Flying some shit with helium...?
PostPosted: 14:36 - 29 Aug 2013    Post subject: Flying some shit with helium...? Reply with quote
Hey..
Little project I'm doing at the minute, and the internet as always is telling 2 different answers.
I want to lift 1 - 1.5kg of static weight that does not move. I want it to float through my control (wires, poles) but I also want it to ascend up as high as it can. Basically the opposite of free falling Laughing Like letting a balloon go, it just fucks off up to the big blue.
Can anyone give me an exact amount of helium that would be required, even better if you can give me that figure in standard party balloon numbers Wink
Everything bar the helium is ordered so its good to go Mr. Green Before you go and say test it, I need to know a decent amount of helium to buy for multiple attempts and working out what I would need for a swarm....
Karma for all helpful ones as always Mr. Green
Tungtvann
PostPosted: 14:43 - 29 Aug 2013    Post subject: Reply with quote
80-100 balloons (for 1kg). Double that for extreme lifting speed.
lihp
PostPosted: 14:44 - 29 Aug 2013    Post subject: Reply with quote
around 180balloons for 1.5kg
lihp
PostPosted: 14:45 - 29 Aug 2013    Post subject: Reply with quote
You need to remember in the calculations that you need to lift the weight of the balloon and the string also, which I included
lihp
PostPosted: 14:46 - 29 Aug 2013    Post subject: Reply with quote
And I reckon around 1500litres of Helium
Tungtvann
PostPosted: 14:55 - 29 Aug 2013    Post subject: Reply with quote
What about getting hold of some industrial balloons? Couple of those that can hold hundreds of litres rather than 5 might make it a bit easier!
PostPosted: 14:57 - 29 Aug 2013    Post subject: Reply with quote
Yup, ballpark is 1 cubic metre / 1000 litres per kg (assuming standard temperature and pressure, and that you're on earth).
But helium is a strictly limited resource and you're intending to piss it away on a lark? Tut Tut
A real man would use hydrogen. 8% more lift, and what could possibly go wrong?
The Artist
PostPosted: 15:02 - 29 Aug 2013    Post subject: Reply with quote
Much better off using a weather balloon. Can be bought on ebay and you will need quite a lot of helium. I was really bored once and was trying to work out how much I would need to lift myself, a chair and some bevvies up to a decent height. I figured I would need some strong rope but this in turn means I needed more helium and it got too expensive to actually do.
Hetzer
PostPosted: 15:05 - 29 Aug 2013    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Larry_Walters
https://www.express.co.uk/news/weird/51363/Man-flies-garden-chair-tied-to-helium-balloons
Tungtvann
PostPosted: 15:07 - 29 Aug 2013    Post subject: Reply with quote
It's pretty expensive stuff now, too. I reckon it might cost a few hundred quid in helium! 'mon Paddy, what ya doin?
PostPosted: 15:13 - 29 Aug 2013    Post subject: Reply with quote
Remember if you're intending to go very high, the balloon(s) will expand massively in size as the air pressure decreases.
At 10,000 feet, the air pressure will be roughly 70% of what it is at sea level. Your balloon will increase in size by a third or so
Weather balloons are designed for this.
Anyway. Stop withholding details, this isn't a military procurement exercise where you tell people what you want them to supply but not what it's for because that's how you end up with avionics systems that don't physically fit inside your helicopters.
Tell us what you're trying to do.
For rapidly elevating a single payload of 1.5kg directly up very quickly, have you considered a rocket? Or a catapault? Or an air cannon?
PostPosted: 15:20 - 29 Aug 2013    Post subject: Reply with quote
It is a HD recording device with GPS and stuff. Further things would be controlling the device and making it follow a paired device.
For example, suspended item pairs with my phone. It follows me if I walk backwards. Not exactly its use, but I'm aiming for that to be its primary function.
Firstly, I need to get it in the air as high as it can go and work from that. I'd try alternatives to helium, but I know of none. It also needs to be fairly stable from the initial lift and I need to be able to roughly control its descent to not smash the poor thing to bits.
Example, its similar to a Parrot Drone 2.0 but controlled differently and has a Pi onboard for the GPS/Bluetooth stuff to work.
Tungtvann
PostPosted: 15:24 - 29 Aug 2013    Post subject: Reply with quote
When you say follow, do you mean the camera following your movement? Will it always have to be tethered and how high do you actually want it to go?
CaNsA
PostPosted: 15:31 - 29 Aug 2013    Post subject: Reply with quote
Bluetooth isn't well known for its range...
Aff
PostPosted: 15:34 - 29 Aug 2013    Post subject: Reply with quote
I recently read an article in Popular Mechanics about 2 MIT students that did this. I'll go and find it and see what it said.
