Exhausts and Firegum
Baffler186
PostPosted: 08:52 - 22 Aug 2013    Post subject: Exhausts and Firegum Reply with quote
Hello. I recently fitted a scorpion full exhaust system (2 sections and end can) to my CBF 125 but I've now noticed that the section joins are blowing a bit. I daren't tighten them up any more as the joins are only small jubilee clips with no sleeves/gaskets. What's the best way to seal them properly? I read on other threads about Firegum but never used it before. Due to the various angles of the exhaust system I don't think it would be easy to get off again in one piece (should i want to sell it with the stock exhaust fitted) so I'd like to ensure that the sections are still removable rather than sealing them all together with something permanent.
Any advice appreciated.
cheers[https://www.msa-direct.co.uk/ProdImages/xl/scorpion-factory-eha107-diagram.jpg][/url]
PostPosted: 08:55 - 22 Aug 2013    Post subject: Reply with quote
Can't you buy actual gaskets?
PostPosted: 09:16 - 22 Aug 2013    Post subject: Reply with quote
Clear, general purpose silicone like you'd use to seal round the edge of your bath.
Cheap, effective and easily removed if you need to.
Islander
PostPosted: 10:42 - 22 Aug 2013    Post subject: Reply with quote
I'd be tempted to use the high temperature stuff for stove flues. It's good up to 300C IIRC and not that much more expensive. Thumbs Up
Baffler186
PostPosted: 11:38 - 22 Aug 2013    Post subject: Reply with quote
cheers, this makes sense as the exhaust gets red hot! Hopefully I can do it neatly....
PostPosted: 11:52 - 22 Aug 2013    Post subject: Reply with quote
I've used Wickes own brand general purpose silicone to seal between the header pipe and the cylinder head on my Enfield before. No problems.
PostPosted: 12:03 - 22 Aug 2013    Post subject: Reply with quote
On stinkwheel's previous recommendation, I've used B&Q Value silicon gloop a couple of times with success.
It even managed to seal a little-fingernail sized hole when bean-tinned over. It's not rated to those temperatures, but it does seem to work.
Walloper
PostPosted: 18:39 - 22 Aug 2013    Post subject: Reply with quote
A steel drinks can cutted to size and wrapped around the pipe will 'bring it up to size' for the can/woteva. Then tighten as normal with the jubilee clip.
Matt-
PostPosted: 19:48 - 22 Aug 2013    Post subject: Reply with quote
+1 for this, i've done this before because the firegum exhaust paste wasn't man enough for the job!
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Baffler186
PostPosted: 11:07 - 23 Aug 2013    Post subject: Reply with quote
thanks everyone, will give that a go. I will probably need to buy 8 cans of beer, just in case I mess up the can-cutting
Matt-
PostPosted: 12:31 - 23 Aug 2013    Post subject: Reply with quote
Use 1 can for your exhaust and drink the other cans Very Happy of course while your doing the work Wink
Walloper
PostPosted: 12:36 - 23 Aug 2013    Post subject: Reply with quote
Take a magnet with you to Morrisons/The Paki's. If the magnet sticks to the can it's steel. If not it's aluminimininumum.
Or just work your way through a selection until you find what is best suited.
Robby
Dirty Old Man
PostPosted: 12:41 - 23 Aug 2013    Post subject: Reply with quote
Wire wool can do a surprisingly good job for getting a seal with slip-on exhausts.
That said, check very carefully to see if it should have a gasket. I know my old CBR6 needed a fairly chunky fibre gasket (like a short section of pipe) to make the exhaust work.
Raffles
PostPosted: 13:11 - 23 Aug 2013    Post subject: Reply with quote
I've used this stuff many times. It's inexpensive and can successfully be used dry or in conjunction with a suitable sealant.
The last post was made 13 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 85.59 Kb
