Windows Software Raid
t121anf
PostPosted: 11:58 - 28 Aug 2013    Post subject: Windows Software Raid Reply with quote
I run a small server at home which uses ESXi to offer multiple VMs. One of them is freenas, another Windows 2008 R2.
I'm beginning to wish I'd just stuck with Windows for ease of configuration, i.e. to auto shutdown from a ups command requires a third VM to take the instruction, which in turn shutdowns the other VMs, then itself and finally the host. Windows can use the software provided.
My server has 4 2TB hdds, which I'd like to make 2x 4TB spans. This is possible in Windows, but my concern is what happens in the event of a server failure.
Can I remove the drives, put them in another PC and access the volume?
(Naturally they will be backed up but thats beside the point, copying 4TB of data is rarely quick.)
Stowelly
PostPosted: 13:55 - 28 Aug 2013    Post subject: Reply with quote
"my concern is what happens in the event of a server failure. " attempt to recover the raid, fail at recovering the raid, attempt to restore backup, realise you dont have a backup..... cry
t121anf
PostPosted: 14:21 - 28 Aug 2013    Post subject: Reply with quote
Sorry, just to clarify there is a 5th drive that would be running the OS. The 4 2TB drives are purely for storage and its the recovery of these I wold care about.
prawny1
I suppose it all depends on what kind of raid you are using as to whether you can just access the volumes on another machine.
hellkat wrote:
t121anf
PostPosted: 14:23 - 28 Aug 2013    Post subject: Reply with quote
Not technically raid, but I an looking at spanned volumes
prawny1
PostPosted: 14:41 - 28 Aug 2013    Post subject: Reply with quote
Would be worth imaging or having a second clone drive of your main os drive so you don't have to set everything back up if the os drive fails or gets a virus, you don't even need to have it connected up once the copy is made just have it in the case and plug in as needed to update the image.
I'm not sure whether a simple spanned drive set will be detected by a different machine though, I would hope it has the info on each drive to identify themselves correctly but since I've never done it I don't know.
el_oso
PostPosted: 22:36 - 28 Aug 2013    Post subject: Reply with quote
software RAID should be fine.
Although I don't know what the limitations are on software RAID, I have swapped RAID volumes into different hardware and has worked fine. (as a non-bootable data drive at least)
Duke 390
Car: Jeep Wrangler 4.0L
duhawkz
PostPosted: 11:16 - 29 Aug 2013    Post subject: Reply with quote
A raid 0 volume (striped) is not fault tolerant if you loose a disk you will loose all 4TB on that volume.
If you server fails and you move the disks to another windows server you should be able to import the volume on the new computer. this should be fairly straight forward.
t121anf
PostPosted: 12:45 - 29 Aug 2013    Post subject: Reply with quote
Not to bothered about fault tolerance.
The 2 4TB volumes will be mirrors of each other, which in turn will be mirrored onto my external NAS and also a monthly export to a USB drive which is stored in a firesafe.
Pictures (which are the most important thing on the volumes) are also mirrored to Dropbox until my Samsung freebie expires then it will probably be moved to SkyDrive.
I just don't want to be in a position where Windows fucks itself and I need to copy 4TB back from my NAS/USB to the volumes.
Worst case is I'll leave them natively as 4x 2TB storing different things on each pair.
The last post was made 12 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 3 - MySQL Queries: 13 - Page Size: 60.41 Kb
