Shed security idea's
rhys1005
PostPosted: 21:36 - 23 Aug 2013    Post subject: Shed security idea's Reply with quote
Hi BCF.. I'm building a shed with my dad over the coming weeks for our motorcycles and I just need a few security idea's as our area is full of theiving scrotes and vandals.
The shed is going to have a concrete base and the shed's also going to have it's main structure (thick as fuck wood pillars) concreted into the ground, the rest of the shed touching the groung will also be bolted down.
Taking advantage of the concrete base my dads made up 3 stainless steel ground anchors about 1.5 foot long with the end being made out of a thick stainless steel 'O' ring for the chain to go through (two shit oxfords and an almax IV).
For locks weve went with a few cheap basic shed locks but plan to had double doors for the bike entrance and a side door for our access. The double doors are going have a barn door style bar & lock on the inside aswell as having two steel rods coming from the ground going up to knee height that also has a steel bar locked across to prevent the bikes leaving the shed.
We may go for a few extras such as reinforcing the inside with chicken wire and putting a plank of wood with a few cheeky nails sticking out behind each of the doors to give the theives a nice suprise.
Ok this might sound a bit OTT but my area is known for theives to the point where my neighbour has a huge £1k storage unit for his bike Shocked
Just want a few more ideas such as what hinges to use etc. this thing is going to be housing 3+ bikes for many years to come so want it as secure as possible for that peace of mind Thumbs Up
SQL
PostPosted: 21:38 - 23 Aug 2013    Post subject: Reply with quote
Shotgun trip mines
Nick 50
PostPosted: 21:40 - 23 Aug 2013    Post subject: Reply with quote
Place 2 in garden:
https://cdn.pedigreedatabase.com/dogbreeds/rottweiler.jpg
Train to park (and bark too) at people passing garden.
bikertomm
PostPosted: 21:42 - 23 Aug 2013    Post subject: Reply with quote
Sounds like you've got the jist of it buddy, all I'd say is get a ground anchor in there when you do the concrete, almax the bugger and get a decent lock on the shed, security light?
Then you've done your bit really! Thumbs Up
SQL
PostPosted: 21:49 - 23 Aug 2013    Post subject: Reply with quote
Nick 50 wrote:
Place 2 in garden:
Train to park at people passing garden.
Park??
https://www.funnydogsite.com/pictures/Driving_Dog.jpg
PostPosted: 21:54 - 23 Aug 2013    Post subject: Re: Shed security idea's Reply with quote
I'd consider going for the big overt security (like the metal bars) inside, so it doesn't look like there's owt worth nicking.
You can get fancy alarm systems fairly cheaply that will take a SIM card - not to deter thieves, but to notify you.
Ideally add to that a CCTV camera or two with remote viewing (can be done fairly cheaply) - that way if the Alarm goes while you're out, you can check up and call the police etc.
-Matt-
PostPosted: 22:08 - 23 Aug 2013    Post subject: Reply with quote
Sounds like you've got it covered to be honest
If you want cheaper/additional ground anchors some cheap plumbing piping like this will do the job normally https://4.bp.blogspot.com/-SlGbfE2MaXw/TWFKAOfhNbI/AAAAAAAAADY/mbaB5U7Le7Q/s200/002.JPG
But 3 is probably plenty Laughing
Besides that i'd get some alarmed disc locks, one or two, cheap ones should be alright if its kept inside [they tend to go off in the wind and stuff if outside sometimes], just as an additional deterant.
rhys1005
PostPosted: 22:13 - 23 Aug 2013    Post subject: Reply with quote
Forgot to mention shed will be outside the front of house as we have no access to back garden. Dad is a welder.. can make pretty much anything is stainless steel if you have any good ideas. Thumbs Up would put a dog in the shed but I like my dogs too much to put them at risk Embarassed
Almax and anchor would deter most from theiving the bike but vandalism is another worry Sad
Can't post pics atm but dad's going to make a 'Y' anchor tomorrow cost £70 odd to buy (search google images). It's concreted into the ground so only two holes are shown in the ground, no metal showing. Will post pics when it's made.
-Matt-
PostPosted: 22:20 - 23 Aug 2013    Post subject: Reply with quote
If the shed is purely for bike security and as hes a welder etc, have you considered a cage inside the shed, additional thing to chain the bike to and if you make a swing-door on it can put some hefty bolts etc to make a 'shed within a shed' essentially.
PostPosted: 22:23 - 23 Aug 2013    Post subject: Reply with quote
Consider sticking some rebar between the 'y' bit in the concrete and around the area; not likely it's going to be an issue, but can probably get some from scrap yard for not much and believe it should make it even harder.
rhys1005
PostPosted: 22:32 - 23 Aug 2013    Post subject: Reply with quote
Yeh we actually thought of having a cage and decided it was too risky as his boss doesn't mind him doing the odd anchor etc but not anything like that (too much material cost). Which is what gave us the chicken wire idea. Definatly something to consider in the future Thumbs Up
Will text him about the rebar tomorrow as he works next to a scrap yard Thumbs Up something i never thought about tbh, makes sense as the lock/chain will be £140 no point letting the anchor be the weak point!
-Matt-
PostPosted: 22:40 - 23 Aug 2013    Post subject: Reply with quote
Ah didn't realise he was using work materials [generous they're allowing the anchors Laughing ].
