NEEBIE HELP
tonycheshire
PostPosted: 08:55 - 20 Aug 2013    Post subject: NEEBIE HELP Reply with quote
hi guys thanks for reading i bought i moped finally a 50cc yamaha neos 53 plate.. to me ages of saving up from work now i was looking at adding a cdi unit to it. and also a new air filter
i cannot find the cdi box have added some pics to see if u guys can help me also any help on what i ould need to do to add a air filter
will u need to upjet also if i do how do i do this?
only reason for adding the cdi is ts slow up hill and on take off.
regards
tony Twisted Evil
https://imageshack.com/scaled/large/90/9gnz.jpgUploaded with ImageShack.com
https://imageshack.com/scaled/large/541/tu2l.jpgUploaded with ImageShack.com
https://imageshack.com/scaled/large/802/fzjg.jpgUploaded with ImageShack.com
https://imageshack.com/scaled/large/692/xqk0.jpgUploaded with ImageShack.com
orac
PostPosted: 09:13 - 20 Aug 2013    Post subject: Reply with quote
it a 50, how fast did you expect it to go.
leave it alone, ride for a bit then get rid and replace with a 125. i honestly wonder why any body bothers with 50cc machine.
ps have you check variator weight, worn or incorect ones will give you the same symptons
tonycheshire
PostPosted: 09:19 - 20 Aug 2013    Post subject: hi Reply with quote
i dont want it to go fast i expect the speed i am getting it is just slow from take off e.g. when at a round about or what ever that is why i want to add the cdi to hopefully increase this
orac
PostPosted: 09:46 - 20 Aug 2013    Post subject: Reply with quote
what are you comparing it too, if it s a 50 that has not been tempered with mean that it will be slow compared to everything, including somebody walking along side you.
the thing you will be forgetting is that by changing thing you will increase the the chance of it failing and causing even more money.
have you checked the variator yet, as that can cause issues of "slowness".
also what were those picture in aid of? some of your carb, a connector and a relay. maybe just start by googling neos CDI so you know what you are looking for. FYI it wont be under there
PostPosted: 10:02 - 20 Aug 2013    Post subject: Reply with quote
Get a standard deck of playing cards.
Cut it in half.
That's the volume of your engine.
No matter how many holes you drill or wires that you cut or join or hundreds of pounds of random bits that you throw at it, it'll still be half a pack of playing cards and any gains that you get will exist more in your imagination than reality.
In the full knowledge that you're going to go ahead and do all that anyway, I would urge you not to, and to put the money into a jar marked "125cc bike".
tonycheshire
PostPosted: 10:48 - 20 Aug 2013    Post subject: Reply with quote
ok thanks for all your replys i basicilly am looking for the CDi them if u can help me find it
PostPosted: 10:55 - 20 Aug 2013    Post subject: Reply with quote
The CDI won't do much... looking at 2mph.
tonycheshire
PostPosted: 10:58 - 20 Aug 2013    Post subject: Reply with quote
i know but can u help me find this please its not next to the battery hence the pictures
-Matt-
PostPosted: 11:00 - 20 Aug 2013    Post subject: Reply with quote
Wouldnt waste your time or money to be honest.
Save both and put them into a 125.
Which will be this much better
https://i44.tinypic.com/1zntv7p.jpg
orac
PostPosted: 11:19 - 20 Aug 2013    Post subject: Reply with quote
so you have been told not to bother and still expect people to help, i have already told you it no under there area you have posted pictures. so you need to take more pictures of other areas of the machine so that it can be identified.
https://lmgtfy.com/?q=yamaha+neos+50+cdi+images
start looking
The last post was made 13 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 64.47 Kb
