo... |
 FantasticMrFo... Nova Slayer
| pendulum |
 Posted: 13:10 - 29 Jun 2012 Post subject: |
I think there's just two washers that do the work. If I am wrong, could someone tell me quick before I start putting the bike back together tonight  ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
| FantasticMrFo... |
| GREENI3 |
| stinkwheel |
 Posted: 13:47 - 29 Jun 2012 Post subject: |
| pendulum wrote: | I know you're right stinkwheel, I've read about the 125 jet upsizing in far too many places for it not to be true... however, I have just undone one of the float chambers, unscrewed the main jet, and on the side of it, as clear as day: 122
So, for whatever reason, it doesn't look like they've changed the jets on my bike when they did the restriction. I have however removed the two big restriction washers, one from each carb.
Now I think I'm ready for the daunting task of trying to get the bike back together again  |
This may go some way to explaining the lack of power when it was restricted. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| prawny1 |
| Robby |
 Robby Dirty Old Man
| prawny1 |
| pendulum |
 Posted: 22:55 - 30 Jun 2012 Post subject: |
Job done, successfully Thanks for the help.
It took me a while but I do work slowly, I'd call it a three spanner job rather than the two Haynes give it, but for a newbie like myself it's challenging but doable
More importantly... what a difference it has made!
Where there was so little acceleration at middle/high revs before, now it just comes alive. It's like a completely different bike! It surprised me big time!
I shall book the next available Mod 1 slot in the morning! ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
There is a gap of 1 year, 48 days between these two posts... |
| magicman-alex |
 magicman-alex Two Stroke Sniffer
The last post was made 13 years, 88 days ago. Instead of replying here, would creating a new thread be more useful? |
