1981 GPZ550
Frost
PostPosted: 20:46 - 26 Jul 2013    Post subject: 1981 GPZ550 Reply with quote
It's a tidy modern classic that came at the right price Wink
Lots of little tatty bits to be sorted on it that include
  • leak in the tank where the badge was fitted
  • more throtle cable free play than actual action Laughing
  • bodged gear select
  • weak as fuck center stand spring
  • very soft forks
  • slight leak on right fork seal
  • clutch drags a bit
Tank has been ordered, center stand spring fitted. Will inspect the front brakes soon.
https://www.bikechatforums.com/files/20130726_203407.jpg
https://www.bikechatforums.com/files/20130726_203356.jpg
https://www.bikechatforums.com/files/20130726_203132.jpg
https://www.bikechatforums.com/files/20130726_203118.jpg
https://www.bikechatforums.com/files/20130726_203043.jpg
beardface
PostPosted: 21:12 - 26 Aug 2013    Post subject: Reply with quote
Nice, looks like it's in good sound nick.
www.soundcloud.com/bodren
RhynoCZ
PostPosted: 21:22 - 26 Aug 2013    Post subject: Reply with quote
Loved my '88, your's just perfect Smile
https://i970.photobucket.com/albums/ae184/RhynoCZ/GPz550foto3.jpg
EDIT: Sorry, wrong year, but it is cool ad, don't you think? Smile
Frost
PostPosted: 22:46 - 27 Aug 2013    Post subject: Re: 1981 GPZ550 Reply with quote
Sadly it wasn't perfect Sad
If you look closely at the front calipers you'll see the banjo bolts are at the top and the bleed nipples are at the bottom. They are therefore upside down which can only be done by also putting them on the wrong side Shocked
On stripping and rebuilding with fresh seals they were impossible to bleed. After ages of pissing around i tried the bleed nipple off the rear on one of the fronts and it bled perfectly. 2 new nipples later and it became clear why they had been upside down, so that some pikey could bleed them through the banjo!
Frost wrote:
  • leak in the tank where the badge was fitted - Replaced
  • more throtle cable free play than actual action Laughing - adjusted
  • bodged gear select - replaced
  • weak as fuck center stand spring - replaced, then connected to the right bloody place, cheers keith!
  • very soft forks - removed bodged preload (huge nuts) replaced air valves and correctly pressurised
  • slight leak on right fork seal - rebuilt and changed both seals
  • clutch drags a bit - might be fixed, might be fucked, still undecided
Additionally a headlight bracket is missing meaning the light points at the sky. a possibly fitting one has been ordered from the US of A and is taking its sweet time getting here.
The rear tire though new wouldn't hold pressure. I replaced the valve but no luck. Stuck an inner tube in it.
Overall it's been a pain in the arse fixing other peoples handywork, but i'm starting to get some confidence in the bike now. In a straight line it's not too slow at it handles well for a bike if it's age and era.
beardface
PostPosted: 21:07 - 28 Aug 2013    Post subject: Re: 1981 GPZ550 Reply with quote
Good to hear that, enjoy the bike mate Smile
bypass2
PostPosted: 22:50 - 12 Sep 2013    Post subject: Reply with quote
looks a nice clean original bike.
PostPosted: 00:37 - 13 Sep 2013    Post subject: Reply with quote
It looks similar to my CB250RS, so I like it. Razz
PostPosted: 08:19 - 13 Sep 2013    Post subject: Reply with quote
I prefer the Uni-Trak one, but still... nice bike.
beardface
PostPosted: 15:29 - 04 Nov 2013    Post subject: Reply with quote
This bike inspired me to keep hunting for a gpz and not go with secondary choices, I found an 86 gpz600r in very similar colours to this and after much patience it is now mine Very Happy
The last post was made 13 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 62.88 Kb