Electric Bike Project
PostPosted: 15:36 - 29 Aug 2013    Post subject: Reply with quote
Initially, I want as high as possible to test the gear, test range of kit etc. Always going to be line of sight.
When its suspended, it will be paired. It will not record until paired and once out of a set range this will stop following. If it was light enough, I'd quadcopter it but until I have the actual stuff down so it does exactly what I need, I don't want to write anything to control 4 rotors Laughing
DrDonnyBrago
PostPosted: 15:43 - 29 Aug 2013    Post subject: Reply with quote
True story: I balloon launched a Scotch egg (back to Scotchland) at my niece's birthday party last week.
You flying a camera or something?
EDIT: NM, read the posts between me opening the thread and me posting a reply.
PostPosted: 15:45 - 29 Aug 2013    Post subject: Reply with quote
If it can do a massive range with my Trainer RC plane, it should cope with this Laughing
Camera/GPS with tracker. It is going to be a larger thing if I can solve this one. For now.. I'm not fussed with the size of the thing, I'll aim to get it down VERY small when I can but for now... large is fine.
Aff
PostPosted: 15:48 - 29 Aug 2013    Post subject: Reply with quote
OK found it.
Popular Mechanics Article wrote:
MIT students Justin Lee and Oliver Yeh stuffed a camera in a cooler, tie it to a helium balloon and launched the rig 17.5 miles into the stratosphere. "the results were fantastic," Lee says. "We tracked the device with a GPS enabled cellphone and found it 20 miles from the launch site". The 5 hour flight which cost $150 in materials, took photos of earth every 5 seconds. Then at 90,000 ft, the balloon popped.
They used a weather balloon and a parachute attached to a coolbox.
Inside the coolbox was the camera and mobile phone all wrapped with newspaper and tinfoil and packed out with those hotpack handwarmers.
They said that on the ground the balloon was 5ft in diameter and at 90,000ft the balloon was 20ft in diameter.
They had some calculation in the article:
We
 found
 out
that
 each
cubic
foot
 of
 helium
 can
lift 28g.
The
 term,
free
lift,
 is
 used
to
describe
 the
 difference
 in
 the
 amount
 of lift provided
 and
the
 weight
 of
the
 entire
 capsule.
Each
 pound
of
free
lift
would
mean
 300
F/min
of
 ascent
rate.
For
 example,
 if
 we
had
 61
 cubic
 feet
 of
helium
lifting
 a
 load
 of
 800
grams,
you
would
have
 2
pounds
of
free lift
and
therefore
an
ascent
rate
of
600
feet/min.
Don't know about this country but they had to get FAA approval.
The article says they have a site: www.1337arts.com
:edit: Just had a look at the site and they have a step by step guide of how to make it. Laughing
https://space.1337arts.com/wp-content/uploads/2009/09/1337artsGuide.pdf
Tungtvann
PostPosted: 15:53 - 29 Aug 2013    Post subject: Reply with quote
Fuck the feds, do it anyway. Can I come and watch?
PostPosted: 15:54 - 29 Aug 2013    Post subject: Reply with quote
Oooh helpful Thumbs Up
I doubt it will cause any disruptions to others as I'm not likely to exceed 200ft for my initial ascension. I'll on'y be flying it up 20 or so times before confirming my things work or it has failed, then I'll rethink the whole thing Thumbs Up
DrDonnyBrago
PostPosted: 15:58 - 29 Aug 2013    Post subject: Reply with quote
Ah, well the lift that Helium produces is the difference in density between Helium and air which is about 1.1 kg per cubic metre at ground level, room temperature. You also need to consider that the helium will actually be more dense as it is compressed by the balloon and that air is less dense the further up you go, and changes with temperature...
It wont be very predictable or controllable, so count on a hard landing or having it physically tethered to the ground.
PostPosted: 16:02 - 29 Aug 2013    Post subject: Reply with quote
For the initial stuff I have a solid link to the floor/myself so it can't bugger off, that would make me cry Laughing I'll be able to retract it and do walk around testing etc.
DrDonnyBrago
What are you eventually trying to doing with it, make something to follow you around with a camera?
prawny1
PostPosted: 16:08 - 29 Aug 2013    Post subject: Reply with quote
Sounds like your planning on spying on someone, missus maybe? implant a radio tracker whilst she sleeps and get the balloon to follow her about all day.
I hope you have a long bit of string for your range tests so that it doesn't just up and float away.
Are all your fans and stuff for controlling direction strong enough to counter wind forces? 180 balloons will have an awful big surface area.
hellkat wrote:
The last post was made 12 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 127.49 Kb
