Misfiring problem *SOLVED*
BoYSiE
PostPosted: 17:51 - 09 Dec 2004    Post subject: Misfiring problem *SOLVED* Reply with quote
Hi, i have recently put a bore kit in my ped, and when it pulls away in the high revs it seems to misfire, also, when im flat out it starts to misfire, its only when i hit 10k+ Rpm, below that its fine. It said in my bore kit manual to use a longer threaded spark plug? which i havent done, could this be the solution?
Thanks.
pipnet11
PostPosted: 18:27 - 09 Dec 2004    Post subject: Reply with quote
Try it. If you bugger about with timing and things only to find out its a simple plug problem you'll be kicking yourself. Plugs dont cost much, and are a doddle to change, it would be the first thing Id try.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
PostPosted: 20:02 - 09 Dec 2004    Post subject: Reply with quote
Using a longer or shorter threaded plug in a small engine will significantly alter the compression ratio. Two strokes are a delicate balance of pressures so I would try the longer plug in. This will bump up the compression ratio. Take the plug out after a few miles and 'read' the colour according to the following guide:
https://www.bikechatforums.com/viewtopic.php?t=37506
BoYSiE
PostPosted: 15:00 - 11 Dec 2004    Post subject: Reply with quote
Ok, i thought i would post my results, i bought a hotter spark plug (racing spark plug) and now i no longer have misfiring at high revs.
Jon.
The last post was made 21 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 40.11 Kb
