| Lazysod |
 Lazysod Borekit Bruiser
| Irn-Bru |
 Irn-Bru World Chat Champion
| nathan k |
 nathan k Spanner Monkey
| nathan k |
 Posted: 02:45 - 27 Aug 2013 Post subject: |
Try sitting at the lowest point in the seat (a little forward) and slide you cheek off the seat at a light. |
| yambabe |
 yambabe World Chat Champion
| prawny1 |
 prawny1 World Chat Champion
| G |
 G The Voice of Reason
| Lazysod |
| G |
| Lazysod |
 Posted: 13:38 - 27 Aug 2013 Post subject: |
| G wrote: | Why do you want or need to get flat footed?
I don't think I do on the KTM enduro bikes I had.
And my right ankle doesn't articulate quite properly either, but still fine to use toes if I don't move myself over.
The Jap 4 stroke 250s aren't underpowered when compared to a DT - for greenlaning their wider range of power is better if anything.
The CFR230 is another one to have a look at if you're stuck on the 'short' thing.
| Quote: | I just wish I had the time to take on the project of fitting a tuned DT125 engine into the rolling frame of a YZ125 and making that road legal, I guess fitting lights and the road registering part is the pita, would the process of fitting a DT125 engine into a YZ125 be that difficult? I've removed and refitted motocross engines in my teens and didn't struggle but I guess adding electrics and oil tank will require a level of ingenuity and impracticality. |
What? and 'Why the hell?'
Why do you want to take a reasonable reliable engine, make it less reliable, then put it in to a taller bike that as standard comes with a less reliable engine?
Putting a DT engine in to a motocross chassis is likely to need some fabrication work - more effort in that than adding an oil tank and electrics, which should be pretty simple.
Premix can be fairly easy - get some baby bottles and mark off the amount in litres of petrol on the side for 2 stroke. Whenever you fill up, give it an appropriate squirt and you're sorted. |
I thought for green laning I'd be better off flat footed since when I tried that style of riding in the past it was often touch and go with regards to the ground and my feet.
The YZ125 I've owned before and had lowered front and rear in a way I don't think is possible with the DT, I like the idea of the YZ's solid chassis and components with a DT engine tuned to breath a little easier and give more power, I wouldn't want to attempt to tune it too close the power of a YZ125, I imagine I'd be about 25% down on YZ125 power after fitting an exhaust and minor tuning but didn't think that would affect reliability so much, I'm just wanting a sturdy bike that's quick without the need to mix oil though your idea about oil mixing has got me thinking maybe it isn't so inconvenient mixing on the move. |
| G |
| prawny1 |
 Posted: 14:37 - 27 Aug 2013 Post subject: |
Surely yz is going to be even taller than a dt right?
The conversion you are talking about has been done a few times believe it or not.
https://1.2.3.12/bmi/i64.photobucket.com/albums/h165/mark_midlands/yz200done2.jpg
This one the wr200 engine but is pretty much the same conversion (wr/dt200 engine fits 125 frame) ____________________ hellkat wrote:
Some people are only alive cos its against the law to kill them. |
The last post was made 12 years, 263 days ago. Instead of replying here, would creating a new thread be more useful? |
