Garage Bolt
-Matt-
PostPosted: 18:19 - 29 Aug 2013    Post subject: Garage Bolt Reply with quote
Old couple next door keep having their garage broken into, its one of the shitty up-and-over doors with a 'lock' on the handle you could get open with a driver in seconds Rolling Eyes Nothing majors been nicked, bicycle and odd bits of gardening stuff, but they were asking if i could fit something cheap and simple to secure it a bit.
Garage defender isn't an option as the bloke struggles to bend down with his bad back, just wondering if anyones used something like this and how likely it is to withstand an average effort to get inside Thinking
Any better suggestions Praying Question
https://www.ebay.co.uk/itm/Enfield-Garage-Door-Bolt-Locks-MK-4-New-2013-Model-/321138971563
https://i.ebayimg.com/t/Enfield-Garage-Door-Bolt-Locks-MK-4-New-2013-Model-/00/s/MTE5NVgxNjAw/z/kG4AAMXQhpdRsIVJ/$(KGrHqFHJE4FGNV2GFfCBRsIVI)bYQ~~60_57.JPG
https://i.ebayimg.com/t/Enfield-Garage-Door-Bolt-Locks-MK-4-New-2013-Model-/00/s/NDAwWDQwMA==/z/hzIAAOxyLchRsIWo/$(KGrHqNHJFQFGuIyNOt4BRsIWodyQw~~60_12.JPG
Wonko The Sane
PostPosted: 19:12 - 29 Aug 2013    Post subject: Reply with quote
Parent's garage has a set of those mounted about 2ft up from the bottom.
mounted there to prevent a crowbar and bending the door to get in.
Bear in mind you're putting visible locks on which may make people think there is now something of value in the garage and try harder.
as far as we're aware there hasn't been another attempt to get into the garage since fitting them.
-Matt-
PostPosted: 19:52 - 29 Aug 2013    Post subject: Reply with quote
Thanks mate i'll fit a pair for them then Thumbs Up They dont need a bank vault just something to hopefully deter the local teenagers who theyre fairly sure are the culprits Laughing
PostPosted: 19:55 - 29 Aug 2013    Post subject: Reply with quote
https://www.henrykrank.com/index.php?main_page=product_info&products_id=2964
spikenipple
PostPosted: 20:02 - 29 Aug 2013    Post subject: Reply with quote
Those locks look very well built...but the only trouble is you can unlock them with a screwdriver. Find something with a key lock, not that shitty cross-head type lock.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
-Matt-
PostPosted: 20:15 - 29 Aug 2013    Post subject: Reply with quote
Yeah i wondered about that, looks almost like a universal crosshead shape, but the listing (if its being truthful Laughing ) reckons theyre all totally different keys, was wondering if theres a deeper individual section of the keyhole beyond the crosshead maybe Confused
PostPosted: 20:20 - 29 Aug 2013    Post subject: Reply with quote
It does have a key lock.
https://i.ebayimg.com/t/ENFIELD-GARAGE-DOOR-LOCK-BOLT-REPLACMENT-CYLINDER-CORES-/00/s/MTIwMFgxNjAw/z/TAYAAOxy79VRctjN/$T2eC16RHJGMFFprc4gs2BRctjMsU9!~~60_12.JPG
andym
PostPosted: 20:28 - 29 Aug 2013    Post subject: Reply with quote
Can't they just wedge a bit of wood under the side of the handle that drops? That's all I did until I repaired the lock on mine
-Matt-
PostPosted: 20:37 - 29 Aug 2013    Post subject: Reply with quote
Only the main door single entrance so wouldnt work if im understanding what you meant andy?
Thanks for that shaggy hadnt noticed the tip of the key properly looks like that one should do the trick Thumbs Up
spikenipple
PostPosted: 20:47 - 29 Aug 2013    Post subject: Reply with quote
Maybe I should look at the key next time Laughing
Nope.
PostPosted: 21:47 - 29 Aug 2013    Post subject: Reply with quote
I have a set of these. They're OK but one of them jammed up and had to be drilled out. I guess it could happen to any lock outside over a period of time but these we're no more then 3 years old. Guess the quality differs from manufacturer to manufacturer.