If a full blown cage isnt an option a hinged lock-bar might be doable as another additional thing to stop it being dragged out, can whack a chain/locks or whatever through the loop-point
Can't find an appropriate picture so excuse the horrendous drawing Laughing
https://i41.tinypic.com/2mgqrti.jpg
I would think you will need some pretty fucking determined thieves to nick it already though from what you've described unless the bikes in the 10k region Laughing
fraser2312
PostPosted: 22:54 - 23 Aug 2013    Post subject: Reply with quote
Sorry if I'm stating the obvious but when you fit the hinges use those bolts with the mushroom head, its really surprising the amount of hinges you see fitted with pozi screws Thumbs Up .
rhys1005
PostPosted: 23:07 - 23 Aug 2013    Post subject: Reply with quote
Great idea Very Happy think it should be some sort of gate behind the doors as a replacement for a door bar that can't be lock from the outside? (decided were not having a side door now - too expensive to secure another door). Similar to those barriers that stop people entering car park compounds without paying?
I'm hoping for 3 'lines of defense'.. The actual shed security (shed locks/ chicken wire/ thick doors/ alarm), Securing the bike so it can't be moved (chains/ ground anchors/ 'gate lock') and then the actual bike security (disc lock/ alarm/ steering lock).
Most of the above i have from securing previous bikes when parked outside shops etc and from when i previously planned to build a shed so it's not like it's going to cost me a bomb. Cost so far is £600 but that's for all the materials, just have a few more bits such as almax so total should come hopefully come to £800.
Three bikes, do plan on getting bikes in future worth over £3k so times that by 3 (dad will also be using a shed) and you see why im so OTT Laughing
rhys1005
PostPosted: 23:11 - 23 Aug 2013    Post subject: Reply with quote
Hinges are my biggest concern atm.
Think fire door hinges or shed hinges would be best? Fitting hinges on the inside is possible right (silly question but i oddly see sheds with hinges on the outside with pozi drive like you said Shocked )
Funny you mention that actually.. Went to view a bike the other week.. Seller shown me his flashy 3 grand shed with 3 inch thick wood etc.. Huge gap under it without a concrete base (hello car jack) and hinges on the outside with pozi drive Laughing
-Matt-
PostPosted: 23:14 - 23 Aug 2013    Post subject: Reply with quote
I'd rather be OTT and fairly sure theyre safe personally also, luckily enough to have a garage in an alright area at the moment, so although mines not totally safe with the alarms/chain/anchor its pretty sturdy.
I'd definately do the same though, especially with that amount and value of bikes Thumbs Up
BTTD
PostPosted: 23:27 - 23 Aug 2013    Post subject: Reply with quote
Security hinge.
https://www.locksonline.com/acatalog/stainless-steel-security-butt-hinge-102-x-76-mm-7289.html?gclid=CLrT2pjNlLkCFRMPtAodeQsAzA
Fitted something similar to my shed (cos I like my flymo nice and secure), but mine were from Screwfix.
sabian92
PostPosted: 00:48 - 24 Aug 2013    Post subject: Reply with quote
If Home Alone has taught me anything:
Use metal door handle
Attach live mains wire to handle
Dead scrotes! Thumbs Up
DJS
PostPosted: 08:00 - 24 Aug 2013    Post subject: Reply with quote
SQL wrote:
Shotgun trip mines
+1 for these!!
Available on Ebay quite cheaply and will scare the cr*p out of any scrote trying to steal your pride and joy.
rhys1005
PostPosted: 08:58 - 24 Aug 2013    Post subject: Reply with quote
Thanks for the reccomendations/idea's Thumbs Up
Won a Abloy 362 padlock on ebay for £45 (£160 retail hope it isn't a fake?) and an Almax IV chain from their site. Also ordered one of those shot gun blank 'alarms' as i found one pretty cheap and going to look at those security hinges tonight as dad has a membership card to builders yard Thumbs Up
Any idea why people use those long as fuck shed hinges appose to firedoor hinges?
BTTD
PostPosted: 11:03 - 24 Aug 2013    Post subject: Reply with quote
Because normal sheds have 1" door frames that won't support the thin shed door.
Joncrete Cungle
PostPosted: 11:12 - 24 Aug 2013    Post subject: Reply with quote
I have 4 Abloy 362 padlocks that all came from ebay, none are fake. We have a couple of £160 new ones on the gates at work that I compare my ebay jobbies to. Wink Thumbs Up
Ribenapigeon
PostPosted: 19:48 - 24 Aug 2013    Post subject: Reply with quote
I sandwiched my shed doors between half inch exterior plywood glued and bolted on as well as bolting on plywood surounding the doors over the top of the hinges as well as using steel strapping over the hinges. All lock hasp areas are surrounded by 2"x2" also bolted as well as screwed in so as to prevent a crowbar getting under the hasps or the three padlocks. The doors are akso chained to the door surounds on the inside. Bolt everything, screws are no good. Then add electrical alarms and other devices. Get a video survalence kit as well. my shed has survived five attempted break ins this way and the last one the coppers even got a conviction due to video evidence.
As for locks you can only go so far, but alongside my normal padlocks ive used a van door lock. Theyre an absolute bugger to get through apparently (according to my underworld sources).
An internal cage may be a bit over the top but if I could weld and had access to exuipment then I would have at least made a metal door frame and put a metal frame in the door.
Walloper
PostPosted: 20:06 - 24 Aug 2013    Post subject: Reply with quote
DJS wrote:
SQL wrote:
Shotgun trip mines
+1 for these!!
Available on Ebay quite cheaply and will scare the cr*p out of you if you forget to disarm the fucker.
FTFY.
i.p.phrealy
PostPosted: 22:45 - 24 Aug 2013    Post subject: Reply with quote
re-enforce the frame and doors with angle iron if you can. makes them harder to crowbar open.
The last post was made 13 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 129.78 Kb
