Car problem, Peugeot 405
RhynoCZ
PostPosted: 13:21 - 23 Aug 2013    Post subject: Car problem, Peugeot 405 Reply with quote
My brother's got a '93 2.0L 405 ABS and he's got problem with brakes. There's a lot of air coming into the system, when the car's not used. He bleeded the system, got new brake fluid in it and the system worked but then he parked the car for a week and it was all over again. The brake pedal goes to the floor and there's air in the system again. What'd you suggest before he spends money on it?
Thank you
PostPosted: 14:22 - 23 Aug 2013    Post subject: Reply with quote
The seals on the MC and the bleed area.
RhynoCZ
PostPosted: 21:46 - 23 Aug 2013    Post subject: Reply with quote
Gonna look into that, thanks Thumbs Up
misscrabstick
PostPosted: 22:44 - 23 Aug 2013    Post subject: Reply with quote
remove all the wheels, look at the calipers, look in the drums if not discs all round, look for fluid leaks, look at the mastercylinder where it bolts to the servo, wet? look at the abs unit, wet? if you can't find any wetness assume the mastercylinder is bad and swop it out and bleed the system, be warned though bleeding abs systems after a mastercylinder change without a pressure bleed system can be problematic sometimes.
RhynoCZ
PostPosted: 18:10 - 25 Aug 2013    Post subject: Reply with quote
Everything's nice and dry, I gonna try to change seals in the master cylinder and if nothing, then I'm gonna tell my brother to get a new MC Thumbs Up
Thanks again
The last post was made 13 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 44.17 Kb