-Matt-
PostPosted: 22:40 - 29 Aug 2013    Post subject: Reply with quote
Thanks everyone. Noticed on the picture i posted of it fitted to a garage it looks like a reinforced section has been added to the garage door frame, did you do this computid or is it just additonal protection probably?
andym
PostPosted: 12:03 - 30 Aug 2013    Post subject: Reply with quote
Sorry I thought you meant it was this kind of handle that was on there already:
https://s7g3.scene7.com/is/image/ae235/?$p$&wid=281&hei=281&op_sharpen=1&layer=0&size=281,281&layer=1&size=281,281&src=ae235/74579_P
With a similar handle on the inside (with a little knob instead of the key obviously), so that's why I said about using a piece of wood wedged between 1 side of the handle and the floor...
angryjonny
PostPosted: 12:35 - 30 Aug 2013    Post subject: Reply with quote
If I understand correctly the problem is that you'd have to set that up from the inside. And without any other exit from the garage, you'd have to then live in the garage.
stevo as b4
PostPosted: 14:15 - 30 Aug 2013    Post subject: Reply with quote
Im sure you can get those discreet door locks with a proper 5lever lock mechanism instead of that silly little cross head key.
I would make up two 3mm thick steel plates to bolt into the wood frame either side with a hole cut out for the locking pin/mortice lock, or use a piece of angle iron etc.
-Matt-
PostPosted: 14:58 - 30 Aug 2013    Post subject: Reply with quote
It is the style of lock you pictured andy, but as jonny said [again if im understanding what you meant properly] it would mean to get it locked you'd essentially be stuck inside as theres no other exit Thumbs Down
I told them it might be easier getting a lock smith to do something but they said they don't trust them with the keys and not to rip them off, so its landed in my lap Laughing Rolling Eyes
stevo as b4
PostPosted: 15:21 - 30 Aug 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Yale-5-lever-Mortice-Lock-/171114171192
You could make a couple of these fit the sides of the garage door easily enough and use some thick steel plate over the mortice box which you would recess slightly into the frame. I'd say they are better than the locks you have linked in your OP.
-Matt-
PostPosted: 15:37 - 30 Aug 2013    Post subject: Reply with quote
Cheers Stevo Thumbs Up
Going to ask to have a good look at their door later and work out what the best lock/method of fitting is going to be as i've only had a quick glance so far, need to size up whats going to fit or not properly.
Wonko The Sane
PostPosted: 18:32 - 30 Aug 2013    Post subject: Reply with quote
on my parents they just drilled into the wooden frame for the bolt to slide into
didn't bother re-enforcing them.
however, the garage is 4 volvo estate lengths from the road, tucked down the side of the house past two cars, ground level is 6ft lower than road so you can't actually see the locks, they're there to slow down entry and hopefully ward off anyone chancing it.
They were fitted after a break in where we lost one mountain bike (the more expensive one was left) two power drills and an angle grinder.
andym
PostPosted: 19:23 - 30 Aug 2013    Post subject: Reply with quote
Point taken, didn't realise it was a detached garage (maybe if I'd read the whole thread properly then I might have noticed it), I had a side door that led into the back garden which is why I could use that method Embarassed
andys675
PostPosted: 20:39 - 30 Aug 2013    Post subject: Reply with quote
though about a garage defender?
andys675
PostPosted: 20:41 - 30 Aug 2013    Post subject: Reply with quote
Aff
PostPosted: 20:43 - 30 Aug 2013    Post subject: Reply with quote
Neutral
Electric Bike Project
stevo as b4
PostPosted: 21:22 - 30 Aug 2013    Post subject: Reply with quote
Can the guy realistically get to insert keys into locks that are no higher than 12" from the bottome of the door then?
Mortice locks obviously want to be sited low down on the door frame and not nearer the pivot point.
Ariel Badger
PostPosted: 21:44 - 30 Aug 2013    Post subject: Re: Garage Bolt Reply with quote
-Matt- wrote:
My two bikes are behind those ATM.
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 133.41 Kb
