No headlight when engine not running
Richmurrills
PostPosted: 10:25 - 24 Aug 2013    Post subject: No headlight when engine not running Reply with quote
Hi all,
Probably a stupid question but;
I've just replaced my headlight bulb on my YBR 125 (2005-2007 model) as the filament for the dipped beam had blown and I didn't fancy running everywhere on full beams.
The new bulb's in fine and I have headlights when the engine is running but I don't get any light when the ignition is on but the engine isn't running.
I'm sure I used to so I'm guessing a fuse has blown. Could someone confirm that a) I'm not imagining things and b) It's likely to be a fuse that's gone when the filament went?
Aff
PostPosted: 10:27 - 24 Aug 2013    Post subject: Reply with quote
All the bikes I have owned have only had the light working when the engine is running.
Electric Bike Project
jamesrs250
PostPosted: 10:55 - 24 Aug 2013    Post subject: Reply with quote
all my bikes the lights are only on when the engine is running..apart from the bandit if you put the parking switch on...if it is a fuse just check all the fuses only about 6 of them
YBR Ric
PostPosted: 11:11 - 24 Aug 2013    Post subject: Reply with quote
The main headlight bulb only works on dip/main when the engine runs.
With the engine off, ignition on (as far as the headlamp goes) you will only have the 5w pilot light bulb lit.
Richmurrills
PostPosted: 12:01 - 24 Aug 2013    Post subject: Reply with quote
Ok cool. I'm not sure I was even getting that but I'll check in the dark.
PostPosted: 12:07 - 24 Aug 2013    Post subject: Reply with quote
If the lights are on when the engines running all is OK.
You don't have a separate fuse for the lights with engine running/nor running. I
t's probably a safety feature to ensure you don't kill your battery.
Richmurrills
PostPosted: 13:49 - 24 Aug 2013    Post subject: Reply with quote
Not worried from a safety POV, it's just bugging me as I'm *sure* it behaved differently before. Damn my brain. Smile
Walloper
PostPosted: 16:15 - 24 Aug 2013    Post subject: Reply with quote
Perhaps 'The light is on but no one is home.' Very Happy
Richmurrills
PostPosted: 16:42 - 24 Aug 2013    Post subject: Reply with quote
Quite possibly.
Wonko The Sane
PostPosted: 17:56 - 24 Aug 2013    Post subject: Reply with quote
my ZZR has a separate switch for the lights so they do come on with the ignition (if switch is on)
The Honda I had before it didn't have a separate lights switch so they used to come on with the engine (lower powered light before starting)
clancy
PostPosted: 20:07 - 24 Aug 2013    Post subject: Reply with quote
Do you need the lights on when the bikes off ? Lol
KLX 300r
Dave M
PostPosted: 20:24 - 24 Aug 2013    Post subject: Re: No headlight when engine not running Reply with quote
Richmurrills wrote:
Hi all,
Pilot light is there as a fail safe just in case headlight fails completely so you have a little bit of light. Should only come on while engine is running.
uberkron
PostPosted: 23:57 - 24 Aug 2013    Post subject: Reply with quote
Not many 125 have a dc headlight, if it came on with the key thered not be long before you couldnt crank it over.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
The last post was made 13 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 76.3 Kb
