Gsxr coolant
j.silvs
PostPosted: 13:38 - 26 Aug 2013    Post subject: Gsxr coolant Reply with quote
Want to have a go at changing the coolant on my gsxr
Is there a certain one to get or recommendations?
Obv being in UK it needs to have ant freeze properties too
PostPosted: 13:40 - 26 Aug 2013    Post subject: Reply with quote
Blue or green give more bhp than orange. This is because orange reflects light differently, and so doesn't flow as fast. Thumbs Up
j.silvs
PostPosted: 13:42 - 26 Aug 2013    Post subject: Reply with quote
Joking?
PostPosted: 13:43 - 26 Aug 2013    Post subject: Reply with quote
There are a few different types:
https://en.wikipedia.org/wiki/Antifreeze
All are as good as each other, can't mix blue/green and orange types together (apparently).
Can't use antifreeze if you're racing.
50-50 mix will be fine for the UK, Northerly points of Scotland may need a different mix in winter.
PostPosted: 13:44 - 26 Aug 2013    Post subject: Reply with quote
J.Silvs wrote:
Joking?
No, factual. Thumbs Up
j.silvs
PostPosted: 13:47 - 26 Aug 2013    Post subject: Reply with quote
So 50/50 anti freeze and distilled/ de ionised water?
PostPosted: 13:52 - 26 Aug 2013    Post subject: Reply with quote
Indeed.
Or normal water and a couple of Calgon tablets. Thumbs Up
Personally I've put normal water in, and not had an issue.
Walloper
PostPosted: 15:01 - 26 Aug 2013    Post subject: Reply with quote
Don't need to phaph with deionised water now-a-days.
Buy a good quality Pre-Mixed Coolant,
Drain AND FLUSH the system.
Add the new coolant and bleed.
If you fill slowly the system SHOULD self bleed but if in an Adolescent/Pre-pubescent rush (as they do) then you may trap air crack the head and then hell will mend you.
50:50 is the max anything more will not increase the 'anti-freezing' ability and can cause harm due to the salts dropping out of solution.
The thing is once it's done it should be good for two to three years. If you buy a 'long-life/extended life coolant then it will last until biking in Europe is eventually banned. Smile
e.g. five year coolant
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_907027_langId_-1_categoryId_255224
Tip:
If you add a teaspoon of baking powder you can hardly taste the bittering agent. Thumbs Up
The last post was made 13 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 55.85 Kb
